Trying to resolve the low memory issue with my ROM that is not seen on the stock ROM for the Pro model.
_______________________________________
OK with the experience I got from porting my Finless 1.0 ROM for the Telos to the Meta and having success......
Now we try the S95 Pro.
This is a BETA test ROM!
After testing I will try to fix anything that isn't working and make a final ROM.
Note this TEST ROM is not rooted! The final will be rooted!
The boot screen says Meta not Pro and I will fix that in final ROM too. Do not be worried it says Meta!
Also you must flash this ROM with the USB burning tool.
Please test:
Wifi
Ethernet
Bluetooth
Memory
Here is the link for you to test.
ROM -> S95 Pro - Finless ROM 1.0 Port Beta 2 (280 MB)
