MK802III-S New Firmware Android 4.2.2 NEOTV CROM 2.0
Try it with these Module for the AR Card http://forum.xda-developers.com/atta...0&d=1360039535.
For the Realtek i have found nothing.
Neomode
Originally posted by neomode View PostWich External Wifi Module ?
Please tell me the Product you want using or the Chip Type.
ThanksOriginally posted by neomode View PostTry it with these Module for the AR Card http://forum.xda-developers.com/atta...0&d=1360039535.
Neomode
Hello, first of all thanks Neomode you did an excellent job with your CROMS.
I'm Ezequiel from Argentina and I bought a few weeks ago a RikoMagic MK802 IIIs, I would like to use an external Wifi Dongle with my Android PC.
I attached a photo of it. It's Belkin.
Uploaded with ImageShack.us
Could you help me to install the module?
Thanks so much,
Ezequiel
Before I return wanted to ask
Neo, I bought a BobjGear USB 2.0 to 10/100 ethernet adapter to replace the 10Mbs adapter I am using.
It is the one on this page: http://www.amazon.com/BobjGear-Ethernet-Ultrabooks-ChromeOS-Included/dp/B007RTACDM/
It claims to be compatible yet I do not get a link. I am able to see the MAC address on the setup menu but it never get an IP address from my router. The old one works right every time.
Is a specific module (that does not come by default in Android) needed? This is the second unit I received (I returned the first as defective) so the behavior is puzzling to me. It has "ASIX AX88772 Driver Compatible" printed in one corner, if that helps any.
Thanks!
neomode, what is it that you did different in version 1.9 of your rom to make WIFI performance so much better?
I have two 5th edition MK802 IIIS with bluetooth (8GB) that works fantastic WIFI wise when I flash version 1.9. But when I flash version 2.0 WIFI performance is noticeably poorer. What is up with that?
Originally posted by neomode View PostThe 2.0 has a different Kernel to make running android 4.2.2. That's all.
Neomode
There is any possibility to use this USB Ext Wifi Dongle?
Originally posted by EzeCuervo View PostHello, first of all thanks Neomode you did an excellent job with your CROMS.
Thanks so much,
Ezequiel
Thanks again for your help.
Originally posted by Sadykovildar View Postremote control work with this app,
http://www.mediafire.com/download/9ettekulsbk5g82/RKRemoteV2.0.2.rar
In this link you can see more))))
http://blog.geekbuying.com/index.php.../#.UbCLWfktxar
Must I change something in the server?
I've tried this ROM and it works with chipset WIFI MEDIATEK MT5931SA & BT Mediatek MT6622N, but the launcher gives an error when booting. Also youtube can't be updated and XBMC is not smooth at all with this ROM.
Is there any other rom available (with better performance) for the mediatek wifi and BT?
There are currently 3428 users online. 0 members and 3428 guests.
