Stock Firmware For Tronsmart Vega S95
    HI guys:
    This is the stock firmware for vega S95. Copy this from Tronsmart forum. and here we go:
    Dear All:
    We’re pleased to announce the stock firmware for Vega S95, This is the stock firmware which shipped with your device. and if we have new update, you will receive the OTA update notice, and you just need to click update button.
    OTA update procedures:
    1.) All Apps -> Update & Backup App -> Click ” Online Update”
    Or Settings -> More Setting -> About Mediabox -> System Update
    2.) Confirm to update and let the system to reboot and complete the update process
    If you want the full system image, They are here:
    We offer two ways to update the system manually:
    1) Via SD Card
    2) Via PC (Only support windows pc right now, and need usb-a male to male cable)
    The update instructions for both is here:
    www.mediafire.com/download/pt1gj3gi5bb68...ctions%26license.zip
    For Vega s95 Telos:
    www.mediafire.com/download/b4krtgjm7f485...S95_Telos-151127.rar
    www.mediafire.com/download/y3ht3a1eekg7n...SD_Update_151127.rar
    For Vega S95 Meta:
    www.mediafire.com/download/i3813rgv9tqv1..._S95_Meta_151128.zip
    www.mediafire.com/download/c2180zxzo3mfj...5_Meta_SD_151128.rar
    For Vega S95 Pro:
    www.mediafire.com/download/6r4qigdrxe586...a_S95_Pro_151128.zip
    www.mediafire.com/download/l6esfgsfirwep...95_Pro_SD_151128.rar
    Remote controller app for Android phones:
    www.mediafire.com/download/1f7z9f31pqq4y...Client_Tronsmart.apk
    Any questions, please kindly let us know.
    Best Regards
    Tronsmart Team.
    As far as i know, Tronsmart is working on a new firmware base on the new sdk from amlogic to solve some bugs from customer report. and they will arrange the OTA update soon.
    Eric
    Looking for developers
    HI,
    is there any build number or how to
    determine which version is already pre-installed box?
    Br,
    Andris
      Hi yes if you go to settings/more settings/ about media box
      The build number is right at the bottom
        How to hard or factor restore this tv box ?
          Hi yes if you go to settings/more settings/Backup & reset
          Factory data reset
          will put your box back to the way it was when you first brought it.
            Originally posted by blinkone View Post
            Factory data reset
            Yes, but if the box is rooted, root will persist after Factory Data Reset. At least it did after resetting the Meta.
            Good day.
              i am asking about hard reset ! How to hard reset the box ? with some kind of switch ! where that reset switch is located ?
                If you are referring to a physical switch, there is a "Fn" button via a pinhole on the bottom. How this applies to your objective is unknown to me.
                  Firmware update: Telos
                  New firmware for Tronsmart Vega s95, Version 20160119.
                  Vega s95 telos:
                  For SD card update method, you can use this image.
                  If you prefer to update via your windows PC, Here is the image file you might need.
                  Download the update here is the instruction if required
                  Rest to follow soon
                    Well done ! trebor.
                    When will the new one for the Vega s95 pro come out ?
                      The Pro will be the last after the Meta I am led to believe, you keep an eye on the Tronsmart Forum for information
                      Cheers
                        New OTA firmware for Meta is available now. Just update OTA, it went fine. Have not had time testing yet.
                        One thing I can confirm is that the OTA update will not get the device loop like Beelink units.., just lick confirm to update and let the device does the rest.
                          Good to know for us Meta users.
                          Thanks.
                            We can confirm they push the update to Meta and Pro version today.
                            They should release the full image soon for both version.
                              Just updated my firmware to latest on my Meta and noticed that the 4k@60hz is no longer available. Anyone else have this issue? Is there a way to revert factory firmware? I attempted to load via SD card and during update it says that it can't update over a newer firmware.
