That is you need to test it.
I know what needs to be done but cannot test it myself.
So if you want to help, let me know and sign up here.
Requirement!
I will put up test ROMs that will use the AML flash tool not SDcard updates. It makes it easier and faster to turn around updates.
When it's complete I will make the final port a SDcard.
So you WILL as a tester need to be able to use the AML flash tool and erase the system (your data).
