Porting my Finless 1.0 ROM to the S95 Pro - Beta 2 test ROM
Originally posted by locki View Post
Yes I will look into free RAM. I know how to fix it. I used all the same init files for the Meta and Telos and obviously need to use the Pro init files due to the memory being smaller..
Stay tuned for another test ROM release.
By the way, what are you using to show memory so I can use the same one and see what your seeing.
Remember I do not have a Pro to work with so I cannot see the same things you do.
After doing some testing I am not seeing a memory problem between stock and my ROM.
Stock ROM after flashing and booting:
System = 325
App = 90
Free = 360
My ROM
System = 356
App = 106
Free = 330
Not much difference!
Maybe APPs you have installed or something?
Pro has small memory to begin with and people complain of running out of memory on the Pro even with stock ROM.
I left out some memory optimization the Pro had so I will add that back but I do not think this will fully solve the small memory issues.
Flash again. Have the same mistakes. Free ram 215-250 (only clear rom, no one programm install).In stock clear rom- 400 mb.) Antutu crash in 3d test(stock OK 36500). Games have lags whis 3d picturers and crash too. epic citadel mani lags (stock OK 49.9).. all other work fine. CPU in you rom work mutch better. i don know why in my box stock and you rom work whis big differense ? May be problem in my box? Then why stock work fine whisout lags?
It must be because my box is a Telos....
I will add back some things I left out that the Pro had defined.
Stay tuned.
OK ROM updated to Beta 2!
Let me know if it resolves the low memory issue.
ROM -> S95 Pro - Finless ROM 1.0 Port Beta 2 (280 MB)
Beta 2 seems faster, more free ram perhaps. In beta 1 I had a problem with the volume going down by itself, now it's gone. Thank you very much for your efforts. This rom will keep me going until Amlogic releases the x64 sdk witch, like on pc environment, on android is more faster and constant in performance. Please create a zip installation file if possible, maybe for final release.
So I just received a few of the S95 Pros (not by choice but it is what I have) and found this thread on the Beta 2 version. Does testing still need to be done and if so is there any way I can help? Or is there a final version of the ROM for these units and I am just not seeing it? Thanks in advance
There are currently 3554 users online. 0 members and 3554 guests.
