Help with ott tv box
As scooter said do factory default/reset via toothpick you will have all original apps that came with the firmware apart from any added apps you installed afterwards if that fail reflash with stock rom if that fails then I would be opening up teh unit and checking that the heat sink is sitted properly on the cpuBugs are Sons of Glitches!
JustMe
Originally posted by JustMe View PostAs scooter said do factory default/reset via toothpick you will have all original apps that came with the firmware apart from any added apps you installed afterwards if that fail reflash with stock rom if that fails then I would be opening up teh unit and checking that the heat sink is sitted properly on the cpu
honestly dude you will give your self far less headache if you reset it ... as said you can download kodi from play store or get it direct from kodi here - http://mirrors.kodi.tv/releases/andr...rmeabi-v7a.apk
There are currently 2334 users online. 0 members and 2334 guests.
