MX4 RK3229 Bluetooth 4K Kodi Preinstalled TV Box Android 4.4 Dolby DTS 1G/8G H.264/H.265 10Bit 3D Media Player
someone dropped one of these off and they messed up the software after a hour out of the box , so i am wondering if anyone done a backup of the software of one of these .
looking for a copy to reload this one
all i get is the android logo . if you hit the reset button all you get is the android guy on his back with a x
thanks
troy
This native firmware MX4 https://yadi.sk/d/O-DejWwhr2t9s a program for the SD card installation https://yadi.sk/d/TWG4MkU2r2tF7
Got one from gearbest, couldn't resist the price. First thing I did was remove the kodi 15 that was pre-installed and installed Kodi 16.1. I don't know if that was a mistake or not but video playback is absolutely horrible. Glitching and out of sync like crazy. The only video I've seen play half decent was on the youtube app. Seemed to play games half decent, asphalt 8 was very playable. Processor runs very cool, the little heatsink was 21C after 30 min. The ram chips were about 37C. There was a strange piece of metal on the top inside of the case that connected to nothing, not even a thermal bond to anything, not that it needs it.
Wonderful device from Gearbest in US$ 22.. Outstanding image and speed, bluetooth, ethernet, lots of ports.
It requires lots of patience and some knowledge in this type of devices. I own a Beelink X2, another beauty.
Firmware version I receive V05 comes with Recovery partition crippled, not accesible in any way.
To access it, it's needed to press a very singular reset button, INSIDE of AV plug ¡very nice!
That doesn't work in my TV BOX. so the simple task of upgrading, (update.img in root of SD card), doesn't succeeded.
So I needed to flash the new version V06 using RKTools, V06 has recovery ok.
The device comes rooted, great, but it's needed to install SuperUser manager from Play Store.
A guy from Russia, bynevsky from 4PDA, have managed to release a TWRP module that work fine. Very tricky installation tho.
update.img cannot be flashed with TWRP.
The device is outstanding for the price.
It has a minor drawback, doesn't have buttons, and power from remote control put the device in standby.
So to power it off ... the old trick of unplug the AC powerLast edited by DaremoS; 03 September 2016, 23:43."Rock more than music it's a way of living"
Tablet RK2918 - Yifang M900HC 8" JB 4.2.2 Oma
Tablet RK3026 - Yifang M7100KLD 7" JB 4.2.2
Tablet RK3066 - Yifang M7000 7" JB 4.2.2
Tablet AML8726-MXS - Yifang M7000NBD 7" - JB 4.1.1
Phablet Samsung Note 3 - KK 4.4.2
Cell Phone Samsung GT-S5760M - JB 4.0.3
Originally posted by nimm View PostThis new firmware MX4 5.1.1 https://drive.google.com/open?id=0B_...DF3Y0NGWDdxaWc
Update over SD card also does not work.
Originally posted by sitoko View Post
Has anyone tried this? I can't seem to get my pc to recognize the box with an USB-A to USB-A cable (Drivers from Driver Assistant 4.1.1).
According with Antutu
EKB329-MX4 - Android 4.4.4 - 20827
Redbean RT-165 - Android 5.1.1 - 24219
This is the new name for the device. It's a brand from Singapore.
It come without KODI then it's needed to install it. I've installed Kodi 16.2 and work great ... is the principal use I give to the TV BOX.
The only drawback I've noticed is that Chrome is not working well, so I'm using Explorer which is very fast.
Many problems like external keyboard are solved. ...
Happy as a dog with a mamut bone!!!
------------- in production --------------
System work better and look better, but it's still in development, so there is some bugs.
So for novices I suggesat to stay in KitKat 4.4.4 the original that comes with the device, less inconsistencies.
For fun and better response in video goto Lollipop 5.1.1 this firmware above, requires some knowledge and patienceLast edited by DaremoS; 08 September 2016, 02:40."Rock more than music it's a way of living"
Hi there, I have an MX4 V10 (according to the board) Rk3229 Android TV player. I was having a problem with some apps not being able to update themselves using the ethernet port (no wifi or bluetooth on this box). The supplier suggested i do a factory reset which I did but it didn't change anything. Then they suggested I try an updated firmware. I downloaded that firmware, and installed via SD card. whether or not that was correct I still don't know. Anyway, the device picked up the update and proceeded to do its thing. It asked to reboot and it never came back on. When I plug it in I have a solid blue LED with no signal.
I have checked around the net, but I can't seem to find anything that will help me fix this thing. I can find other stock roms but nothing that concretely says its for my device and I'm worried that I mess it up further. Could anyone just point me in the right direction, which firmware I need to use and a link to basic guide of installing it.
I would appreciate the help.
Thank you
UPDATE: The chip i see on mine is SKhynixLast edited by Vitosal; 21 February 2017, 14:53.
There are currently 3062 users online. 0 members and 3062 guests.
