New - RemixOS - S95 Telos - Finless style :)
    Hello Bob, From Remix OS, adb reboot recovery won't get you to recovery. That is strange. I assume you are running your Remix OS with root. Does this matter? If rooted, what if SU reboot recovery? So if I put the EZ's recovery.img and an update file on the root of an SD card, would this work? Would you want to see the logs from my attempts?
    I am certain you realize from my posts, that I don't really know what I am doing.
    Thanks and good day.
      I have not had time to play with it further but will again soon.
      It's possibly because of my rooted version being installed.
        i am assuming there is no fastboot option on this like with nexus devices to be able to boot a temp recovery, any way we are able to flash your recovery used with ezroot.zip as an update.zip in the remix os recovery?
          Not a fast boot but similar. On boot for recovery, if it sees a recovery.img on SDcard it will boot that. If not it boots recovery from EMMC.
            So i am trying to flash back to android using the usb burning tool, getting the device to show up in the tool but as soon as i add the .img from the latest and december stock tronsmart firmware it shows mac 0 and hitting start results in a Get key failed error, any tips??
              never mind solved it extracted the license.rar all is working now so far so good
                NOTE: This ROM is only for the Telos, so if you try it on your Meta, you do so at your own risk.
                I loaded this ROM on the Meta. All seems well. Though as expected, no WiFi/BT. Otherwise, seems to run very well, Eth works fine.
                Nice work Bob.
                I also loaded the Ugoos AM1 Lollipop F/W. The WiFi/BT did not work in that F/W either...as expected. Click image for larger version
                Last edited by RISCy Dude; 22 February 2016, 05:27. Reason: Edited to correct my statement on WiFi/BT ref. AM1 F/W on S95 Meta. My original statement was in error. My apologies.
                  Heh, no risk, no Dude or what?
                  I have an AM1, nice Firmware.
                  JD
                    HeHe! Nothing ventured, nothing gained. After seeing the teardown of the AM1 at CNX, I felt the risk was low. The AM1 and Telos look virtually identical. The pre-production unit they had even had the SATA connector on the board, though it was not accessible thru the case. Otherwise both are 2GB/16GB w/AP6335.
                    I guess the S95's Remix or Bob's Remix ROM would run fine on the AM1.
                    Have fun!
                      RISCy..... want a Finless style RemixOS ROM for the Meta?
                        If he wont I will
                        But I think he will
                        Cheers
                          OK will do it tomorrow.
                            Yes Bob, I would like a Meta version. While your Telos Remix runs fine on the Meta, having BT and WiFi would be outstanding.
                              Sorry got hung up... Will work on it this week.
                                Thanks for making the RemixOS Rom, I just got my Telos and flashed it with this rooted Rom I have a couple of issues if you can help.
                                1. if i set the resolution to 1080p 60hz and set the screen to fill the screen then shutdown and restart it reverts back to defaults and my set resolution is lost and i have to reset again is there a fix for this.
                                2. i removed vidon and installed kodi jarvis release version and noticed from a plugged in USB mouse right click does not work but i know the mouse works fine else where just not on this and i have tried another same result.
                                Thanks for listening
