Minix questions.
    Minix questions.
    1. I understand when you root the minix you lose the Ota update capability. Does this mean I should update firmware and then install custom root?
    2. Could it be possible in the future to root the u1 with Ota still capable.
    3. If I have to install stock rom every time there is a new Ota update is there any easy way to keep all my previous kodi, apps, settings to be able to restore them. I would like to be able to set up kodi and not have to do it every time a new firmware comes out
    4. I use this box for only kodi. Do some kodi apps require root to Work?
    I have ordered a U1 and been reading the forums. I'm excited to get it up and going. I have a little experience with Android tronsmart-s89h. I learned a bit and have read about the minix boxes and thought it would be a good choice. Learning all the rooting methods with the s89 was a lot at once so I hope to refine the skills on this box. Any help is appreciated. I understand this box is still new so they need to work stuff out over time.
    Cheers
    you can root using "update.zip" (oops seems no ota anymore, got it wrong..)
    http://www.freaktab.com/forum/tv-pla...root-check-why
    anyway, goodluck.. and if you can post a review/user-feedback of the U1
    Last edited by mitchell4you; 30 December 2015, 20:28. Reason: update..got it wrong
      I'm no expert but I will post a brief review or video review. Just trying to decide if I should root or not. We will see...
        I have not looked at what the OTA update APP is looking for to determine if it is rooted or not but I will investigate and maybe make a simple way to hide it or unroot easily.
          I have not rooted mind yet, but I am very interested in the un-root method. Thanks for all you do Bob.
