VOYO V3 Intel Cherry Trail X7-Z8700 4K Mini PC Windows10 64Bit 4G/128G 2.4G/5G Dual Band WiFi Type-C BT4.
    VOYO V3 Intel Cherry Trail X7-Z8700 4K Mini PC Windows10 64Bit 4G/128G 2.4G/5G Dual Band WiFi Type-C Bluetooth 4.0
    Equipped with Intel Cherry Trail X7-Z8700 CPU and Intel HD Graphic GPU, VOYO V3 Mini PC provides a better experience to enjoy time with family and friends. What`s more, it can can be applied to office software to create a mobile working environment. All in all, its ultra slim metal body with its powerful functions extends the users outstanding effect, so that it is worthwhile for you to possess.
    Intel Cherry Trail X7-Z8700 with a maximum clock speed of up to 2.4GHz.
    8th Generation Intel HD Graphic
    Windows 10
    Bluetooth 4.0: Easy pairing
    5G WiFi with more stable WiFi signal
    4GB RAM + 128GB ROM
    Last edited by trebor; 19 January 2016, 18:12. Reason: No GB LAN, optioned only with a USB/lEther device
    Do you have a link to we're you can by this. Thanks.
      Try the Search Function at the top of the Page.
      May not work with everything all the times, a good place to start
      The V3 is an Interesting bit of Gear
      Cheers
        Yeh, Its on geekbuying for £166. bit to pricey for my taste like & i think it will throttle a fair bit. there is no heat vents that i can see.
          For what it is, with the specs, it's not bad value, especially for those that might like the idea of a NUC style box but don't like the thought of installing components.
          The specs talk of ethernet but from the images I can't see a port to support it.
            There is no ethernet, I asked geekbuying and they replied, but didn't change specs
            You can put Gigabit ethernet on usb 3.0 port, but with same logic you can say it has dual gigabit ports, sata port, DVD drive, etc :
              Good review here
                Good, bit over the top about UA settings, but what can you do, one has to live on the wild side.
                Also CNXSoft has a teardown.
                Cheers
                  Hey guys, I've found a $10 coupon for this Mini PC at geekbuying and thought I would post it in here for you, too. Coupon code: DJHOKQFS.
                    Did anybody get it?
                    EDIT: The coupon got updated to: VY3EDM.
