Running Linux From SD Card or USB Flash Drive - Using Balbes150 Method And Files.
i've a TV-Box called H96 Pro+ (or "Pro Plus") from an unknown manufacturers, the Start Sceen shows something about "MBOX", with
- CPU S912
- 3GB RAM and
- 32GB Disc Space
I've tried the "Armbian_5.27_S9xxx_Ubuntu_xenial_3.14.29_mate_KOD I_20170701" Image and some of the included dtb-Files but i haven't found the right one for me.
So i thought, it would be the best idea to extract/obtain/what ever the dtb-File from my Box.
For that, i've Access to my Box via ssh and a Android-Firmware Img-File for my Box.
I hope it's possible and not so complicated, could someone explain me how to obtain the DTB from my Box or the IMG-File?
- CPU S912
- 3GB RAM and
- 32GB Disc Space
Originally posted by balbes150 View Post
Try running without a cover "dtb.img".
- the Android-Update App restart the Box
- i see maybe 3 seconds the bootlogo of the box
- then it restart again an i see the bootlogo now up to 20 seconds
After that, the box go off and nothing more happend. And it make no difference if i wait 10 Minutes or 30.
I use a SD-Card to USB Adapter so i can see activity through its flashing LED and it flash in both cases.
When i try running Armbian without the "dtb.img" in the Root Dir it happens the following.
In this case, you need to look for the correct dtb file.
None of the available dtb-files in your Armbian-Image sounds proper for me.
I know and this was the reason why i asked, how to extract the dtb file from the runing system or the Firmware Update File/Image.
Good idea, perhaps you have the suitable link of the topic?
I havn't found it.
When you start, in the part where you ask the user and password, I choose root and I accept it but after asking me to change the password tells me
"Authentication Token manipulation Error"
I have only tried Ubuntu and Debian in a MXQ Pro 4 K (p201)
The bug is usually resolved with the following command:
Mount-0 remount,rw /
But how do I avoid being asked to login to write the command?
Hi all, I have a Sunvell T95U Pro running Arbian which it seems to be doing very well, its currently installed on a 16GB USB stick. I'm running it headless as a voip PBX. What I would like to do now is get it onto the flash. I have run the install.sh and it tries to boot from the flash but fails, looks like when its going for the root filesystem. Can anyone point me in the direction of any documentation on how to make this happen please or just any tips at all. On a regular x86 I would have no problem if I was stuck at a grub prompt etc, I would work it out but with this device I have no idea where to even begin looking.
Thanks in advance
Daz
Originally posted by Dios.ongo View PostWhen you start, in the part where you ask the user and password, I choose root and I accept it but after asking me to change the password tells me
2. The first time you need to change the password "root" in accordance with the rules of password security (not allowed simple passwords).
There are currently 4945 users online. 0 members and 4945 guests.
