Running Linux From SD Card or USB Flash Drive - Using Balbes150 Method And Files.
Used first image, Armbian_5.44_S9xxx_Debian_stretch_3.14.29_icewm_20 180729.img, unpacked it with 7z to get .img file,
write it to SD card with Win32DiskImager, insert card to box, turn on the box. UART output is the same as before:
GXM:BL1:dc8b51:76f1a5;FEAT:ADFC318C:0;POC:3;RCY:0; EMMC:800;NAND:81;SD:0;READ:0;CHK:AA;USB:8;LOOP:1;E MMC:800;NAND:81;SD:0;READ:0;CHK:AA;USB:8;LOOP:2;EM MC:800;NAND:81;SD:0;READ:0;CHK:AA;USB:8;LOOP:3;EMM C:800;NAND:81;SD:0;READ:0;CHK:AA;USB:8;LOOP:4;EMMC :800;NAND:81;SD:0;READ:0;CHK:AA;USB:8;LOOP:5;EMMC: 800;NAND:81;SD:0;READ:0;CHK:AA;USB:8;LOOP:6;EMMC:8 00;NAND:81;SD:0;READ:0;CHK:AA;USB:8;
Tried with the SD card that worked before I removed the chip, UART output is the same:
USB burning tool don't recognize the box now, had to short pins before to recognize, now it's not recognizing. UART output is the same:
GXM:BL1:dc8b51:76f1a5;FEAT:ADFC318C:0;POC:3;RCY:0; EMMC:800;NAND:81;SD:800;USB:8;LOOP:1;EMMC:800;NAND :81;SD:800;USB:8;LOOP:2;EMMC:800;NAND:81;SD:800;US B:8;LOOP:3;EMMC:800;NAND:81;SD:800;USB:8;LOOP:4;EM MC:800;NAND:81;SD:800;USB:8;LOOP:5;EMMC:800;NAND:8 1;SD:800;USB:8;LOOP:6;EMMC:800;NAND:81;SD:800;USB: 8;LOOP:7;EMMC:800;NAND:81;SD:800;USB:8;
Have another SD card and tried Armbian but all the same. Tried also to shorting pins like before, but there is no chip and that not working anymore, now box won't boot at all.
Yes, but how it worked when the emmc was attached to the board?
I just needed to short pins and it would boot.
Is there any chance now to short some points and make it booting again?
Power supply is good, I measured around the DC jack and have 5.0v.
Edit:
Interesting find:
I have another broken box, Beelink GT1 Ultimate and have some files that I'm experimented with, u-boot.bin.
Tried to burn the image with Win32DiskImager and put it in this boxand get some UART readings:
GXM:BL1:dc8b51:76f1a5;FEAT:ADFC318C:0;POC:3;RCY:0; EMMC:800;NAND:81;SD:0;READ:0;0.0;CHK:0;
no sdio debug board detected
TE: 321346
BL2 Built : 11:58:42, May 27 2017.
gxl gc3c9a84 - xiaobo.gu@droid05
set vdd cpu_a to 1120 mv
set vdd cpu_b to 1050 mv
set vddee to 1000 mv
Board ID = 2
CPU clk: 1200MHz
DQS-corr enabled
DDR scramble enabled
DDR4 chl: Rank0+1 @ 816MHz
TE: 150453
So, the box see sd card but won't boot Coreelec or Armbian from it.
Maybe this helps to find what is wrong.Last edited by Nebojsa; 15 September 2018, 13:46.
Edit 2:
Found another .bin file, u-boot.bin.sd.bin for A95X (can't find u-boot.bin.sd.bin for my box, Sunvell T95V pro), made bootable sd card with Amlogic boot card maker and have uart reading:
TE: 325963
BL2 Built : 18:01:20, Feb 17 2017.
gxl ge226e8f - xiaobo.gu@droid05
Board ID = 2
CPU clk: 1200MHz
DQS-corr enabled
DDR3 chl: Rank0+1 @ 792MHz - PASS
Rank0: 1024MB(auto)-2T-11
Rank1: 1024MB(auto)-2T-11
DataBus test pass!
AddrBus test pass!
Load fip header from SD, src: 0x0000c200, des: 0x01400000, size: 0x00004000
New fip structure!
Load bl30 from SD, src: 0x00010200, des: 0x01100000, size: 0x0000d600
Load bl31 from SD, src: 0x00020200, des: 0x10100000, size: 0x00015400
Load bl33 from SD, src: 0x00038200, des: 0x01000000, size: 0x000a9e00
NOTICE: BL3-1: v1.0(debug):34b885f
NOTICE: BL3-1: Built : 15:32:22, Oct 29 2016
aml log : bl31 normal boot !
[Image: gxl_v1.1.3154-065f772 2016-09-29 14:08:54 yan.wang@droid05]
OPS=0x82
7e 91 61 3c 62 9 9f 3c df 30 8d a [0.742051 Inits done]
secure task start!
high task start!
low task start!
INFO: BL3-1: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader
ERROR: Error initializing runtime service opteed_fast
INFO: BL3-1: Preparing for EL3 exit to normal world
INFO: BL3-1: Next image address = 0x1000000
INFO: BL3-1: Next image spsr = 0x3c9
U-Boot 2015.01-g3ae4572-dirty (May 09 2017 - 15:11:16)
DRAM: 2 GiB
Relocation Offset is: 76ec9000
board_init sm1628
register usb cfg[0][1] = 0000000077f5f998
vpu: error: vpu: check dts: FDT_ERR_BADMAGIC, load default parameters
vpu: clk_level = 7
vpu: set clk: 666667000Hz, readback: 666660000Hz(0x300)
vpp: vpp_init
boot_device_flag : 1
Nand PHY Ver:1.01.001.0006 (c) 2013 Amlogic Inc.
init bus_cycle=6, bus_timing=7, system=5.0ns
reset failed
get_chip_type and ret:fffffffe
chip detect failed and ret:fffffffe
nandphy_init failed and ret=0xfffffff1
MMC: aml_priv->desc_buf = 0x0000000073ec96b0
aml_priv->desc_buf = 0x0000000073ecb9d0
SDIO Port B: 0, SDIO Port C: 1
emmc/sd response timeout, cmd8, status=0x3ff2800
emmc/sd response timeout, cmd55, status=0x3ff2800
emmc/sd response timeout, cmd1, status=0x3ff2800
MMC init failed
Using default environment
In: serial
Out: serial
Err: serial
reboot_mode=cold_boot
hpd_state=1
[1080p60hz] is invalid for cvbs.
set hdmitx VIC = 16
config HPLL = 2970
HPLL: 0xc000027b
config HPLL done
j = 4 vid_clk_div = 1
hdmitx phy setting done
hdmitx: set enc for VIC: 16
rx version is 1.4 or below div=10
hdmtix: set audio
[store]To run cmd[emmc dtb_read 0x1000000 0x40000]
read emmc dtb
mmc init failed
Amlogic multi-dtb tool
Cannot find legal dtb!
[store]Err:do_store_dtb_ops,L236:Fail in fdt check header
board_late_init(): [store dtb read $dtb_mem_addr] fail
load dtb to 1000000
[store]To run cmd[emmc dtb_read 1000000 0x40000]
read emmc dtb
mmc init failed
board_late_init(): store dtb read 1000000 fail
card in
[mmc_init] mmc init success
Device: SDIO Port B
Manufacturer ID: 3
OEM: 5344
Tran Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 7.4 GiB
mmc clock: 40000000
Bus Width: 4-bit
Net: dwmac.c9410000
wipe_data=successful
wipe_cache=successful
upgrade_step=0
[OSD]check dts: FDT_ERR_BADMAGIC, load default fb_addr parameters
[OSD]fb_addr for logo: 0x3d800000
[CANVAS]canvas init
[CANVAS]addr=0x3d800000 width=5760, height=2160
Cannot find dev.
amlmmc cmd <NULL> failed
store - STORE sub-system
Usage:
store store init flag
store read name addr off|partition size
read 'size' bytes starting at offset 'off'
to/from memory address 'addr', skipping bad blocks.
store write name addr off|partition size
write 'size' bytes starting at offset 'off'
store rom_write add off size.
write uboot to the boot device
store erase boot/data:
erase the area which is uboot or data
store erase partition <partition_name>:
erase the area which partition in u-boot
store erase dtb
store erase key
store disprotect key
store rom_protect on/off
store scrub off|partition size
scrub the area from offset and size
store dtb iread/read/write addr <size>
read/write dtb, size is optional
store key read/write addr <size>
read/write key, size is optional
cmd store failed
Err imgread(L333):Fail to read 0x2000B from part[logo] at offset 0
There is no valid bmp file at the given address
[KM]Error:f[keymanage_dts_parse]L282:not a fdt at 0x0000000001000000
gpio: pin GPIOAO_2 (gpio 102) value is 1
get_cpu_id flag_12bit=1
Hit Enter or space or Ctrl+C key to stop autoboot -- : 0
Cannot find dev.
Usage:
store erase dtb
store erase key
cmd store failed
Err imgread(L132):Fail to read 0x100000B from part[boot] at offset 0
InUsbBurn
noSof
Device: SDIO Port B
Manufacturer ID: 3
OEM: 5344
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 7.4 GiB
mmc clock: 40000000
Bus Width: 4-bit
Device: SDIO Port B
Manufacturer ID: 3
OEM: 5344
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 7.4 GiB
mmc clock: 40000000
Bus Width: 4-bit
reading aml_autoscript
** Unable to read file aml_autoscript **
reading recovery.img
** Unable to read file recovery.img **
(Re)start USB...
USB0: USB3.0 XHCI init start
Register 3000140 NbrPorts 3
Starting the controller
USB XHCI 1.00
scanning bus 0 for devices... 1 USB Device(s) found
scanning usb for storage devices... 0 Storage Device(s) found
** Bad device usb 0 **
Cannot find dev.
Usage:
store erase dtb
store erase key
cmd store failed
Err imgread(L132):Fail to read 0x100000B from part[recovery] at offset 0
gxm_q200_v1#
Then I put usb with CoreElec that worked on device before, along with inserted sd card, and got this uart reading:
TE: 326798
Board ID = 2
CPU clk: 1200MHz
DQS-corr enabled
DataBus test pass!
AddrBus test pass!
New fip structure!
OPS=0x82
7e 91 61 3c 62 9 9f 3c df 30 8d a [0.742882 Inits done]
secure task start!
high task start!
low task start!
DRAM: 2 GiB
board_init sm1628
vpu: clk_level = 7
vpp: vpp_init
reset failed
MMC init failed
In: serial
Out: serial
Err: serial
hpd_state=0
cvbs performance type = 6, table = 0
read emmc dtb
mmc init failed
load dtb to 1000000
read emmc dtb
mmc init failed
card in
Device: SDIO Port B
Manufacturer ID: 3
OEM: 5344
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 7.4 GiB
mmc clock: 40000000
Bus Width: 4-bit
Net: dwmac.c9410000
upgrade_step=0
[CANVAS]canvas init
Cannot find dev.
Usage:
store erase dtb
store erase key
cmd store failed
Cannot find dev.
Usage:
store erase dtb
store erase key
cmd store failed
InUsbBurn
noSof
Device: SDIO Port B
Manufacturer ID: 3
OEM: 5344
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 7.4 GiB
mmc clock: 40000000
Bus Width: 4-bit
Device: SDIO Port B
Manufacturer ID: 3
OEM: 5344
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 7.4 GiB
mmc clock: 40000000
Bus Width: 4-bit
(Re)start USB...
USB XHCI 1.00
scanning bus 0 for devices... 2 USB Device(s) found
scanning usb for storage devices... 1 Storage Device(s) found
1033 bytes read in 22 ms (44.9 KiB/s)
## Executing script at 01080000
Saving Environment to aml-storage...
MMC init failed
Device: SDIO Port B
Manufacturer ID: 3
OEM: 5344
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 7.4 GiB
mmc clock: 40000000
Bus Width: 4-bit
reading kernel.img
** Unable to read file kernel.img **
(Re)start USB...
USB XHCI 1.00
reading kernel.img
7821312 bytes read in 4473 ms (1.7 MiB/s)
reading dtb.img
159744 bytes read in 108 ms (1.4 MiB/s)
usb dtb.img loaded
ee_gate_off ...
## Booting Android Image at 0x01080000 ...
reloc_addr =73ee5f10
copy done
Multi dtb detected
Multi dtb tool version: v2 .
Support 4 dtbs.
aml_dt soc: gxm platform: q200 variant: 2gled
dtb 0 soc: gxb plat: p200 vari: 1g
dtb 1 soc: gxb plat: p200 vari: 2g
dtb 2 soc: gxl plat: p212 vari: 1g
dtb 3 soc: gxl plat: p212 vari: 2g
Not match any dtb.
load dtb from 0x1000000 ......
ERROR: image is not a fdt - must RESET the board to recover.
load dtb from 0x74634710 ......
Could not find a valid device tree
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
[rsvmem] fdt addr error.
Loading Ramdisk to 73ccb000, end 73eb5b92 ... OK
FDT creation failed! hanging...### ERROR ### Please RESET the board ###
Thinking, if sd card wake the device maybe it will find usb with CoreElec and boot from it, it find it but won't boot...
SUCCESS!
I found u-boot.bin.sd.bin for my box, write it to sd card with Boot card maker (not Burn card maker).
Make another usb flash drive with CoreElec from scratch, plug both sd card and usb flash to box.
Plug the power and... voila, it boots to CoreElec!
@balbes150, thanks for the help and for clarifying some things that I didn't know.
I have another question.
In this case I have to plug both sd card and usb flash for everything to work.
Is there any way to combine those two into one?
I'm Windows user and when make sd card with Boot card maker, card remains empty in Windows (looks like empty)
and cannot copy files to usb flash and make it the only device I need for boot.
Any suggestion how to do that?
Thanks.
You can use any LInux you like. Write the LE or Armbian image to the SD card. Rename the script "s905_autoscript"to " aml_autoscript". Copy to SD card need the file "u-boot.bin.sd.bin". Run Linux on your PC. Connect SD card to PC. Open the terminal. Switch to the "root" user mode with the "sudo su" command (a prompt with the "#" symbol should appear on the line). Run the command "fdisk l". Carefully examine the output of this command and find how your SD card is marked in this list. Execute two u-boot write commands on the SD card.
dd if=u-boot.bin.sd.bin of=/dev/<name of your Sd card in the system> conv=fsync bs=1 count=442
dd if=u-boot.bin.sd.bin of=/dev/<name of your Sd card in the system> conv=fsync bs=512 skip=1 seek=1
After these steps, the SD card will boot and have a working system.
Thanks, this works!
Made live usb with some small Linux distro, think Slack, wrote commands you gave me on prepared SD card with Libre and box boot just with that SD card.
Then I tried something else.
Made new SD card with CoreElec, then use Boot card maker to write u-boot.bin.sd.bin, just untick option "format".
I got bootable SD card with CoreElec, no need for Linux step.
So, everything is working now from SD card.
I tried to do the same with USB stick, but won't boot.
Think that boot device must be SD card.
I would like more if can use USB stick because I have couple of those that don't use, but never mind, it's important that works.
Thanks again.
There are currently 6219 users online. 3 members and 6216 guests.
