[ROM] Superceleron V1.0 Custom Rom OTT MXQ (G9C)
    Hi there guys and girls, my new rom for this device i have done for 1 month now, but i was been really busy so only now i could finish it!
    I'm going to try to remember everything i made to it!
    I hope you enjoy it
    Changelog v1.0:
    • Build from the source.
    • Custom Kernel.
    • Proper rooted.
    • Twrp recovery. (thks abdul_pt/me)
    • Custom Kodi 16.1 RC2 Build.
    • initd.d support.
    • Debloated.
    • Xbox 360 cable and wireless support.
    • Network tweaks.
    • Permissions fixed.
    • Xposed Framework added and fully working.
    • Removed non working OTA.
    • Sleep working, full poweroff also working.
    • Google core framework updated.
    • Media reported free space fixed.
    • And other fixes i just cant remember!
    Download:
    Install instructions:
    • 1) Download this ROM (SC_v1.0_OTT_MXQs905.zip). DO NOT unzip it!
    • 2) Copy the zip to a SDcard. Make sure it is a good SDcard and not corrupt. If your not sure, format it FAT32.
    • 3) Make sure you do NOT have a recovery.img on SDcard that you used for something else. This ZIP is properly signed for the OTT MXQ recovery in the box now.
    • 4) Go into APPs and run the Update&Backup APP.
    • 5) On the right side under "Local Update", click the select button.
    • 6) It should open a list of ZIP files on your SDcard. Select SC_v1.0_OTT_MXQs905.zip.
    • 7) Now click the update button.
    • 8) The system will reboot into Recovery but will not show any menus.
    • 9) The green Android man will show up and update the ROM. Do not do anything until it is finished!
    • 10) The system will reboot on it's own and boot the new ROM.
    1ยบ BOOT TAKES AROUND 6 MINUTES!
    THIS ROM DELETES ALL YOUR DATA SO DO A BACKUP!
    USE AT YOUR OWN RISK!
    Enjoy it!
    Looks great, I'll be testing this at the weekend while I continue to work on my ROM :-)
      I hope you enjoy it
      Changelog v1.0:
      • Custom Kernel.
      • Proper rooted.
      • initd.d support.
      • Debloated.
      • Network tweaks.
      good, we will test it on acemax G9C model
        Hy Superceleron,
        Could you maybe modded this ROM to work proper in beelink mini mx?
          Originally posted by envagyok View Post
          Hy Superceleron,
          If i get a test box, yes! is the mini mx wifi chip the ap62xx?
            It does have WiFi Chip AP6212.
              Ok thks! Maybe i will check it when i have time!
                Hi, i flashed your rom. My box says OTT MXQ but not G9C and now my wifi and remote don't work anymore and i have no idea where to find the original rom.. I have the MXQ pro with red 4k text. And its a p200 type. Mine also doesnt have bluetooth. Can you help me finding a working rom?
                  Never flash a rom if you don't have the stock one in hand!
                  And that is why i added the model to the title... so no one flash by mistake the rom!
                  Make a new post here asking if anyone knows a rom for you box. give all information you can on the post!
                    Yes.
                    this ROM support change refresh rate, and hd audio passtrough with kodi?
                    I heard amlogic has a SDK what support it, but Chinese manufacturers isn't support in their firmwares.
                      if your box is G9C, you can have the G9C software from our website
                      www.acemax.net.cn downloading center
                        Tested yesterday on a MxQ g9c and works perfect... thanks, resolved the xbox 360 cable issue.
                          My box is D16
                          Wifi chipset is RTL8189ES
                          Any custom rom for it..Thanks in advance..
                            First I would like to say : "thank you very much for this nice ROM".
                            I use this rom for a while now and it runs fine, except for the non working ethernet/wifi due to the wrong hardware version (OTT - MXQ PRO - p200).
                            Is it possible to make it work in this or maybe a future Superceleron ROM.
                            For now I use an USB ethernet adapter so it is very workable but it would be nice to use the onboard LAN/Wifi.
                            I hope to hear from you.
                            Thanks in advance.
                              This looks great, but I also have the MXQ Pro. I do have a spare ethernet->USB adapter and I am tempted to switch to this to solve my idle-hang issue
