New thread for drivers petitions.
    Originally posted by mustafaupk View Post
    1 What is your stick?: Original MK808-B
    2 What is your rom?: Finless ROM 1.7
    3 What is your kernel?: 3.0.8+
    4 Id of the device you want the drivers been compiled and the commercial name. : 2001:1a02, DLink-Dub E100C
    5 Main chipset of the device: asix
    6 Link to the driver that comes with the device (if you have it): https://www.dropbox.com/sh/bgqpfsnhhgcnjde/QAF8zeXi9l
    Hi Leolas,
    I am trying to get a modified asix driver to load alongside the built-in asix driver. Can you compile it and let me know about any errors? Hopefully it works.
    Hi Leolas, I am also looking for the same driver. Any help would be highly appreciated.
    MK808B|D-Link Powered USB Hub|Looking for working USB to Ethernet adaptor...
      Re: New thread for drivers petitions.
      Sorry i was away for some days, now i am back again but working in qx1 kernel development.
      About axis drivers, every driver i try to compile has the same problem, the kernel has this driver inside, so any module will conflict with the internal kernel driver, so sorry no solution
      leolas
      My devices:
      Gearbest.com)
        Thanks for the response Leolas. Pity, guess we going to have to buy a known working adaptor.
          leolas
          Hi Leolas,
          I know that the asix driver is present in the kernel. I'm trying to modify the asix driver so it registers under a different name (bsix) and see if I can successfully load it. Could you please compile the driver using the sourcefiles I provided? I want to try it.
            Hi Leolas,
            Of course, I will try, but I am almost sure than the device will be claimed by the kernel driver, but if you adapt the sources and give me a link i will try to compile them.
            leolas
            My devices:
            Gearbest.com)
              leolas
              Here's the source with modified sources.
                Originally posted by malfrat View Post
                Have you try the rkwifi,ko rename method, 8188eu.ko is already in system/lib/modules
                dont forget to set permission to 644. i.ve already made a thread that could help you try this. really hope it work for you
                Thank you, I'll look for that thread and give it a try,
                  Unfortunatelly it didn't work...
                  Renamed /system/lib/modules/rkwifi.ko to rkwifi.ko.old
                  Renamed /system/lib/modules/8188eu.ko to rkwifi.ko
                  check permission of new rkwifi.ko to rw-r--r--
                  Connected wifi dongle in OTG then rebooted.
                  After reboot, wireless is down and i can't turn it on
                    Try to connect the usb wifi dongle to the normal usb port
                    leolas
                    My devices:
                    Gearbest.com)
                      I will try it when arrive home
                      leolas
                      My devices:
                      Gearbest.com)
                        leolas
                        Hi Leolas, I just did it, same method but connecting wifi dongle in normal MK808's USB port, unfortunatelly it didn't work...
                        Thanks in advance for any help.
                          Code:
                          leo@leolas-desktop:~/kernel/drivers/patched-asix$ make
                          make -C ~/kernel/3.0.8+/rk3066-kernel ARCH=arm SUBDIRS=/home/leo/kernel/drivers/patched-asix CROSS_COMPILE=~/kernel/arm-eabi-linaro-4.6.2/bin/arm-eabi- modules
                          make[1]: se ingresa al directorio «/home/leo/kernel/3.0.8+/rk3066-kernel»
                            CC [M]  /home/leo/kernel/drivers/patched-asix/asix.o
                          In file included from /home/leo/kernel/drivers/patched-asix/asix.c:41:0:
                          /home/leo/kernel/drivers/patched-asix/axusbnet.c: In function 'rx_submit':
                          /home/leo/kernel/drivers/patched-asix/axusbnet.c:318:22: warning: unused variable 'info' [-Wunused-variable]
                          /home/leo/kernel/drivers/patched-asix/asix.c: In function 'ax88772_suspend':
                          /home/leo/kernel/drivers/patched-asix/asix.c:591:17: warning: unused variable 'dev' [-Wunused-variable]
                          /home/leo/kernel/drivers/patched-asix/asix.c: In function 'ax88772b_suspend':
                          /home/leo/kernel/drivers/patched-asix/asix.c:614:24: warning: unused variable 'ax772b_data' [-Wunused-variable]
                          /home/leo/kernel/drivers/patched-asix/asix.c: In function 'ax88772b_resume':
                          /home/leo/kernel/drivers/patched-asix/asix.c:667:24: warning: unused variable 'ax772b_data' [-Wunused-variable]
                          /home/leo/kernel/drivers/patched-asix/asix.c: In function 'ax88772b_bind':
                          /home/leo/kernel/drivers/patched-asix/asix.c:1602:5: warning: unused variable 'i' [-Wunused-variable]
                          /home/leo/kernel/drivers/patched-asix/asix.c: In function 'ax88178_phy_init':
                          /home/leo/kernel/drivers/patched-asix/asix.c:2305:1: error: unknown type name 'v'
                          make[2]: *** [/home/leo/kernel/drivers/patched-asix/asix.o] Error 1
                          make[1]: *** [_module_/home/leo/kernel/drivers/patched-asix] Error 2
                          make[1]: se sale del directorio «/home/leo/kernel/3.0.8+/rk3066-kernel»
                          make: *** [default] Error 2
                          There was a v hidden in the first col of 2305 line, if I removed it then:
                          Code:
                            Building modules, stage 2.
                            MODPOST 1 modules
                          WARNING: "dwc_otg_clear_halt" [/home/leo/kernel/drivers/patched-asix/asix.ko] undefined!
                            CC      /home/leo/kernel/drivers/patched-asix/asix.mod.o
                            LD [M]  /home/leo/kernel/drivers/patched-asix/asix.ko
                          here is the link to the driver http://cloud.freak-tab.de/public.php?service=files&t=4b0911249d693760030f8a1 2ddf70ce3
                          My devices:
                          Gearbest.com)
                            Sorry then new sources needed, I am working in the qx1 now so i dont have free time time to work in drivers, i will try retake this thread as soon i can make the qx1 works well.
                            My devices:
                            Gearbest.com)
                              Code:
                              Code:
                                MODPOST 1 modules
                              Thank you leolas.
                              There was an error about dwc_otg_clear_halt which was caused by axusbnet.c. I've replaced the axusbnet.c file with a newer version. Could you compile one more time?
                              Here's the link:https://www.dropbox.com/sh/8v3eqmkkmhn641g/n7431wf0tJ
                                BTW leolas,
                                In the following command:
                                Code:
                                Is the ~/kernel/3.0.8+/rk3066-kernal directory a copy of the omegamoon kernel sources?
                                And what is the source for the ~/kernel/arm-eabi-linaro-4.6.2/bin/arm-eabi- modules directory?
                                If you can answer these questions, I could probably compile these drivers myself and speed up testing.
                                Thank you.
