M8 S812 unbrick help pls ?
    hi guys
    i have an OTT M8 tv box here
    on the pcb there is
    XT-s812-v10
    2015-08-04
    im not sure how to unbrick this
    i tried flashing the megatron v3 firmware to it
    and now its just a black screen on boot up
    i cant get into any recovery menu either
    any help here greatly appreciated
    on the MCU it says
    Amlogic S812 quad core
    thanks
    dave
      ok heads up guys
      my box is in fact an M8S+ or so i think
      but only has M8 printed on bottom and top
      so i used the amlogic sd formatter and used this image
      use the included u-boot.bin image to format the SDcard first or it will not work period (remember this)
      once you prep the card
      go into the archive what you downloaded and copy all files from there onto the SDcard inc the u-boot.bin file
      once ready stick it into the M8 box and hold the RESET pin down. and power up the box
      my light went from blue to read after about 8 seconds and if i let go here the box booted up with the previous bricked image (mega tron)
      so i reset again and held the RESET button till the android man was on screen
      after it rebooted it showed the amlogic boot logo with M8S+ badge
      then the screen went to an ANDROID logo, just leave it as its flashing now
      after about 7 mins my box said setting up apps to which i took out the SDcard and left it be till it booted into my fresh android OS
      job done
      couldn't of done it without help from you guys here
      hope my post helps others as ive seen you guys all having the same probs
      dave
        trying this now hope it works. its funny because on startup the screen said s802 amlogic. really an s812. crazy!! I don't know how they flashed s802 firmware on a s812.
          OMG DUDE!!!! you are a life saver. Thanks!
            I HAVE THE SAME BOX
            what do u mean that is the m8s+
            it is printed M8s
            how can i know what i have?
              @ giladsta
              I see on the sticker on the PCB that your box is S812 So that would indicate that you have the M8s
              I cant tell by looking if its a M8s or a M8s+
              M8s is
              Ethernet 10/100M
              M8s+ is
              Ethernet 100/1000M
              So if you brought the box as GB lan it should be a M8s+
              I don't own ether of them box's so sorry cant help much more
                Glad my write up is helping some of you guys
                Im just going by what firmware flashed ok and booted up fine, mine was M8S+ firmware lol
                I know its S812 as it said on the pcb and on the mcu
                Its good stable software too i think
                Ps my pic was small cos... Ive no idea lol my original pic was 800kb but when uploaded it turned into a thumbnail ?!
                Dave
                  I also have this box. Im currently doing those steps as
                  dave11674.
                  Got to the android logo keep loading. I gave it 15mins then unplug and plug it again. The box started and android logo went off very quckly and it said setting up apps.. so i took the sd card out... and the screen went black. Im doing it again and this time i will not take the sd card out. We will see...
                  Anyway i finally going somewhere with my clone box!
                  Update:
                  Android 5.1 has started on my box. The problem i have now is there is no wifi or cable internet .... what to do?
                    you could try a different firmware mate for your box
                    ive read lots trying other firmwares
                    my wifi and Enet was fine
                    dave
                      Originally posted by dave11674 View Post
                      hi guys
                      on the pcb there is
                      XT-s812-v10
                      2015-08-04
                      on the MCU it says
                      thanks
                      dave
                      [ATTACH=CONFIG]n553069[/ATTACH]
                      I loaded m8s openelec from just me website works great but the lights are wrong when its on its red when its off its blue otherwise everything works great
                        hi guys
                        on the pcb there is
                        XT-s812-v10
                        2015-08-04
                        on the MCU it says
                        thanks
                        dave
                        sorry meant to add there are plenty of unbrick procedures on this site that should work for you I think just me posted one
                          had another one in on top it said M8s
                          so i got an m8s mega tron image
                          just one on their site
                          and low n behold BRICK lol
                          my unbrick here sorted it lol
                          dave
                            hi guys
                            on the pcb there is
                            XT-s812-v10
                            2015-08-04
                            on the MCU it says
                            thanks
                            dave
                            found this firmware today https://yadi.sk/d/O9-g6-M3mKyZE it works great on the XT-s812-v10 wifi and Ethernet work great so far only issue is instead of blue light when its on its got a red light
                              The link is dead. Can you post it again ?
