I just got the QX1 today!
Originally posted by Finless View PostAll the stick support 1080P. But understand if the kernel is native 720 then when you set to 1080, it is upscaled and thus not truly 1080P.
Some people want true 1080 pixel resolution. Why I am not totally sure as I cant tell the difference. But they do.
No Power On after Power off on 4.2.2. rom
Hey guys, sorry for my english, i am Yorgos from Greece, i bought this imito qx1, i flashed the official 4.2.2 rom. Everything went well, until i pressed on the main screen the power off button. It promed me that the tablet (?) will switch off.
After that i canot switch it on. I unplugged the power cable and plugged it again, i tryed ctrl-alt-del on the wireless usb keyboard. Nothing. It seems to be dead.
Please Help me!!! What can i do???
(I tryed to connect it to the pc but the pc dont recognised that i pluged something to it)
Originally posted by j0hnj0hn View Postis it stable
does it gets very hot
Push the system generally and it falls over, exactly the same as the normal definition rom. All in all pretty poor but I suppose its slightly better looking, at least when it freezes its in 1080.
Originally posted by Finless View PostOK I just got the QX1 today.
The stock ROM it came with BLOWS! USB hubs are not even supported.
It's expected though folks... I just flashed to the recent release geekbuying posted and WAY BETTER!
All working well so far.
If you got one of these with 4.1.1.... DO YOURSELF A FAVOR! Flash the latest ROM NOW!
Don't frustrate yourself with the ROM it came with.... Seriously!
I will report back soon and also do a "What's in the Box" video for you all.
Oh... and expect a ROM from me... I see things already I want to fix
it there a tutorial on how to flash a rom on the imito qx1
Originally posted by j0hnj0hn View Postit there a tutorial on how to flash a rom on the imito qx1
Then I used the Flash Tool after installing the drivers as described here:
And that worked.
HTH,
Mike
Re: I just got the QX1 today!
1. Enable usb debugging in settings
2. Connect it to your PC with the supplied usb cable.
2. Install rockchip drivers.
3. Run the the Rockchip Batch tool. Use version 1.7.
4. You will see your device with a pink color. Click switch and wait for 5 secs. Your device should be green now.
5. Load the firmware and press upgrade.
Sent from my GT-I9300 using Tapatalk 2
Do i have to factory reset first
and is their a way that i can backup my apps and my appss settings like XBMC (so it keeps its addons and fixes)
There are currently 3248 users online. 0 members and 3248 guests.
