Porting my Finless 1.0 ROM to the Meta - Beta test over - Final ROM posted
So what are the differences between the Pro and Meta?
Meta and Telos was Wifi, Bluetooth, Ethernet, memory size.
Because I do not have a Meta or Pro need to know what to port?
What doesn't work when you flash the Meta ROM on the Pro?
It will take me about 30 minutes to build a test ROM for the Pro.
Will you be here that long to test?
ROM is building now. I should have it up and ready for you to test in about 20 more minutes.
I have flashed both the Meta and Pro stock ROMs on my Telos with no brick. Just some things won't work right.
Stay tuned.
I will make a new post for porting rather than mix up feedback between Meta and Pro.
S95 Pro test ROM posted in new thread. Go test!
OK the S95 BETA ROM testing is over....
I will be posting a final ROM in about 30 minutes or so.
It will have
Root out of the box
Fixed some permissions I missed in the BETA ROM.
Fixed init.d support as it was not working.
Fixed the logo's, build.prop settings for the Meta
Finally!
I think I fixed the boot lock ups! I have not had one now in a while!
It appears to be the FOTA APKs that Tronsmart implemented!!!! They are forcing a OTA check and as you know when there is a new OTA it forces you to install it. It does not give you a choice. It appears that sometimes on boot, the FOTA APP tries to access Wifi or Ethernet before the stacks are ready. This seems to cause a lock up.
So I removed those in my ROM since you cannot OTA from my ROM anyway...
But you folks let me know if it solves the boot lockups e.g. the mouse and keyboard do not work...
Stay tuned.... final 1.0 ROM for the Meta will be up soon.
At the bottom of all my posts is a donate button. Click it to donate from Paypal.
Thanks!
There are currently 1893 users online. 0 members and 1893 guests.
