Pipo M9 Max 4.2.2 RileyROM 1.4
    OK, I'm uploading the 1.5 version. Ready for testing. If it works, I'll make a new thread.
    While I'm waiting, I thought I would mention a thread about getting Netflix working on 4.2.2 ROM's:
    Netflix Fix
    I just installed your ROM on Pipo Max M9. It went smoothly and I am happy.
    The only thing that makes me unhappy is the Netflix problem. I tried to install the "Exposed framework" from the thread you referenced but when got it installed I lost my WiFi connection and the only way to get it back was uninstalling the framework and subsequent reboot.
    Are you going to fix the Netflix problem in the near future? I know that this is a common issue across different devices and some of them managed to solve the issue.
    Thank you!
      Pipo just introduced a firmware update for the M8 Pro that's sole purpose was to fix Netflix...and it works perfectly on my M8 Pro. I'm looking for an update soon for the M9 with the same fix. Looks like they have the same guy working on all of these firmware updates, and he releases them one at a time.
      Stay tuned.
      Randy
        Stay tuned.
        Yo riley, there is already a new firmware released by pipo m9, is the new custom rom in the works built on this one? Just wanna know cause I'm thinking about using your custom rom. The other users say games run faster and smoother on your rom. Especially dead trigger and shadowgun deadzone.
        Anyone tried the new updated firmware with descriptions?
        M9 software_english version_20130529(no need key) version#79
        M9 software_new pcb_english version_20130529(need key)
        Does anyone know which one to use?
        I didn't enter a product key when I upgraded to 4.2.2 last time
          Sorry did a little back reading you already mentioned it is based on 5/29/2013 version
          Thanks! More power
            pipo m9 bluetooth prob
            hi riley, im fascinated on your rom making but im having a problem on bluetooth connection. the sixaxis controller app is working fine but when i pair my controller my sixaxis remote wont pair on my tablet and the bluetooth wont turn on when the app was started. hope you could help me fix this.
              It may be that you need a driver for your device. We will need to look into that. Leolas is our driver guy.
              Randy
              Randy
                could you provide a fix rom for it. just improve the 1.5 and it would be awesome
                  I'll work on that Monday.
                  Randy
                  Randy
                    tol...
                    Thanks! More power
                    Tol tga san ka? Tga pinas kb? Rom of riley is very ok.. although im having a prob on the sixaxis controller ( kung gmagamit ka nun?) Hopefully riley would put a fix on it. And also. To mr. Randy, did u try playing world war z? It doesnt work..
                      randy
                      help, when i erase d idb its numbers is 4096? how come it is like this? how could i fix it
                        Make sure you have a good USB connection. Let the tablet connect in loader mode for about 10 seconds before erasing IDB.
                        Those two things usually fix the IDB issue.
                        Randy
                        Randy
                          sixaxis controller support.
                          Hi, I was wondering if there has been any progress with getting the ps3 controller to work wirelessly?
                            You should ask this question in a thread relating to a newer ROM. For instance RileyROM 1.7 : http://www.freaktab.com/showthread.p...7-with-SDK-2-0
                            Support your local flasher
                            Current devices : Pipo MAX M8 Pro - Samsung Galaxy S4 - Intel NUC
