Visible blue led mod
It always bothered me, that I didn't have immediate feedback, whether my Ug802 is powered or not. The led is hidden, and the only way to see it, was to look at the device from different angles, or in complete darkness. I wanted a way to let the led shine through. At first, I drilled a small hole in to the case, as seen on the Mk808, but found it insufficient. Steel peeking through holes. So I decided to etch a straight gap from the hole to the side of the lid, an put a square piece of transparent plastic in it, wich should guide the light, out of the box. I used a piece of plastic cut from a CD-RW jewel case, I had laying around. Shaped it, with a nail file, to the shape of the casing, and glued it in with some hot glue. -
Originally posted by DiSrUpTeR View PostNice....
There are currently 2037 users online. 1 members and 2036 guests.
