Launcher - Let's see yours!
    Hi Guys
    I thought that since this is becoming a very nice box in it's own, that we need some kind of launcher showcase. How about yours?
    Let's keep this on-topic and for the help of all in the community, give some kind of description of what and how you got your Launcher as it is...
    cyber7-out
    kind regards
    cyber7 (aka Aubrey Kloppers; Cape Town; South Africa)
    http://www.cyber7.co.za / http://aubreykloppers.wordpress.com
    using xh home tv apk now
      Square home tablet launcher or Google now launcher. Both on the play store.
        Jadootv Launcher is also very good. But I couldn't install it on my MK808b Plus stick because I don't know how to modify. But It was easy to extract the app.. try it if it can be of any use....
        https://mega.nz/#!DtsWWSaR Decrypt Key: !5WXZT5sDN-eLJGEffMTtf2iNCojkb9JPsX7qUJhEkYA
          Here is mine.
          Specifications:
          • Square Home 2
          • Miui v5 Icons
          • RSS Widget
          • Weather Live
          kind regards
            This looks good. Is this the one you included in you latest Build?
              Ohh damn Square Home 2 looks sexy....gota check that out tonight.
                One thing i like about square home is you can back up and give your setup up to others to try. Hes got a new version out i havent had time to try it. I payed the 3 or 4 bucks for full version does everything i need.
                  I have tried it on nexbox z68 rk3368 based and the apk installs, but when u launch it a message says the device is not supported and closes.
                  Any clue to install it on z68?
                  Thanks.
                    izwfkv I don't know how to modify it so I was unable to install it. There is a file in side the compressed .apk that need to be modified to get it installed on a different box other than Jadootv..
                      Specifications:
                      • Square Home 2
                      • DCikonZ icons.
                      • RSS Widget
                      • Weather Live
                      • System Monitor 1.5
                      • One Key Boost - Memory Cleaner
                      kind regards
                        cyber welcome back. This one also looks good...
                        Can you make a backup of your launcher and post it here?
                          grok - I am busy creating a bit of a "generic" Firmware with all the utilities injected. Hopefully I can complete later today
                          ps - It does take some time to build, dump, load and test full backups, so stay tuned
                          kind regards
                            @cyber7: Many thanks, Already we are waiting for your new firmware.
                              For those that know how to tweak or create Launchers, home screens etc... someone mentioned earlier about modifying a file within an installation for each individual box... I am looking for a simple launcher interface without too much tweaking that i can simply load and set up for an older family member, something like the MXQ launchers or this...
