OTT M8 S802 V2 Bricked [Err]--[0x10105002]Romcode/Initialize DDR/Read initialize status/USB Control setup error
    Hey Guys im New here.
    I got an M8 Box form Ott. I got it "Bricked" from a frend.
    The problem is i got no image over HDMI also not over A/V.
    If i plug the power or OTG USB the box turnd ON (blue light turns on)
    and i can change the color in to red.
    (i try that all after the How to´s)
    So i try to unbricked via the BurnCard no success.
    Than i try the USB Burning Tool.
    I got success connect but after 2% i got this error.
    So i try diffrent PC´s with diffrent Windows on it diffrent USB Cabel´s and diffrent USB Ports.
    Everytime the same error.
    so can somebody help me please?
    Hello,
    Try the Rom for the Probox2 EX the Firmware you find here --> http://probox2.com/?wpdmdl=970
    Download the Flash Tool here --> http://probox2.com/wp-content/upload...grade-tool.zip
    Also Download Mobrobo and install it for the Driver --> ​http://download.moborobo.com/downloa..._official).exe
    When you do all this then try again to Flash the Box.
    Regards
    Neomode
      Hey i install Moborobo and deinstall the driver that comes with the burning tool.
      Now it founds no driver for the box.
      do you have a solution for that?
        Then Install the Driver from Flash Tool, after this it should Work for you.
        Neomode
          still no success
