No, not at all. Simply asking a question if it was possible. Very happy to keep the original logo, but as I like to mod ROMS it would of been interesting to know how it works. Anywho, thanks again Superceleron for the ROM!
[ROM] Superceleron V1.0 Custom Rom OTT MXQ (G9C)
Dunno, i dind't test it because i dont have how to test it!
This is the menu I'm looking for: I've seen it on several KitKat-based TV boxes, but I'm wondering if Google just removed the functionality altogether with Lollipop.
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by BENETNATH View PostHi,
are there any Beelink mini mx II users of this rom ? can you confirm wheter the DTS passthrough is perfectly working or not ?
thanks for your efforts superceleron ^^
i tried, same issues, no sound in Kodi except if i'm in stereo.
Mx player is fine on dts
I would like to test this firmware, but could someone just confirm, that this is for MXQ Pro 4K S905?
Hardware Info gives the following information:
AMLOGIC MXQPRO
SYSTEM (Android 5.1.1)
Model: MXQPRO
Manufacturer: amlogic
Device: p201T
Product: p201T
Brand: Android
Android Version: 5.1.1 (Lollipop)
API Level: 22
Build ID: LMY47V
Fingerprint: Android/p201T/p201T:5.1.1/LMY47V/20160308:user/test-keys
And the device looks like the one I uploaded here.
Thanks in advancedYou may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by CannaBioD View PostFinally it works, this is what I did :
* First I have flashed : SC_v.1.0_OTT_MXQs905.zip from the Android "UPDATE&BACKUP / Select update".
* Second I've flashed p200-ota-201601.zip with the TWRP from the SuperCeleron Firmware.
* And finaly the toothpick method and the USB_Burning_Tool did connect and I've managed to flash the L-MXQPRO-KODI-0511 (https://docs.google.com/uc?id=0B8lZz...xport=download).
Now the latest firmware runs fine including Wi_fi and Ethernet.
I was trying to follow these directions and SC_v.1.0_OTT_MXQs905.zip flashed fine using the Update&Backup. The problem is that the first Superceleron screen is all that comes up now when I boot the box. The remote seems to have no response and my cordless usb mouse doesn't either. I can't flash any other firmware because despite the presence of the reset button in the A/V jack, it has never worked for me. Also, when I hook the box to my PC using male-to-male usb, nothing shows up in my device manager.
How do I get to the superceleron menus? Is there something simple that I am doing wrong or is my tv box toast for good?
Help me obi-wan kenobi, you're my only hope.
first, thanks so much for the quick reply!
I think I'm all set to do that but can't figure out a way to flash it. I tried making a bootable SD card, tried hooking the box up usb, tried toothpick method. No response from the box at all. It just always boots up to that first screen of superceleron rom.
so unfortunately I'm stuck and confused.
Any ideas are much appreciated!
This took a few tries to get 100%.
I decided to go with an older version of the burning tool and it worked out.
After a week or so of use, it's been a huge difference in performance as well as everything working in the play store.
Thank you for your work. My Q Box Amlogic S905,2G DDR3,16G is working night and day better.
I generally do not see a huge performance increase like this from a ROM. This was a big increase from the stock ROM.
Can't thank you enough, just what I was looking for.
Glad you like it
Originally posted by maxxtoor View Posthi superceleron,
i have the mxq pro 4k,,,
hx s905 series,,,
5.1.1 android version,,,
ddr 3gb,
16gb memory,,,
nucleo version 3.14.29 ren@gxt #1,,,
compilation number hx_s905-userdebug 5.1.1 LMY47V 20160606 test-keys,,,
bluetooht...
this firmware work whit my device?
There are currently 2135 users online. 0 members and 2135 guests.
