Video > The "Guts" of 3 Quad Core TV sticks
    Originally posted by fullygeneric001 View Post
    I apologize for the confusion, and if you don't get/appreciate my humor, please don't look in the boot animation discussion thread
    Oh God..... Not the boot animation thread
    Your right I better not go look
      Thanks for your information.
      I'm currently thinking of getting one of these devices. Still after a lot of reading I can not completely decide.
      Am I correct in assuming that I could go for anyone of these, as there seems to be hardly any difference?
      The one you say shows most promising results currently (cx-919) has only 1gb ram in comparison to the others 2gb, does this not influence performance?
      Also do you already have an idea which of the devices you are going to support with custom roms? Cause I will certainly want to get one where you are providing custom roms
      edit: just saw that there actually are two versions of cx-919, one with 1gb and one with 2gb.
      also there is a tronsmart cx-919 on geekbuying that already comes with 4.2.2 preinstalled. Have you ever tried that one?
      Thanks again!
      Cheerz
        Re: Video > The "Guts" of 3 Quad Core TV sticks
        From what I've read, all devices suffer from stuttering, which basically means they can not serve their intended use.
        Hopefully that will be solved though. Eventually.
        For now just get the one with the best chips in (WiFi BT) it with regards to open source.
        Signature? Signature!
          Ok, thanks!
          Which one would you suggest considering wifi bt? The cx-919?
          Cheerz
            I have the CX 919, not tested it yet. I would recommend it from what I've read for WiFi range and easy access to reset button.
            I'd probably buy a QX1 today.
