Just figured it was worth an ask. Thanks!
QX1 Video performance question
Does the QX1 play Netflix and other video apps smoothly or does it have the same jitter effect as the tronsmart mk908? Wondering of course if the kernel from this rom (assuming it´s got smooth video) could be ported to work for the 908. I tried flashing it outright but it wouldn´t post a screen. I´m assuming it is a similar issue to the rk3066 devices - mk808 kernels wouldn´t post video on a ug802 for instance because it used a different port internally (eg: hdmi1 vs hdmi0) for video output.
Just figured it was worth an ask. Thanks!If my work benefits you and you want to help out the cause, feel free to
http://www.hoaby.com/android/donate.gif
Tags: None
I'm currently mucking around with a QX1 and can safely say that video comes through flawlessly. So far i've tested it with HD youtube videos, streaming through my PLEX server and videos saved on a flash drive. I am, however, on the latest firmware released by the iMito people which required a quick flash through the rockchip app.
No complaints so far.
Originally posted by hoabycsr View PostDoes the QX1 play Netflix and other video apps smoothly or does it have the same jitter effect as the tronsmart mk908? Wondering of course if the kernel from this rom (assuming it´s got smooth video) could be ported to work for the 908. I tried flashing it outright but it wouldn´t post a screen. I´m assuming it is a similar issue to the rk3066 devices - mk808 kernels wouldn´t post video on a ug802 for instance because it used a different port internally (eg: hdmi1 vs hdmi0) for video output.
Netflix is totally unstable for me... hangs, crashes, etc.
Just what I tested last night. I know Imito will fix it.
I had the same issue at first with the new firmware but I noticed it didn't **** up as much when connected to an Ethernet connection instead of wifi
Originally posted by Finless View PostNetflix is totally unstable for me... hangs, crashes, etc.
There are currently 2280 users online. 1 members and 2279 guests.
