NEW - Finless 1.0 ROM for S95 Meta - Final!
Originally posted by TurboMan View Posthi Bob,if i want to go to Original Stock Rom how do i install it thanks
To answer your question TurboMan... Here is what i did to revert.
1. Get a male to male usb.
2. Use your PC and Use usb burning tool software...steps can be found in http://freaktab.com/forum/tv-player-...smart-vega-s95
3. After that make sure box is not connected to internet and you will want to root the box because tronsmart will force auto update to their latest version.
Originally posted by gggg602 View Post
I just reverted back to stock rom to test out hdmi 2 issue i was having. The sock rom did fix the issue. Bob, not sure if you can see any differences between stock rom and your rom for hdmi 2 compatibility?
Thanks mate I'm going to try that 👍
I changed nothing with HDMI detection so something else is going on. What stock ROM did you flash back to?
Build - p200_2G-201511280456
Gary
Originally posted by TurboMan View PostI can't flash the stock rom at all it says failed 😔
Did you go the PC route? Which version are you currently on? Flashing with SD card won't work. Also if you did pc route, in the instructions. I believe it says that you need to copy some license file to a certain folder. Did you do that? If that didn't work, try downloading stock rom from tronsmart site amd use the license key from there. See link...http://forum.tronsmart.com/forum/veg...5#.VtUPy4VlDqA
Originally posted by TurboMan View Postnot copy any licences at all i just add this file Vega S95_Meta_151128.img and it failed and i did with usb to usb on my pc,hmm i cant see any license file in there mate
Finless, please help! I have two M8 s802 boxes that are not seeing any access points or networks. When the MBox settings open it gets stuck when I check wifi because it is not finding any networks. Please help. I have tried so many different ROMs and I have reset the box with the USB Burn Tool. Still nothing will start the wireless card in order to find a network to connect to. Thanks
Hi Bob, Thank you for the great job, I really love it and it just make my life better.
Due to almost everything is fine, so I just made a bug and ideas report.
1. #Clipborad# / Copied text cannot be pasted, the popup "Paste" button simply not working when you long press in text field.
2. #AndroidTVRemote# / Google has released two remote app, which could control AndroidTV devices through other android phones or tablets etc.,
They are:
"Google TV Remote" com.google.android.apps.tvremote Google INC.
"Remote Control" com.google.android.tv.remote Google INC.
Unfortunately, they are both not working on S95s, at less mine. I guess maybe there is a platform missing or something else I couldn't understand.
3.#MXPLUS_IR# / I also have a MX PLUS with 2GB memory and dualband wireless, I flashed it into a S95 META, yes it works like a charm except when I long press a key on the IR remote for about 5 seconds, the unit goes off and stay power down. I think this problem won't be widely because original S95s ship with a RF remote instead of IR ones with MX PLUS.
and again, Thank you Bob.
Hi Bob I am trying to use my TV provider app to allow me to watch my service on other devices. I downloaded it and can't get it to open just getting a blank screen. No message saying it won't open or error. The app is "eir vision go" on playstore is there a possible solution to this please and thanks.You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by saor11 View PostHi Bob I am trying to use my TV provider app to allow me to watch my service on other devices. I downloaded it and can't get it to open just getting a blank screen. No message saying it won't open or error. The app is "eir vision go" on playstore is there a possible solution to this please and thanks.
This is the player video of Google
goog luck
There are currently 2106 users online. 0 members and 2106 guests.
