NEXBOX Z68 RK3368 Android 5.1 4K UHD TV BOX 2G/16G 2.4G/5G Dual Band WIFI Gigabit LAN Bluetooth4.0 KODI HDMI H.265
    Originally posted by jmatteis View Post
    Just wondering for those that bought this box from Geekbuying. Just recently noticed that when i go to Memory, it shows 2 instances of 7.99 GB, both with 1.99 GB used. Is this correct? It is supposed to be a 16GB box, but wondered if I got something different?
    There is internal storage that consists of user and userdata.
    On the userdata partition you can install apps, on user you can copy normal files.
    Then the Android OS also uses about 1-2GB storage.
    And the 16GB is rounded off, so it might only be 15-15.5 GB real storage, there are apps to check this.
    On Amlogic tv boxes there is for instance only 1.7GB real RAM instead of 2GB.
    This is not a issue on Rockchip devices as there are real 1.99GB RAM.
