Exactly. So I'm not using Netflix at the moment, because it just annoying! I hope they come with a fix soon.
QX1 notes and bug fix list
No Power On after Power off on 4.2.2. rom
Hey guys, sorry for my english, i am Yorgos from Greece, i bought this imito qx1, i flashed the official 4.2.2 rom. Everything went well, until i pressed on the main screen the power off button. It promed me that the tablet (?) will switch off.
After that i canot switch it on. I unplugged the power cable and plugged it again, i tryed ctrl-alt-del on the wireless usb keyboard. Nothing. It seems to be dead.
Please Help me!!! What can i do???
(I tryed to connect it to the pc but the pc dont recognised that i pluged something to it)
Originally posted by hispan1c View PostHi yorgos, is the blue led lit on the qx1? If not it is getting no power.
Sent from my GT-I9300 using Tapatalk 2
No the blue lit is not on, but there is no problem with the "charger" or the cable, because i have another qx1 and it works with the same cables. I don't know what to do, i only pushed on the home screen of 4.2.2 the power off button, and it was like i ordered my device to die...
Thank u for your quick reply, any suggestions???
Re: QX1 notes and bug fix list
Gee, that sounds like its dead. I know what you mean because I have used that power off icon a couple of times too, it just turned off the device but when I pulled the power plug from it and put it back, it worked fine. Did you tried sticking a metal pin in the reset hole? Just to try anything....
Originally posted by hispan1c View PostGee, that sounds like its dead. I know what you mean because I have used that power off icon a couple of times too, it just turned off the device but when I pulled the power plug from it and put it back, it worked fine. Did you tried sticking a metal pin in the reset hole? Just to try anything....
Yes i tryed that too....anyway thank u so much for your help, i will try tommorow find a wired keyboard, hoping with ctrl-alt-del or fn-enter will wake that stick!!!
I have tested this 1080 rom now for a few days and for me Netflix is not working. Generally when a movie starts it freezes then returns back to the title screen.. When a movie does play it often plays with just sound. Sometimes I have to clear cache and data just to load the titles.
Originally posted by Runner68 View PostI think I solved it. I take out the origin power supply n use my own usb 2a hub connect to the imito qx1 with the normal usb port(not the micro usb) and everything work well. The supplier power supply is the main problem for me.
There are currently 4189 users online. 1 members and 4188 guests.
