Unfortunately I have little free space on the site, so the old version I periodically remove.
Running Linux From SD Card or USB Flash Drive - Using Balbes150 Method And Files.
can someone help me with my problem?
every time i start my tv box i have white screen on my tv and nothing happens.even i make a complete and succesfull update with aml update tool and the official firmware,i always have the same problem.
i was trying to boot from sd but nothing happens.
with serial adaptor i can see this
GXBB:BL1:08dafd:0a8993;FEAT:EDFC318C;POC:3;RCY:0;E MMC:0;READ:0;CHK:0;
TE: 46515
no sdio debug board detected
BL2 Built : 13:29:22, May 19 2016.
gxb g4fcf8d0 - xiaobo.gu@droid05
Board ID = 2
set vcck to 1100 mv
set vddee to 1000 mv
CPU clk: 1536MHz
LPDDR3 use R13_C10
STICKY_REG0: 0x00000000
STICKY_REG1: 0x00000000
LPDDR chl: Rank0+1 diff @ 660MHz
DDR0: 256MB(auto)-1T-49
DDR1: 256MB(auto)-1T-49
DataBus test pass!
AddrBus test pass!
Load fip header from eMMC, src: 0x0000c000, des: 0x01400000, size: 0x00004000
Load bl30 from eMMC, src: 0x00010000, des: 0x01000000, size: 0x0000a9b0
Sending bl30...........................................OK.
Run bl30...
Load bl301 from eMMC, src: 0x0001c000, des: 0x01000000, size: 0x00001f60
Wait bl30...Done
Sending bl301........OK.
Run bl301...
rc: 0x00020000, des: 0x10100000, size: 0x00011130
--- UART initialized after reboot ---
[Reset cause: unknown]
[Image: unknown, amlogic_v1.1.3048-cfe1053 2015-12-04 16:31:11 xing.xu@droid05]
bl30: check_permit, count is 1
bl30: check_permit: ok!
chipid: ef beLoad bl33 from eMMC, src: 0x00034000, des: 0x01000000, size: 0x0009e730
ad de d f0 ad ba ef be ad de not ES chip
efuse init ops = 13
efuse init hdcp = c, cf9=7
[0.183561 Inits done]
secure task start!
SARADC channel is 01
SARADC val is 0000010cNOTICE: BL3-1: v1.0(debug):02cce1e
NOTICE: BL3-1: Built : 15:47:40, Nov 6 2015
INFO: BL3-1: Initializing runtime services
INFO: BL3-1: Preparing for EL3 exit to normal world
INFO: BL3-1: Next image address = 0x1000000
INFO: BL3-1: Next image spsr = 0x3c9
U-Boot 2015.01-g685bb0b-dirty (Oct 14 2016 - 14:45:55)
DRAM: 512 MiB
Relocation Offset is: 16ed5000
register usb cfg[0][1] = 0000000017f62be0
register usb cfg[0][2] = 0000000017f62c00
register usb cfg[2][0] = 0000000017f62c20
vpu detect type: 5
vpu clk_level = 7
set vpu clk: 666667000Hz, readback: 666660000Hz(0x300)
boot_device_flag : 1
Nand PHY Ver:1.01.001.0006 (c) 2013 Amlogic Inc.
init bus_cycle=6, bus_timing=8, system=5.0ns
reset failed
get_chip_type and ret:fffffffe
chip detect failed and ret:fffffffe
nandphy_init failed and ret=0xfffffff1
MMC: aml_priv->desc_buf = 0x0000000013ec5770
aml_priv->desc_buf = 0x0000000013ec7900
SDIO Port B: 0, SDIO Port C: 1
emmc/sd response timeout, cmd8, status=0x3ff2800
emmc/sd response timeout, cmd55, status=0x3ff2800
mmc_init: mmc_start_init -20, time 16
mmc_init: 0, time 62
[mmc_init] mmc init success
mmc read lba=0x14000, blocks=0x400
start dts,buffer=0000000013ec9ff0,dt_addr=0000000013ec9f f0
parts: 11
00: logo 0000000002000000 1
01: recovery 0000000002000000 1
02: rsv 0000000000800000 1
03: tee 0000000000800000 1
04: crypt 0000000002000000 1
05: misc 0000000002000000 1
06: instaboot 0000000020000000 1
07: boot 0000000002000000 1
08: system 0000000040000000 1
09: cache 0000000020000000 2
10: data ffffffffffffffff 4
get_dtb_struct: Get emmc dtb OK!
[mmc_get_partition_table] skip cache partition.
Partition table get from SPL is :
name offset size flag
0: bootloader 0 400000 0
1: reserved 2400000 4000000 0
2: cache 6c00000 20000000 2
3: env 27400000 800000 0
4: logo 28400000 2000000 1
5: recovery 2ac00000 2000000 1
6: rsv 2d400000 800000 1
7: tee 2e400000 800000 1
8: crypt 2f400000 2000000 1
9: misc 31c00000 2000000 1
10: instaboot 34400000 20000000 1
11: boot 54c00000 2000000 1
12: system 57400000 40000000 1
13: data 97c00000 30c200000 4
mmc read lba=0x12000, blocks=0x2
mmc read lba=0x12002, blocks=0x2
mmc_read_partition_tbl: mmc read partition OK!
eMMC/TSD partition table have been checked OK!
mmc env offset: 0x27400000
In: serial
Out: serial
Err: serial
[store]To run cmd[emmc dtb_read 0x1000000 0x40000]
read emmc dtb
Net: Meson_Ethernet
wipe_data=successful
wipe_cache=successful
upgrade_step=2
reboot_mode=cold_boot
hpd_state=1
[CANVAS]addr=0x3f800000 width=3840, height=2160
[1080p60hz] is invalid for cvbs.
set hdmitx VIC = 16
config HPLL = 2970
HPLL: 0xc800023d
config HPLL done
set_hpll_od3_clk_div[216] div = 6
j = 8 vid_clk_div = 1
hdmitx phy setting done
hdmitx: set enc for VIC: 16
enc_vpu_bridge_reset[977]
amlkey_init() enter!
[EFUSE_MSG]keynum is 4
[KM]Error:f[key_manage_query_size]L504:key[usid] not programed yet
[KM]Error:f[key_manage_query_size]L504:key[mac] not programed yet
[KM]Error:f[key_manage_query_size]L504:key[deviceid] not programed yet
gpio: pin GPIOAO_3 (gpio 122) value is 1
saradc - saradc sub-system
Usage:
saradc saradc open <channel> - open a SARADC channel
saradc close - close the SARADC
saradc getval - get the value in current channel
saradc get_in_range <min> <max> - return 0 if current value in the range of current channel
Enter USB burn
Set Addr 1
Get DT cfg
Get DT cfg
Get DT cfg
set CFG
waitIdentifyTime(751) > timeout(750)
Hit any key to stop autoboot: 0
read emmc dtb
ee_gate_off ...
## Booting Android Image at 0x01080000 ...
reloc_addr =13f4a1c0
copy done
load dtb from 0x1000000 ......
Uncompressing Kernel Image ... OK
kernel loaded at 0x01080000, end = 0x01efbdb8
Loading Ramdisk to 13c2d000, end 13ec3117 ... OK
Loading Device Tree to 0000000013c22000, end 0000000013c2cf2d ... OK
signature:
fdt_instaboot: get header err
Starting kernel ...
uboot time: 2684877 us
then it stuck . my tv box is docooler s905 pro.
TE: 125880
BL2 Built : 15:22:26, Nov 13 2015.
gxb g6dcf28d - xiaobo.gu@droid05
set vcck to 1100 mv
Board ID = 2
CPU clk: 1536MHz
DDR channel setting: DDR0 Rank0+1 same
DDR0: 1024MB(auto) @ 912MHz(2T)-13
DataBus test pass!
AddrBus test pass!
Load fip header from eMMC, src: 0x0000c000, des: 0x01400000, size: 0x000000b0
Load bl30 from eMMC, src: 0x00010000, des: 0x01000000, size: 0x000088c0
Sending bl30...................................OK.
Run bl30...
Load bl301 from eMMC, src: 0x0001c000, des: 0x01000000, size: 0x00001e60
Wait bl30...Done
Run bl301...
Load bl31 from eMMC,[ src: 0x00020000, des: 0x10100000, size: 0x00014240
Image: gxb_v1.1.3060-2032b38 2016-03-25 15:43:36 xing.xu@droid05]
chipid: ef be ad de d f0 ad ba ef be ad de not ES chip
efuse init ops = 23
efuse init hdcp = 7c, cf9=0
[0.228221 Inits done]
secure task start!
high task start!
low task start!
Load bl33 from eMMC, src: 0x00038000, des: 0x01000000, size: 0x000a3a00
NOTICE: BL3-1: v1.0(debug):0e5e53f
NOTICE: BL3-1: Built : 10:50:05, Mar 1 2016
U-Boot 2015.01-svn113868 (Apr 22 2016 - 16:50:19)
DRAM: 1 GiB
Relocation Offset is: 36ed0000
IR init done!
register usb cfg[0][1] = 0000000037f62780
register usb cfg[0][2] = 0000000037f627a0
register usb cfg[2][0] = 0000000037f627c0
vpu: error: vpu: check dts: FDT_ERR_BADMAGIC, load default parameters
vpu: clk_level = 7
vpu: set clk: 666667000Hz, readback: 666660000Hz(0x300)
reset failed
MMC: aml_priv->desc_buf = 0x0000000033ec0770
aml_priv->desc_buf = 0x0000000033ec2900
emmc/sd response timeout, cmd = 8
emmc/sd response timeout, cmd = 55
Amlogic multi-dtb tool
Single dtb detected
start dts,buffer=0000000033ec4eb0,dt_addr=0000000033ec4e b0
parts: 11
08: system 0000000050000000 1
12: system 57400000 50000000 1
13: data a7c00000 12a400000 4
mmc read lba=0x12000, blocks=0x1
mmc read lba=0x12001, blocks=0x1
In: serial
Out: serial
Err: serial
hpd_state=0
cvbs performance type = 0, table = 1
read emmc dtb
Single dtb detected
Net: Meson_Ethernet
upgrade_step=0
hpd_state=0
[KM]Error:f[key_manage_query_size]L507:key[usid] not programed yet
[KM]Error:f[key_manage_query_size]L507:key[deviceid] not programed yet
Usage:
Enter USB burn
Try connect time out 701, 700, 672
(Re)start USB...
USB0: dwc_usb driver version: 2.94 6-June-2012
USB (0) peri reg base: c0000000
USB (0) use clock source: XTAL input, div: 1
USB (0) base addr: 0xc9000000
Force id mode: Host
dwc_otg: No USB device found !
lowlevel init failed
USB1: dwc_usb driver version: 2.94 6-June-2012
USB (1) peri reg base: c0000020
USB (1) use clock source: XTAL input, div: 1
USB (1) base addr: 0xc9100000
Force id mode: Host
USB error: all controllers failed lowlevel init
** Bad device usb 0 **
** Bad device usb 1 **
** Bad device usb 2 **
** Bad device usb 3 **
ret = 1 .[mmc_init] mmc init success
Device: SDIO Port B
Manufacturer ID: 3
OEM: 5344
Tran Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 7.4 GiB
Bus Width: 4-bit
reading s905_autoscript
1545 bytes read in 11 ms (136.7 KiB/s)
## Executing script at 01020000
reading uInitrd
4292669 bytes read in 195 ms (21 MiB/s)
reading zImage
16932800 bytes read in 750 ms (21.5 MiB/s)
reading dtb.img
** Unable to read file dtb.img **
read emmc dtb
Single dtb detected
## Loading init Ramdisk from Legacy Image at 13000000 ...
Image Name: uInitrd
Image Type: AArch64 Linux RAMDisk Image (gzip compressed)
Data Size: 4292605 Bytes = 4.1 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
Single dtb detected
## Flattened Device Tree blob at 01000000
Booting using the fdt blob at 0x1000000
Loading Ramdisk to 33aa5000, end 33ebcffd ... OK
Loading Device Tree to 000000001fff5000, end 000000001ffffddf ... OK
signature:
Starting kernel ...
uboot time: 6295745 us
Originally posted by stelioskoz View Post
very strange because this tv box is with 2gb ram.where is the other 1,5 gb?
Originally posted by Shimon View Post
IIRC, the S905, 3.14.79 based images were unique, by virtue of supporting VESA modes and not just 720p/1080p.
Are the mainline (4.x kernel) S905 images also superior in that respect or it doesn't matter any more? Not sure what they have to offer compared to s905x-S912 ones.
Originally posted by balbes150 View Post
I don't know why you have so much memory, I'm just stating a fact that you can see in the log. You have this attachment previously worked fine with the regular Android ? Was not braking or freezes while working ?
QA5:A;SVN:B72;POC:17F;STS:0;BOOT:0;INIT:0;READ:0;C HECK:0;PASS:0;
TE : 253090
BT : 15:18:08 Aug 25 2015
PMU:NONE
##### VDDEE voltage = 0x044c
CPU clock is 792MHz
DDR mode: 32 bit mode (auto)
DDR size: 512MB (auto)
DDR check: Pass!
DDR clock: 636MHz with 2T mode
DDR pll bypass: Disabled
DDR init use : 15588 us
HHH
Boot From SDIO C
SD_boot_type: 00000002
card_type: 00000001
0x0000009f
check SD_boot_type:0x2 card_type:0x1
ucl decompress...pass
0x12345678
Boot from internal device 1st tSD/fSD on SDIO C
TE : 616398
System Started
U-boot-00000-gea60e66-dirty(m8b_m201_v1@) (Aug 25 2015 - 15:17:56)
clr h-ram
DRAM: 512 MiB
relocation Offset is: 0fec8000
show partition table:
part: 0, name : logo, size : 2000000
part: 1, name : recovery, size : 2000000
part: 2, name : misc, size : 2000000
part: 3, name : boot, size : 2000000
part: 4, name : system, size : 40000000
part: 5, name : cache, size : 20000000
part: 6, name : data, size : end
aml_card_type=0x0
MMC: [mmc_register] add mmc dev_num=0, port=1, if_type=6
[mmc_register] add mmc dev_num=1, port=2, if_type=6
The osc_clk is not running now!
power init
out reg=c110804c,value=dfffffff
IR init done!
register usb cfg[0][1] = 1ff73ba8
register usb cfg[2][0] = 1ff76748
init 32k clock
out reg=c8100024,value=bfff3fff
out reg=c8100024,value=9fff3ffb
NAND: EMMC BOOT: not init nand
do not init nand : cause boot_device_flag without nand
get_boot_device_flag: init_ret -1
get_boot_device_flag EMMC BOOT:
Emmckey: Access range is illegal!
[mmc_init] SDIO Port C:1, if_type=7, initialized OK!
6: misc 2d400000 2000000 1
7: boot 2fc00000 2000000 1
8: system 32400000 40000000 1
9: data 72c00000 15b500000 4
i=0,register --- emmc_key
MMC BOOT, emmc_env_relocate_spec : env_relocate_spec 59
set_storage_device_flag: store 2
mem size is 512
The osc_clk is running now!
checked platform is costdown,use costdown dtd
aml_dt: m8b_m201C_512M
aml_dt is: m8b_m201C_512M
Multi dtb tool version: v2 .
Multi dtb detected, support 4 dtbs.
aml_dt soc: m8b platform: m201C variant: 512M
dtb 0 soc: m8b plat: m201 vari: 1G
dtb 1 soc: m8b plat: m201 vari: 512M
dtb 2 soc: m8b plat: m201C vari: 1G
dtb 3 soc: m8b plat: m201C vari: 512M
Find match dtb: 3
vpu clk_level in dts: 3
set vpu clk: 182150000Hz, readback: 182150000Hz(0x701)
Net: Meson_Ethernet
init suspend firmware done. (ret:0)
cvbs trimming.1.v5: 0xa0, 0x0
hdmi tx power init
vdac open.1 = 0x1, 0x0
mode is: 4
viu chan = 1
config HPLL
config HPLL done
[ImgPck]ver=2
-->reboot_mode:0x0
-->powerkey:0x0
reboot_mode=charging
Hit Enter key to stop autoboot -- : 0
exit abortboot: 0
(Re)start USB(0)...
USB: dwc_usb driver version: 2.94 6-June-2012
USB (1) peri reg base: c1108820
USB (1) base addr: 0xc90c0000
Force id mode: Host
dwc_otg: Highspeed device found !
scanning bus for devices... 1 USB Device(s) found
scanning bus for storage devices... 1 Storage Device(s) found
reading s805_autoscript
798 bytes read
## Executing script at 11000000
MMC: block number 0x1 exceeds max(0x0)
** Can't read from device 0 **
** Unable to use mmc 0:1 for fatload **
reading uInitrd
2982713 bytes read
reading uImage
6119561 bytes read
reading dtb.img
22446 bytes read
## Booting kernel from Legacy Image at 14000000 ...
Image Name: Linux-3.10.33
Image Type: ARM Linux Kernel Image (gzip compressed)
Data Size: 6119497 Bytes = 5.8 MiB
Load Address: 00208000
Entry Point: 00208000
## Loading init Ramdisk from Legacy Image at 15000000 ...
Image Name: uInitrd
Image Type: ARM Linux RAMDisk Image (gzip compressed)
Data Size: 2982649 Bytes = 2.8 MiB
## Flattened Device Tree blob at 11800000
Booting using the fdt blob at 0x11800000
board_usb_stop cfg: 0
uboot time: 18606389 us.
EFUSE machid is not set.
Using machid 0xf81 from environment
From device tree /memory/ node aml_reserved_end property, for relocate ramdisk and fdt, relocate_addr: 0x52e2001
Loading Ramdisk to 05009000, end 052e12f9 ... OK
Loading Device Tree to 05000000, end 050087ad ... OK
Starting kernel ...
[ 0.000000@0] Booting Linux on physical CPU 0x200
[ 0.000000@0] Initializing cgroup subsys cpu
[ 0.000000@0] Initializing cgroup subsys cpuacct
[ 0.000000@0] Linux version 3.10.33-vegas805-g6575b40 (root@user-VirtualBox) (gcc version 4.9.4 20151028 (prerelease) (Linaro GCC 4.9-2016.02) ) #10 SMP PREEMPT Sat Mar 25 10:07:14 MSK 2017
[ 0.000000@0] CPU: ARMv7 Processor [410fc051] revision 1 (ARMv7), cr=10c5387d
[ 0.000000@0] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000@0] Machine: Amlogic Meson8B, model: AMLOGIC
[ 0.000000@0] no prop version_code
[ 0.000000@0] physical memory start address is 0x200000
[ 0.000000@0] reserved_end is c1fffff
[ 0.000000@0]
[ 0.000000@0] Total memory is 510 MiB
[ 0.000000@0] Reserved low memory from 0x06000000 to 0x0c1fffff, size: 98 MiB
[ 0.000000@0] mesonfb0(low) : 0x06100000 - 0x06900000 ( 8 MiB)
[ 0.000000@0] mesonfb1(low) : 0x06900000 - 0x06a00000 ( 1 MiB)
[ 0.000000@0] deinterlace0(high) : 0x1e800000 - 0x20000000 ( 24 MiB)
[ 0.000000@0] mesonstream0(low) : 0x06a00000 - 0x07200000 ( 8 MiB)
[ 0.000000@0] vdec0(low) : 0x07200000 - 0x0b200000 ( 64 MiB)
[ 0.000000@0] ppmgr0(low) : 0x0b200000 - 0x0c200000 ( 16 MiB)
[ 0.000000@0] cma: CMA: reserved 8 MiB at 1e000000
[ 0.000000@0] cma: Found region@0, memory base 0, size 18 MiB
[ 0.000000@0] cma: CMA: reserved 20 MiB at 1cc00000
[ 0.000000@0] Memory policy: ECC disabled, Data cache writealloc
[ 0.000000@0] Meson chip version = RevA (1B:A - 0:B72)
[ 0.000000@0] PERCPU: Embedded 9 pages/cpu @c132d000 s12992 r8192 d15680 u36864
[ 0.000000@0] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 94772
[ 0.000000@0] Kernel command line: root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyS0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.repair=yes net.ifnames=0 mac=
[ 0.000000@0] ******** uboot setup mac-addr: bc:c0:56:a8:32:c1
[ 0.000000@0] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000@0] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000@0] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000@0] Memory: 64MB 16MB 294MB = 374MB total
[ 0.000000@0] Memory: 331092k/331092k available, 51884k reserved, 0K highmem
[ 0.000000@0] Virtual kernel memory layout:
[ 0.000000@0] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000@0] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000@0] vmalloc : 0xde800000 - 0xff000000 ( 520 MB)
[ 0.000000@0] lowmem : 0xc0000000 - 0xde600000 ( 486 MB)
[ 0.000000@0] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000@0] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000@0] .text : 0xc0008000 - 0xc0b69d14 (11656 kB)
[ 0.000000@0] .init : 0xc0b6a000 - 0xc0bcc2c0 ( 393 kB)
[ 0.000000@0] .data : 0xc0bce000 - 0xc0c71940 ( 655 kB)
[ 0.000000@0] .bss : 0xc0c71940 - 0xc0f50f04 (2942 kB)
[ 0.000000@0] PM: Registered nosave memory: 0000000000208000 - 0000000000d69000
[ 0.000000@0] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000@0] Preemptible hierarchical RCU implementation.
[ 0.000000@0] NR_IRQS:256
[ 0.000000@0] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
[ 0.000000@0] Global timer: MESON TIMER-F (c0bedb40) initialized
[ 0.000000@0] Switching to timer-based delay loop
[ 0.000000@0] Console: colour dummy device 80x30
[ 0.000000@0] console [tty0] enabled
[ 8.056050@3] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ 8.066537@3] systemd[1]: systemd-modules-load.service: main process exited, code=exited, status=1/FAILURE
[ 8.083749@3] systemd[1]: Failed to start Load Kernel Modules.
[ 8.087873@3] systemd[1]: Unit systemd-modules-load.service entered failed state.
[ 8.100783@3] systemd[1]: Started LSB: Set keymap.
[ 8.106343@3] systemd[1]: Time has been changed
[ 8.115659@3] systemd[1]: Started udev Coldplug all Devices.
[ 8.208044@3] systemd[1]: Mounting FUSE Control File System...
[ 8.218688@3] systemd[1]: Mounting Configuration File System...
[ 8.229831@3] systemd[1]: Starting Apply Kernel Variables...
[ 8.241211@3] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 8.253312@3] systemd[1]: Starting Syslog Socket.
[ 8.261793@3] systemd[1]: Listening on Syslog Socket.
[ 8.265739@3] systemd[1]: Starting Journal Service...
[ 8.280899@3] systemd[1]: Started Journal Service.
[ 8.383334@0] systemd-udevd[211]: starting version 215
[ 8.930291@2] ionvideo open
[ 8.934708@2] ionvideo_stop_generating!!!!
[ 8.938928@2] ionvideo release
[ 8.931425@2] amlvideo openamlvideo close[ 13.845331@3] EXT4-fs (sda2): re-mounted. Opts: commit=600,errors=remount-ro
[ 26.394452@3] hdmitx: cec: CEC not ready
[ 46.434452@3] hdmitx: cec: CEC not ready
[ 66.474448@3] hdmitx: cec: CEC not ready
[ 86.514449@3] hdmitx: cec: CEC not ready
[ 97.938848@1] systemd-journald[209]: Received request to flush runtime journal from PID 1
[ 106.554454@3] hdmitx: cec: CEC not ready
[ 126.594457@3] hdmitx: cec: CEC not ready
[ 133.734627@2] stk8baxx_permis_thread exit, retry=22
[ 146.634465@3] hdmitx: cec: CEC not ready
[ 166.674502@3] hdmitx: cec: CEC not ready
[ 186.714503@3] hdmitx: cec: CEC not ready
[ 206.754500@3] hdmitx: cec: CEC not ready
[ 226.794502@3] hdmitx: cec: CEC not ready
[ 246.834504@3] hdmitx: cec: CEC not ready
i try to boot the official rom from sd card.i see this
scanning bus 1 for devices... 1 USB Device(s) found
scanning usb for storage devices... 0 Storage Device(s) found
ret = 1 .mmc_init: mmc_start_init 0, time 408
mmc_init: 0, time 422
Device: SDIO Port B
Manufacturer ID: 2
OEM: 544d
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Capacity: 3.7 GiB
Bus Width: 4-bit
935 bytes read in 5 ms (182.6 KiB/s)
########## cmd=setenv kernel_loadaddr "0x1080000"
setenv condev "console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0"
setenv bootargs_mmc "root=/dev/mmcblk1p2 rootwait rootflags=data=writeback rw ${condev} no_console_suspend fsck.repair=yes net.ifnames=0"
setenv bootargs_usb "root=/dev/sda2 rootwait rootflags=data=writeback rw ${condev} no_console_suspend fsck.repair=yes net.ifnames=0"
setenv boot_start bootm ${kernel_loadaddr} - ${dtb_mem_addr}
if fatload usb 0 ${kernel_loadaddr} uImage; then setenv bootargs ${bootargs_usb}; if fatload usb 0 ${dtb_mem_addr} dtb.img; then run boot_start; else store dtb read ${dtb_mem_addr}; run boot_start;fi;fi;
if fatload mmc 0 ${kernel_loadaddr} uImage; then setenv bootargs ${bootargs_mmc}; if fatload mmc 0 ${dtb_mem_addr} dtb.img; then run boot_start; else store dtb read ${dtb_mem_addr}; run boot_start;fi;fi;
reading uImage
** Unable to read file uImage **
"Synchronous Abort" handler, esr 0x8a000000
ELR: 726174735f746f6f
x0 : 0000000000000000 x1 : 0000000013f017c0
x2 : 00000000c13e2ffe x3 : 0000000017f65230
x4 : 0000000017f64db0 x5 : 0000000017f65230
x6 : 0000000017f64db0 x7 : 0000000017f64dc0
x8 : 0000000000000001 x9 : 0000000000000002
x10: 000000000000000f x11: 0000000017f46af0
x12: 0000000000000000 x13: 0000000000000000
x14: 0000000000000000 x15: 0000000017ed60d0
x16: 0000000017ed62b4 x17: 0000000000000000
x18: 0000000013ec4e28 x19: 2065736c65203b74
x20: 74642065726f7473 x21: 2420646165722062
x22: 6d656d5f6274647b x23: 0000000017f73998
x24: 0000000000000000 x25: 0000000000000000
x26: 0000000000000000 x27: 0000000013f01590
x28: 0000000000000000 x29: 62206e7572206e65
Resetting CPU ...
resetting ...
TE: 45425
Board ID = 2
set vcck to 1100 mv
CPU clk: 1536MHz
LPDDR3 use R13_C10
DataBus test pass!
AddrBus test pass!
Run bl30...
Wait bl30...Done
Run bl301...
efuse init ops = 13
[0.182371 Inits done]
secure task start!
DRAM: 512 MiB
vpu detect type: 5
vpu clk_level = 7
reset failed
parts: 11
In: serial
Out: serial
Err: serial
read emmc dtb
Net: Meson_Ethernet
upgrade_step=0
reboot_mode=normal
hpd_state=1
set hdmitx VIC = 16
config HPLL = 2970
HPLL: 0xc800023d
config HPLL done
Usage:
(Re)start USB...
Force id mode: Host
Force id mode: Host
and always restart and do the same again and again
IF TI TRY TO BOOT FROM SD WITH Armbian_5.27_S9xxx_Debian_jessie_3.14.29_server_20 170531.img I HAVE THIS.
TE: 48297
Board ID = 2
set vcck to 1100 mv
CPU clk: 1536MHz
LPDDR3 use R13_C10
DataBus test pass!
AddrBus test pass!
Run bl30...
Wait bl30...Done
Run bl301...
efuse init ops = 13
[0.185259 Inits done]
secure task start!
DRAM: 512 MiB
vpu detect type: 5
vpu clk_level = 7
reset failed
parts: 11
In: serial
Out: serial
Err: serial
read emmc dtb
Net: Meson_Ethernet
upgrade_step=0
hpd_state=0
Not find '576cvbs' mapped VIC
Usage:
Enter USB burn
Try connect time out 701, 700, 632
(Re)start USB...
Force id mode: Host
Force id mode: Host
ret = 1 .mmc_init: mmc_start_init 0, time 813
mmc_init: 0, time 827
Device: SDIO Port B
Manufacturer ID: 2
OEM: 544d
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Capacity: 3.7 GiB
Bus Width: 4-bit
1545 bytes read in 9 ms (167 KiB/s)
########## cmd=setenv kernel_loadaddr "0x11000000"
setenv initrd_loadaddr "0x13000000"
setenv condev "console=ttyS0,115200n8 console=tty0 no_console_suspend consoleblank=0"
setenv bootargs "root=LABEL=ROOTFS rootflags=data=writeback rw ${condev} fsck.repair=yes net.ifnames=0 mac=${mac}"
setenv boot_start booti ${kernel_loadaddr} ${initrd_loadaddr} ${dtb_mem_addr}
if fatload usb 0 ${initrd_loadaddr} uInitrd; then if fatload usb 0 ${kernel_loadaddr} zImage; then if fatload usb 0 ${dtb_mem_addr} dtb.img; then run boot_start; else store dtb read ${dtb_mem_addr}; run boot_start;fi;fi;fi;
if fatload usb 1 ${initrd_loadaddr} uInitrd; then if fatload usb 1 ${kernel_loadaddr} zImage; then if fatload usb 1 ${dtb_mem_addr} dtb.img; then run boot_start; else store dtb read ${dtb_mem_addr}; run boot_start;fi;fi;fi;
if fatload usb 2 ${initrd_loadaddr} uInitrd; then if fatload usb 2 ${kernel_loadaddr} zImage; then if fatload usb 2 ${dtb_mem_addr} dtb.img; then run boot_start; else store dtb read ${dtb_mem_addr}; run boot_start;fi;fi;fi;
if fatload usb 3 ${initrd_loadaddr} uInitrd; then if fatload usb 3 ${kernel_loadaddr} zImage; then if fatload usb 3 ${dtb_mem_addr} dtb.img; then run boot_start; else store dtb read ${dtb_mem_addr}; run boot_start;fi;fi;fi;
if fatload mmc 0 ${initrd_loadaddr} uInitrd; then if fatload mmc 0 ${kernel_loadaddr} zImage; then if fatload mmc 0 ${dtb_mem_addr} dtb.img; then run boot_start; else store dtb read ${dtb_mem_addr}; run boot_start;fi;fi;fi;
reading uInitrd
4292523 bytes read in 254 ms (16.1 MiB/s)
reading zImage
16932800 bytes read in 996 ms (16.2 MiB/s)
reading dtb.img
38993 bytes read in 12 ms (3.1 MiB/s)
Image Name: uInitrd
Data Size: 4292459 Bytes = 4.1 MiB
Loading Ramdisk to 13aaa000, end 13ec1f6b ... OK
Loading Device Tree to 0000000013a9d000, end 0000000013aa9850 ... OK
signature:
Starting kernel ...
uboot time: 12119771 us
There are currently 2164 users online. 2 members and 2162 guests.
