p/s: I was try to press and hold the reset button but have same result, can not install anything and it still no led light (it will have blue led if I put the SD card to install the fw)
How to Unbrick Amlogic s805,s802, s812, s905 Video Tutorial
When I connect M8N with my PC (win 7) via usb cable, it show connect success on USB Buring Tool (withouth short NAND or press and hold the reset button) and when I put the SD card (after make with Bootcard Maker) then power on M8N (without press and hold the reset button), it auto install the fw from SD Card but can not success, like the picture. I was try to go to "apply update from EXT", then choose SD Card and the zip file of the firmware but still not success. What is the problem with my M8N now? Can you let me know how to unbrick it?
can you show me what file you using to load in usb burn tool?Bugs are Sons of Glitches!
JustMe
Originally posted by Code-Sniper View Postthese are the right PINS? (M8 K200) Greetz from Berlin [ATTACH=CONFIG]n557281[/ATTACH]Bugs are Sons of Glitches!
JustMe
Just me thanks for your help, all this save my ass to pay for new tv box because now i have unbrick it
But your restore rom is not made for my tv box, and now i have other rom and not the rom that i have when im buy it.
i try to mix the files from the M8_M8S_ap6330_8g2g.zip to my tv box files but dont work,
is it possible to tell me how can i install the rom of the my manufacturer?
my box coming with 5.1 lolipop and with ir remote control (this not work in your rom)
My tv box is MXIII-G (2g ram / 8g rom) 1000mbit ethernet
thanks in aadvance
madimitris try this link for your box http://freaktab.com/forum/tv-player-...net#post515227Bugs are Sons of Glitches!
JustMe
Originally posted by JustMe View Postmadimitris try this link for your box http://freaktab.com/forum/tv-player-...net#post515227
Hello. Im new to this. I have a OTT MXQ box. S805 MXQ V03. The box will not come on! When powered the red light flickers and looks like its trying to do something but doesn't. I have tried numerous times with the usb burning tool but keep getting errors at either 2% or 4%. I have also tried the toothpick method with an sd card and a usb containing the image files etc but no joy!! I am ready to launch this box in the bin but i know that i will kick myself if i cant fix this! Any help available?
Friends.
I tried to flash to my MXIII-G and my device is bricked. The led remains always red and I cannot see video.
I tried to reflash my device using AMLogic USB Burning Tools and firmwares (5.1 and 4.4.2) from China Gadget Reviews, but it did not work. It always stop at 2%, during DDR.
Download latest Android KitKat 4.4.2 stock firmware for MXIII-G Android TV Box from here or from here ....
Please, help me on identifying the firmware that I should flash. The photos from my PCB are given bellow.
Thank you in advance.You may only view thumbnails in this gallery. This gallery has 3 photos.3 Photos
Yesterday i received MXIII-G 2/16GB. The PCB is M82G V2.1 S812/2GB/16GB/AP6330
After an hour of working, i switched of the device and inserted an sdcard from my previous device. I turned it on and it stopped working. Afte i removed the sdcard the device has stopped working, and only the red light is shown.
I tried both wqys of firmware installation, bootcard and usb-otg. The device is recognized from my pc but i get an error at 2%
With the bootcard i see nothing on my TV and only red light.
Any help?
Originally posted by nasosal View PostYesterday i received MXIII-G 2/16GB. The PCB is M82G V2.1 S812/2GB/16GB/AP6330
Any help?
Hi
Happens to me as well:-(
And these methods have not resolved.
Same error
29 and 30 pins have joined the nand flash?
Originally posted by Busty290 View Post
Hi
Same error
Have you tried 29 and 30 pins? What has happened?
Here are images of my PCB. Do we have the same PCB?
Drop box folder containing larger images:
If you have access to a prolific serial adaptor try connecting to the UART port on the board, make a terminal connection and watch the log, see what/where your error lies. If your able to get to recovery then it should be fine, just need to find the correct rom. The serial port will maybe tell you more. I managed to flash my bricked M8 from the serial port
There are currently 2858 users online. 0 members and 2858 guests.
