Beelink X2 blocked on the second screen
    Hi everybody
    I'm sorry for my english, I come from Italy.
    3 days ago I received the Beelink X2 bought on Gearbest.com.
    Yesterday I tried to turn it on but after showed Google image it goes on MBOX and doesn't go forward.
    Do you advice me to try with a firmware reset?
    thanks
    If it's failing to boot properly, you have 2 options;
    Return it to gearbest - quite difficult
    Re-flash it and see if that fixes it- might make it impossible to return
    If you can flash it the custom rom Sc v1.2 is very good.
      hi all, any solution to the box hanging at the 1st or 2nd logo pls?
