NEW - Finless 1.0 ROM for S95 Meta - Final!
    Originally posted by nicolas90340 View Post
    hello i have a same pb and with install this apk ​all it's ok
    This is the player video of Google
    goog luck
    Thanks but problem still there
      Originally posted by saor11 View Post
      Hi bob
      Thanks for the rom work will send some beer money in pay day. Just some points on the rom.
      1. Am using a mele f10 pro remote which has a speaker and just like the Vega s89 no sound on TV unless I use sound about app to route audio to TV. Can this be fixed like it was on that box.?
      2. This I would not call a problem ,but I notice on start up the first 30 sec video image is like just under SD quality and then automatically switches to a HD quality. Seen this on kodi and YouTube.my TV is 720 60hz and box is set like wise.
      Hi. I also have the f10 pro.
      I just remove the output lines from the usb section in /system/etc/audio_policy.conf and then reboot.
      Rom works great btw.
      Thanks Finless
        Just a couple of questions on the Finless Rom for the meta tv box.
        I know instructions have been posted on how to install the new rom, but I wondered if it can be done the same way as installing either the stock rom or Remix rom, by using a male to male usb lead from computer to tv box.
        Presently I have the Remix OS 2.0 rom installed on my meta box but there is no support for 3rd party launchers. Can a 3rd party launcher be used with the Finless rom.
          Hello, Welcome to Freaktab. Regarding launchers, if you are referring to his Android ROM, the answer is yes. However, If you are referring to his Remix OS ROM, the answer is no.
          I think you will need to flash his ROMs with the SD method.
            Yes I ws referring to the Finless rom for my meta box. So you reckon its best to flash it with an sd card method rather than using the method I used for the Remix rom.
            I found out that every launcher I tried, about 4/5, would not run due to no support for them with Remix OS.
            Now as I have the Remix OS on my tv box I don't have the Update&Backup APP as per No.4 in the Install Instructions. Would I have to put back the stock image for the meta box first, as I hope not, unless there is no other way of getting the Finless rom on.
              Hey I have one of these boxes, I run a 3.5mm output through usb. This doesn't allow changing of volume through the android os, either higher or lower. The animations show it going up and down but it doesn't modify the sound output, anyway you could throw that in your next rom to allow it to change the output over usb?
                x306xcptnkirk, do you have the Finless rom loaded onto your box? Also did you do it according to the instructions given. I am going to try it by usb to usb connection on my pc and flash the box that way.
                  OK the BETA test ROM is over for porting my Finless 1.0 Telos ROM to the S95 Meta.
                  Thanks to those that tested it!
                  10) Fixed the problem of background APPs closing.
                  Enjoy,
                  Hey. Thank you for your work. Today I run it on the Beelink M18. Seems not have an official version from you but only a porting from this build.
                  This Rom is very interesting for me and very fast.
                  It works fine and I restored the upper taskbar.
                  I work on a project of car PC based on Android TV box (M18). I would like if you can help me on:
                  - How did you solved the background Apps closing (it's a general issue on Android TV rom)
                  - Is it possible to include the resistive touchscreen driver in the rom: http://www.eeti.com.tw/drivers_android.html
                  - Lot of people are using MELE F10 Pro remote but some features as the microphone is not recognize properly. Is it possible to get a better support of the microphone on the Finless rom?
                  Thanks!
                    Finless,
                    Since your work seems so highly thought of I thought I would ask a question.
                    Was wondering if this ROM would work on a MXQ Pro + which has the following hardware:
                    Same CPU and GPU 2G RAM
                    SAMSUNG KLMAG2GEAC-B002
                    -16 GB eMMC flash memory
                    AP6330
                    -Bluetooth/FM/Wifi (Dual Band)
                    MA8601
                    -USB 2.0 High Speed 4-port hub controller
                    ES7154
                    -14-pin stereo digital to analog converter
                    RTL8211F
                    -Integrated 10/100/1000 Gigabit Ethernet Transceiver
                    It's currently running a Meta FW modded by SD-Robot http://www.mediafire.com/download/0i...BTronsmart.rar but it has some problems.such as
                    the mouse overshooting and being difficult to control, SPDIF not working and slow WiFi.
                    Are you planning to release a newer version of your ROM after Tronsmart releases their new ROM for the Meta in the near future?
                      HI Bob, I need help, my box was installed with LibreElec, working fine for a while, but I did an upgrade but using incorrect tree, hence my box will not display on TV, but the box STILL show a blue power light. My question is, is it possible to use you ROM to reinstall to Android or revive my META, or any suggestions will greatly be appreciated
                      Thanks for you supports
                        Thanks very much for the ez root zip, I donated a month or so ago as a thank you. Am I to understand that this rom works on the U1? And will it work on other S95 boxes? Fairly new to this, figuring it out as I go.
                          Hi mates,can i flash my Vega s95 with this rom?Thanks in advance and cheers
                            Mates,please advice....thanks...
                              No need for two post, someone will answer when and if they can. Older boxes have smaller user bases, this can increase time before you get an answer.
                              ​​​​​​This ROM is ancient. What model of S95 do you have?
                                Hello mate,thank you very much endeed.My device is Vega s95_Telos....
