Neomode
MK802III-S New Firmware Android 4.2.2 NEOTV CROM 2.0
Originally posted by cordobes View PostThanks both of you.
If I understand correctly, this is an App/Script that should be installed and then executed to reboot on recovery, correct?
If this is it, I'm in trouble, because my device isn't booting... it just shows the CRT 2.0 screen, but nevers finish the loading.
Re: MK802III-S New Firmware Android 4.2.2 NEOTV CROM 2.0
Originally posted by default View Postneomode, thank you for the roms.
I have one observation that i'd like to share. Wifi seems to be worse in 2.0. Wifi in your 1.9 rom is way better. Wifi is significantly better in your 1.9 rom that I have reverted back to it.
Does anyone else have the same experience?
Sent from my TPC0702 using Tapatalk 2
Originally posted by kmac21 View PostI had same problem first time, had to re flash again via pc
Neomode, thanks a lot for firmware!
Little question. As I understand, Ultra Explorer is exchange for basic explorer tool. But I do not see possibility of opening network storage //192.168 etc... Or by computer name as samba client. Does Ultra Explorer have such option? If not, what software do you recommend? Thanks for answer in advance.
Given how close the devices are, would this work on an MK802III?Last edited by wololo; 15 June 2013, 03:54.Review of the MK802 IV
My list of 10 "Must Have" apps for your android mini PC
Tutorial: how to setup Unblock-US on your mini pc (to watch Netflix outside of the US)
MK802 IIIs won't boot after flash
I have three MK802 IIIs by Rikomagic, all three came from Geek Buying through Amazon and appear to be identical.
Two of them will flash this ROM, boot and work just fine other than Launcher not working. AndroidTV works so that is a non-issue with me. Another plus is my RT-MWK01 Mini Keyboard with Touch Pad works on this ROM but did not on the RikoMagic April 19 firmware.
The third one will flash this ROM but will not boot. It generally gets stuck at the black and gray ' NeoMode Custom ROM ' screen. I have flashed numerous times with the same results. It can always be flashed back to the RikoMagic April 19 firmware with no apparent problems. It doesn't seem to matter if I ' Erase IDX ' or not before flashing.
The one thing I have noticed that is different is the Log File.
The two that work log files are as follows;
17:19:58 565 Flash Chip Information:
17:19:58 565 NO SIZE(MB) Manufacturer
17:19:58 565 ----------------------------------------------
17:19:58 565 0 8192MB MICRON
17:19:58 575 --------------------------------------------
The one that appears to flash but fails to boot log file is as follows;
16:13:30 079 Flash Chip Information:
16:13:30 089 NO SIZE(MB) Manufacturer
16:13:30 089 ----------------------------------------------
16:13:30 089 0 8192MB HYNIX
There are no errors in either log files that I can determine.
Any suggestion would be appreciated.
Chateau, have you tried this rom http://www.freaktab.com/showthread.p...5368#post65368 ? Apparently this rom works on all versions. The 2.0 ROM did not work out to well for mine but works great with 1.9. Best of luck to you.
Originally posted by default View PostChateau, have you tried this rom http://www.freaktab.com/showthread.p...5368#post65368 ? Apparently this rom works on all versions. The 2.0 ROM did not work out to well for mine but works great with 1.9. Best of luck to you.
There are currently 3383 users online. 0 members and 3383 guests.
