28/12/2015 - [ROM] CX-919 CM12.1 (Lollipop 5.1.1)
    Originally posted by michie View Post
    Android 5.1.1 for the CX-919 (CM12.1)
    03/01/2016 V1.3 :
    - Clean Base
    - Fixed Storage
    Strange bug with this ROM - not start loading stick when SD card is inserted. Do u know how to solve this?
      Originally posted by Avasz View Post
      About to install this in MK908ii (RK3188T version).
      *Heavy Breathing*
      Did this work for you?
        I just installed this on my MK809III. It's RK3188 and the chipset (for bluetooth and wifi is AP6210). All is well so far except the bluetooth (which was clearly stated by the OP). Has anyone successfully gotten the bluetooth working? If so, how?
          I tried Netflix, and aside from the Google Play store constantly closing (I had to download Netflix using Play Store on my laptop and selecting Nexus), Netflix won't play right. It either won't play at all, or when it does, the picture is mostly black, with a distorted images across the top (but there is still sound).
          Tried my old kernel, wouldn't boot. Now on to try some others. Any idea as to what might be wrong?
            please help me!
            3) c) the device will reboot in recovery, do factory reset, wipe cache, wipe dalvik cache
            but i don't know how to factory reset,
            then plug to tv hdmi :loop reboot.
            redo step 2) a)-f) can't continue...
            error message:
            USB Device Not Recognized (Error Code 43)
            How to do?
            win10 64bit
            update:
            for win7 driver can find device.... try other
            firmwares.
              *Heavy Breathing*
              I'm not the OP, but would have liked to see this info a few hours ago. But I did an install on my MK908ii anyway, and it seems to work very nicely so far.
                So ... after two days running this ROM (v1.3) on both a CX-919 and an MK-908ii ... I have to say this is close to being the ROM we've been waiting for for these devices. It's nice and smooth, and a it's great to have CM and a nice clean interface, and Android 5... but:
                • I've seen four or five spontaneous reboots
                • Lots of apps quit suddenly (I've seen this in Youtube as well as various games)
                All of which look more kernel problems than anything else. So can someone recommend a different kernel to try with this ROM?
                  For me, the most stable rom so far has been pureX KitKat. Actually, it's the only custom rom I've installed on my CX-919; it does everything I need it to do and feels rock solid.
                  Have been curious to try the Lollipop rom, but reading about the reboots and apps quitting isn't encouraging. I don't observe any of these symptoms on pureX.
                    Any fix for bluetooth? I have installed this rom me going great , but I need bluetooth to connect a mouse , is there any way to correct it? also has been restarted me twice, I would like to collaborate with the development of this rom if necessary . Sorry this is a google translation.
                      i have this dongel and now work on it androind 4.4 kitkat
                      the new rom should work for me?someone?
                        Originally posted by isync View Post
                        I tried changing the DPI, but that only changed the size of objects on the screen. The TV stayed in 1080p the whole time.
                        I agree that 1080p might be too much for this stick. I was using Finless 1.5 4.2.2, and I could select screen resolution. But, I found that 1080p was too much for it and ran in 720p.
                        Any other ideas how to switch the screen resolution ?
                        I share here the kernel I'm using for 720p in a CX919 clone device.
                        Don't forget to change DPI to 160 *before* you flash this kernel, or patch your build.prop in system.img setting "ro.sf.lcd_density=160"
                        P.S.: Use at your own risk. Make sure you know how to reflash your device in case something go wrong.
                          i try to install it but not work can someone help me?
                            Ok....I have never flashed a unit before and I tried to flash my cx-919 with this file. I followed the instructions and the first part went well. Once I closed the develop tool and opened the android tool, my laptop would no longer detect my cx-919. I am using a laptop with windows 10. Can anyone help me out. No matter what I try, it won't detect the tv dongle. I am holding down the button on the side and my laptop makes a sound that it has picked up something plugged in, but it fails to detect it. Have I bricked it by chance? Please help!!!!!
                            Last edited by tparis; 14 April 2017, 03:50. Reason: nevermind, I solved the issue. It was a Windows 10 driver issue.
                              Ok, after the firmware is written, do I connect it to the tv for the last part (reboot in recovery, etc....)?
                                I connected to TV, followed the instructions and now once I reboot, all I get is a blue, red, yellow and green swirling dots on the screen. PLEASE HELP!!!!
