NEXBOX Z68 RK3368 Android 5.1 4K UHD TV BOX 2G/16G 2.4G/5G Dual Band WIFI Gigabit LAN Bluetooth4.0 KODI HDMI H.265
    Due to a technical error...ME..I deleted the thread so....will start again
    Sorry for those who had a a few post.
    Android 5.1
    Rockchip R3368 Octa Core up to 1.6GHz (Cortex-A53 64bit)
    High performance GPU,support OpenGL ES3.1,OpenCL 1.2 and DirectX 9.3
    DDR3 2G
    Onboard eMMC Flash 16GB
    2.4G /5G WiFi
    10/100/1000M LAN
    4Kx2K & FHD 1080P@60fps video output
    Nexbox Z68
    This arrived today and looks neat lets rip into it see what its made of
    AU power supply always good to have 5/3 amps.
    Groovy looking remote easy to find.
    HDMI Cable
    Nice and easy to see all components used
    Quality heat sink that is NOT..deal with that later
    Another view of the Ports
    Nothing much under here
    Quality Antenna that does appear to work well in my setup ok, 3m from router
    Distance maybe a problem, test that later
    First boot OK, setup WiFi, 5 Ghz speed looks good tested ethernet also OK
    Setup Google a bit of junk installed that I don't use, no option to uninstall these apps Hmm. open or update.
    Temp reading 2c only another Hmm,
    I think the firmware is a little sick as I type this...I see the the blokes in other thread doing a number on a Rom may give that a go soon, real soon
    The box seems snappy enough with this setup, I see a new Rom on BlogGeekbuying might try that first
    Piled a lot of apps to update and install and it seemed to cope.
    Bit of a fiddle then we will go Rom hunting.
    Oh Very Poor heat sink if you can call it that bit of Tin with some sticky stuff, I have a low profile heat sink and some arctic glue mod time.
    More to Come.
    Cheers
      Bit more of a fiddle this day, first challenge was getting RKbatchtool and drivers to be happy in win10 64bit thanks to those that helped in that.
      I reburnt the Rom found on geekbuying blog, and its the same that is on the box, so no improvement.
      Flashed the rom from cyber7 thread, no WIFI, many random resets and restarts so still a wip will monitor this more.
      Back to original, let it load up did and update and removed some of the Junk, appears they have made all apps installed as part of the system, cant unistall anything the normal way, a bit of creative root management removed apps not required.
      The box is ok at the present does the job, more testing to come with Kodi and other bits I find useful and play with a few other roms that may be compatible .
      Temperature reading locked on 2c something wrong in that dept
      More to come
        I have been clocking more than 14 hours on my current Z64 (in the stock Kodi that came with the latest firmware) running Clint Eastwood's movies (720p) no problems, no crashes.
        i think that either (1)you installed something interfering with your box or (2)you have a faulty box. If (1)restart from scratch, if (2)return the box...
        kind regards
        cyber7 (aka Aubrey Kloppers; Cape Town; South Africa)
        http://www.cyber7.co.za / http://aubreykloppers.wordpress.com
          Was a fresh flash and twice of the mentioned ROM, not sure, had no chance to do much went a bit ape so back to the start.
          Was wifi working ap6330 working on this rom.
          Now just testing the rom that comes with it to see if it has any hope at working, lots of time to fiddle.
          It may well be a faulty unit back to basics for testing.
          Cheers
            Please could we move this discussion into the thread I am working in? Very difficult to jump forwards and backwards...
            ps - Could you open a "NexBOX Z68" section to start bundling the threads together?
            kind regards
            ps - I am busy building a stripped down release on the second Firmware, so look out for that
            kind regards
              Further testing with Nexbox Z68, Kodi is ok, 1080p 720 Smooth enough.
              Netflix there is an Sync problem with Audio at present seen it on other 3368 boxes.
              Guess I will wait for a bit work on the Rom and hope they can clean it up. I will also have tinker with other roms that are been worked on around the place. to see hoe they cut it. I feel the basic rom should be able to do the job with an update or 10 :-)
              Cheers
                The Numbers
                More information from Geekbench
                  Trebor what ROM are you using now. Its pretty good score?
                    Using cyber7 debloated at the moment this box should be able to do good with a basic rom, with no bloat, it's not 100% yet, but it's 101% better than it was
                    Cheers
                      Cheers
                      Thank you trebor ! You made my day
                      kind regards
                        27861 is very good score.... Almost par to the branded boxes... thanks cyber7 for your great work
                          Nexbox Z68
                          New Firmware Blog.Geekbuying
                            Nexbox Z68
                            Hi trebor, did you tested it out on the new Rom, how is it working so far?
                              Just wondering for those that bought this box from Geekbuying. Just recently noticed that when i go to Memory, it shows 2 instances of 7.99 GB, both with 1.99 GB used. Is this correct? It is supposed to be a 16GB box, but wondered if I got something different?
