Running Linux From SD Card or USB Flash Drive - Using Balbes150 Method And Files.
It all looks good:
Start copy system for DATA partition.
Formatting DATA partition...
/dev/data: clean, 11/760368 files, 74369/3036160 blocks
done.
Copying ROOTFS.
Copy BIN
Copy BOOT
Create DEV
Copy ETC
Copy HOME
Copy LIB
Create MEDIA
Create MNT
Copy OPT
Create PROC
Copy ROOT
Create RUN
Copy SBIN
Copy SELINUX
Copy SRV
Create SYS
Create TMP
Copy USR
Copy VAR
Copy fstab
Done copy ROOTFS
Writing kernel image...
done.
Write env bootargs
Complete copy OS to eMMC parted DATA
Hello balbes150! Thank you so much for your amazing work and making it available to us!! I am now hopeful that I will be able to run Linux on my Tronsmart Vega s95 Telos!
However, I run into problems when trying to update uboot. I put the two files (aml_autoscript.zip and aml_autoscript) on the root of my USB flash drive and I find them in the Update & Backup app but as it reboots and the install process is about to start it gets stuck saying "E : Cannot mount volume /misc!". Would this go away if I purchased and used an SD card instead or do you know if it's a different problem?
Best wishes and once again thank you!!
/D
Ok I tried with an SD card instead but this time it just gets stuck at the initial Tronsmart boot screen.
Any tips or clues towards what I'm doing wrong would be much appreciated!
(To be clear: I have flashed the image called "Armbian_5.27_S9xxx_Debian_jessie_3.14.29_xfce_201 70808.img" to the SD-card and I am using the "aml_autoscript.zip" that is included in the image as you stated in the updated instruction.)
best and thank you balbes150!
/D
Hi Guys,
First I'd like to Thank the experts for their excellent contributions. Balbes, the imges you've created and posted have helped me play around with linux on my MXQ Pro, EM95 and other boxes powered by Amlogic S905.
Seeking advice on troubleshooting Buildroot image:
After several weeks of playing with the prebuild images from Balbes, I went ahead and tried making buildroot from source on openlinux.amlogic.com. I was successfully able to make the Buildroot and I think I have it installed on eMMC as well using the steps in release notes - (point 4.4) : http://openlinux.amlogic.com:8000/do...lease-v1.4.pdf
But now when I boot the boot sequence seems to complete, but there are some warnings and issues that I am seeking advice on:
1 - I get blank screen on my monitor. I am watching the UART for the bootup sequence so I know it completes.
2. The output of fdisk -l suggests that my partitions are not built correctly.
3. There are some warnings along the boot logs that I need to fix. I'll be spending more time on these, but I think the other two issues are more pressing.
Can someone please take a look at these logs and tell how to fix these issues.
------------- start of output from power on -------------
Code:# GXBB:BL1:08dafd:0a8993;FEAT:EDFC318C;POC:3;RCY:0;E MMC:0;READ:0;CHK:0; TE: 132696 no sdio debug board detected BL2 Built : 15:24:17, Oct 28 2015. gxb g5d0d038 - xiaobo.gu@droid05 Board ID = 1 set vcck to 1100 mv set vddee to 1000 mv CPU clk: 1536MHz DDR channel setting: DDR0 Rank0+1 same DDR0: 1024MB @ 912MHz(2T)-13 DataBus test pass! AddrBus test pass! Load fip header from eMMC, src: 0x0000c000, des: 0x01400000, size: 0x000000b0 Load bl30 from eMMC, src: 0x00010000, des: 0x01000000, size: 0x0000a9b0 Sending bl30...........................................OK. Run bl30... Load bl301 from eMMC, src: 0x0001c000, des: 0x01000000, size: 0x00001b80 Wait bl30...Done Sending bl301.......OK. Run bl301... src: 0x00020000, des: 0x10100000, size: 0x00011130 --- UART initialized after reboot --- [Reset cause: unknown] [Image: unknown, amlogic_v1.1.3048-cfe1053 2015-12-04 16:31:11 xing.xu@droid05] bl30: check_permit, count is 1 bl30: check_permit: ok! chipid: ef be Load bl33 from eMMC, src: 0x00034000, des: 0x01000000, size: 0x0009ddc0 ad de d f0 ad ba ef be ad de not ES chip efuse init ops = 12 efuse init hdcp = c, cf9=7 [0.253990 Inits done] secure task start! high task start! low task start! NOTICE: BL3-1: v1.0(debug):02cce1e NOTICE: BL3-1: Built : 15:47:40, Nov 6 2015 INFO: BL3-1: Initializing runtime services INFO: BL3-1: Preparing for EL3 exit to normal world INFO: BL3-1: Next image address = 0x1000000 INFO: BL3-1: Next image spsr = 0x3c9 U-Boot 2015.01 (Aug 17 2017 - 00:57:35) DRAM: 1 GiB Relocation Offset is: 36ed5000 register usb cfg[0][1] = 0000000037f62390 register usb cfg[0][2] = 0000000037f623b0 register usb cfg[2][0] = 0000000037f623d0 vpu detect type: 5 vpu clk_level = 7 set vpu clk: 666667000Hz, readback: 666660000Hz(0x300) boot_device_flag : 1 Nand PHY Ver:1.01.001.0006 (c) 2013 Amlogic Inc. init bus_cycle=6, bus_timing=8, system=5.0ns reset failed get_chip_type and ret:fffffffe get_chip_type and ret:fffffffe chip detect failed and ret:fffffffe nandphy_init failed and ret=0xfffffff1 MMC: aml_priv->desc_buf = 0x0000000033ec5770 aml_priv->desc_buf = 0x0000000033ec7900 SDIO Port B: 0, SDIO Port C: 1 [mmc_init] mmc init success mmc read lba=0x14000, blocks=0x400 start dts,buffer=0000000033ec9d70,dt_addr=0000000033ec9d 70 parts: 11 00: logo 0000000002000000 1 01: recovery 0000000002000000 1 02: rsv 0000000000800000 1 03: tee 0000000000800000 1 04: crypt 0000000002000000 1 05: misc 0000000002000000 1 06: instaboot 0000000020000000 1 07: boot 0000000002000000 1 08: system 0000000040000000 1 09: cache 0000000020000000 2 10: data ffffffffffffffff 4 get_dtb_struct: Get emmc dtb OK! [mmc_get_partition_table] skip cache partition. Partition table get from SPL is : name offset size flag ================================================== ================================= 0: bootloader 0 400000 0 1: reserved 2400000 4000000 0 2: cache 6c00000 20000000 2 3: env 27400000 800000 0 4: logo 28400000 2000000 1 5: recovery 2ac00000 2000000 1 6: rsv 2d400000 800000 1 7: tee 2e400000 800000 1 8: crypt 2f400000 2000000 1 9: misc 31c00000 2000000 1 10: instaboot 34400000 20000000 1 11: boot 54c00000 2000000 1 12: system 57400000 40000000 1 13: data 97c00000 13a400000 4 mmc read lba=0x12000, blocks=0x1 mmc read lba=0x12001, blocks=0x1 mmc_read_partition_tbl: mmc read partition OK! eMMC/TSD partition table have been checked OK! mmc env offset: 0x27400000 In: serial Out: serial Err: serial [store]To run cmd[emmc dtb_read 0x1000000 0x40000] read emmc dtb Net: Meson_Ethernet wipe_data=successful wipe_cache=successful upgrade_step=0 reboot_mode=cold_boot hpd_state=1 [CANVAS]addr=0x3f800000 width=3840, height=2160 [1080p60hz] is invalid for cvbs. set hdmitx VIC = 16 config HPLL = 2970 HPLL: 0xc800023d config HPLL done set_hpll_od3_clk_div[216] div = 6 j = 8 vid_clk_div = 1 hdmitx phy setting done hdmitx: set enc for VIC: 16 enc_vpu_bridge_reset[977] amlkey_init() enter! [EFUSE_MSG]keynum is 4 [KM]Error:f[key_manage_query_size]L504:key[usid] not programed yet [KM]Error:f[key_manage_query_size]L504:key[mac] not programed yet [KM]Error:f[key_manage_query_size]L504:key[deviceid] not programed yet gpio: pin GPIOAO_3 (gpio 122) value is 1 Enter USB burn Try connect time out 701, 700, 596 Hit any key to stop autoboot: 0 (Re)start USB... USB0: dwc_usb driver version: 2.94 6-June-2012 USB (0) peri reg base: c0000000 USB (0) use clock source: XTAL input, div: 1 USB (0) base addr: 0xc9000000 Force id mode: Host dwc_otg: No USB device found ! lowlevel init failed USB1: dwc_usb driver version: 2.94 6-June-2012 USB (1) peri reg base: c0000020 USB (1) use clock source: XTAL input, div: 1 USB (1) base addr: 0xc9100000 Force id mode: Host dwc_otg: Highspeed device found ! scanning bus 1 for devices... 2 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found ** Bad device usb 0 ** ret = 1 .[store]To run cmd[emmc dtb_read 0x1000000 0x40000] read emmc dtb ee_gate_off ... ## Booting Android Image at 0x01080000 ... load dtb from 0x1000000 ...... board_usb_stop cfg: 0 Loading Kernel Image ... OK kernel loaded at 0x01080000, end = 0x01eef8f8 Loading Ramdisk to 33baf000, end 33ec2a5d ... OK Loading Device Tree to 000000001fff5000, end 000000001ffffdc4 ... OK signature: fdt_instaboot: get header err Starting kernel ... uboot time: 12447682 us [ 0.000000@0] Initializing cgroup subsys cpu [ 0.000000@0] Initializing cgroup subsys cpuacct [ 0.000000@0] Linux version 3.14.29 (root@ubuntu-server-developer) (gcc version 4.9.2 20140904 (prerelease) (crosstool-NG linaro-1.13.1-4.9-2014.09 - Linaro GCC 4.9-2014.09) ) #1 SMP PREEMPT Wed Aug 16 15:10:43 EDT 2017 [ 0.000000@0] CPU: AArch64 Processor [410fd034] revision 4 [ 0.000000@0] no prop version_code [ 0.000000@0] bootconsole [earlycon0] enabled [ 0.000000@0] secmon: share mem setup [ 0.000000@0] Reserved memory: initialized node linux,secmon, compatible id aml_secmon_memory [ 0.000000@0] __reserved_mem_alloc_size: linux,meson-fb [ 0.000000@0] fb: Reserved memory: created fb at 0x000000003e000000, size 32 MiB [ 0.000000@0] Reserved memory: initialized node linux,meson-fb, compatible id amlogic, fb-memory [ 0.000000@0] __reserved_mem_alloc_size: linux,di [ 0.000000@0] DI reserved memory: created CMA memory pool at 0x000000003c200000, size 30 MiB [ 0.000000@0] Reserved memory: initialized node linux,di, compatible id amlogic, di-mem [ 0.000000@0] __reserved_mem_alloc_size: linux,ion-dev [ 0.000000@0] linux,ion-dev add multi user:ffffffc001e88420 [ 0.000000@0] ion_dev mem setup [ 0.000000@0] Reserved memory: initialized node linux,ion-dev, compatible id amlogic, idev-mem [ 0.000000@0] ppmgr share mem setup [ 0.000000@0] linux,ion-dev add multi user:ffffffc001e90a58 [ 0.000000@0] Reserved memory: initialized node linux,ion-dev, compatible id amlogic, idev-mem [ 0.000000@0] __reserved_mem_alloc_size: linux,codec_mm_cma [ 0.000000@0] Reserved memory: created CMA memory pool at 0x0000000027800000, size 192 MiB [ 0.000000@0] Reserved memory: initialized node linux,codec_mm_cma, compatible id shared-dma-pool [ 0.000000@0] __reserved_mem_alloc_size: linux,picdec [ 0.000000@0] Reserved memory: created CMA memory pool at 0x0000000037000000, size 48 MiB [ 0.000000@0] Reserved memory: initialized node linux,picdec, compatible id shared-dma-pool [ 0.000000@0] __reserved_mem_alloc_size: linux,codec_mm_reserved [ 0.000000@0] codec_mm:vdec: reserved mem setup [ 0.000000@0] Reserved memory: initialized node linux,codec_mm_reserved, compatible id amlogic, codec-mm-reserved [ 0.000000@0] cma: Reserved 8 MiB at 36800000 [ 0.000000@0] psci: probing function IDs from device-tree [ 0.000000@0] PERCPU: Embedded 12 pages/cpu @ffffffc03a1ac000 s19328 r8192 d21632 u49152 [ 0.000000@0] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 244696 [ 0.000000@0] Kernel command line: root=/dev/system rootfstype=ext4 init=/sbin/init console=ttyS0,115200 no_console_suspend earlyprintk=aml-uart,0xc81004c0 ramoops.mem_address=0x20000000 ramoops.mem_size=0x100000 ramoops.record_size=0x8000 ramoops.console_size=0x4000 androidboot.selinux=permissive logo=osd1,loaded,0x3f800000,1080p60hz,hdmimode=108 0p60hz cvbsmode=576cvbs hdmitx=1080p60hz androidboot.firstboot=1 [ 0.000000@0] logo: osd1 [ 0.000000@0] logo: loaded [ 0.000000@0] logo: 0x3f800000 [ 0.000000@0] logo: 1080p60hz [ 0.000000@0] logo: hdmimode=1080p60hz [ 0.000000@0] logo: get cvbsmode: 576cvbs [ 0.000000@0] PID hash table entries: 4096 (order: 3, 32768 bytes) [ 0.000000@0] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.000000@0] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes) [ 0.000000@0] Memory: 568792K/996352K available (9500K kernel code, 990K rwdata, 3252K rodata, 1030K init, 3182K bss, 427560K reserved) [ 0.000000@0] Virtual kernel memory layout: [ 0.000000@0] vmalloc : 0xffffff8000000000 - 0xffffff8040000000 ( 1024 MB) [ 0.000000@0] vmemmap : 0xffffff8040010000 - 0xffffff8041180000 ( 17 MB) [ 0.000000@0] modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB) [ 0.000000@0] memory : 0xffffffc000000000 - 0xffffffc03e000000 ( 992 MB) [ 0.000000@0] .init : 0xffffffc001cf6000 - 0xffffffc001df7b80 ( 1031 kB) [ 0.000000@0] .text : 0xffffffc001080000 - 0xffffffc001cf5134 ( 12757 kB) [ 0.000000@0] .data : 0xffffffc001df8000 - 0xffffffc001eef8f8 ( 991 kB) [ 0.000000@0] PM: Registered nosave memory: [mem 0x01080000-0x01cf4fff] [ 0.000000@0] SLUB: HWalign=64, Order=0-1, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000@0] Preemptible hierarchical RCU implementation. [ 0.000000@0] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. [ 0.000000@0] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000@0] NR_IRQS:64 nr_irqs:64 0 [ 0.000005@0] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483648000ns [ 0.007385@0] mclk->mux_reg =ffffff8000004990,mclk->reg =ffffff8000008994 [ 0.014236@0] local timer MESON TIMER-G mclk->mux_reg =ffffff8000004990,mclk->reg =ffffff800000a998 [ 0.023312@0] local timer MESON TIMER-H mclk->mux_reg =ffffff8000004990,mclk->reg =ffffff800000c99c [ 0.032413@0] local timer MESON TIMER-I mclk->mux_reg =ffffff8000004990,mclk->reg =ffffff800000e9a0 [ 0.041502@0] Switching to timer-based delay loop [ 0.046484@0] Console: colour dummy device 80x25 [ 0.050869@0] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=10000) [ 0.061271@0] pid_max: default: 32768 minimum: 301 [ 0.066147@0] Security Framework initialized [ 0.070378@0] SELinux: Initializing. [ 0.074102@0] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes) [ 0.080967@0] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes) [ 0.089979@0] device-tree: Duplicate name in /efusekey, renamed to "key0#1" [ 0.095321@0] device-tree: Duplicate name in /efusekey, renamed to "key1#1" [ 0.102311@0] device-tree: Duplicate name in /efusekey, renamed to "key2#1" [ 0.109317@0] device-tree: Duplicate name in /efusekey, renamed to "key3#1" [ 0.118249@0] Initializing cgroup subsys debug [ 0.120777@0] Initializing cgroup subsys freezer [ 0.125438@0] ftrace: allocating 32996 entries in 129 pages [ 0.159903@0] /cpus/cpu@0: Missing clock-frequency property [ 0.159944@0] /cpus/cpu@1: Missing clock-frequency property [ 0.165538@0] /cpus/cpu@2: Missing clock-frequency property [ 0.171122@0] /cpus/cpu@3: Missing clock-frequency property [ 0.176729@0] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available [ 0.225809@0] Meson chip version = RevB (1F:B - 0:0-12) [ 0.244968@1] CPU1: Booted secondary processor [ 0.264938@2] CPU2: Booted secondary processor [ 0.284942@3] CPU3: Booted secondary processor [ 0.284996@0] Brought up 4 CPUs [ 0.295954@0] SMP: Total of 4 processors activated. [ 0.301336@0] devtmpfs: initialized [ 0.308469@0] instabooting: 0 [ 0.316909@0] pinctrl core: initialized pinctrl subsystem [ 0.317489@0] regulator-dummy: no parameters [ 0.321587@0] NET: Registered protocol family 16 [ 0.326197@0] ramoops: using module parameters [ 0.330598@0] console [pstore-1] enabled [ 0.334079@0] pstore: Registered ramoops as persistent store backend [ 0.340479@0] ramoops: attached 0x100000@0x20000000, ecc: 0/0 [ 0.346895@0] register canvas platform driver [ 0.350619@0] codec:ignore bus ops for cpu=25 [ 0.355002@0] codec:ignore bus ops for cpu=29 [ 0.359368@0] codec:register amports ops for bus[0] [ 0.364273@0] codec:register amports ops for bus[4] [ 0.369167@0] codec:register amports ops for bus[3] [ 0.374066@0] codec:register amports ops for bus[2] [ 0.378972@0] codec:register amports ops for bus[1] [ 0.383866@0] codec:register amports ops for bus[13] [ 0.388859@0] codec:register amports ops for bus[2] [ 0.393754@0] codec:register amports ops for bus[14] [ 0.398809@0] register rdma platform driver [ 0.403305@0] vdso: 2 pages (1 code, 1 data) at base ffffffc001dff000 [ 0.409447@0] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.416948@0] DMA: preallocated 256 KiB pool for atomic allocations [ 0.423904@0] software IO TLB [mem 0x34800000-0x34c00000] (4MB) mapped at [ffffffc034800000-ffffffc034bfffff] [ 0.432700@0] Serial: AMBA PL011 UART driver [ 0.437239@0] hdmitx: system: amhdmitx_init [ 0.441180@0] hdmitx: system: Ver: 2014May6 [ 0.445449@0] aml_i2c version: 20140813 [ 0.449300@0] tv_vout: tv_init_module [ 0.452909@0] tv_vout: major number 254 for disp [ 0.457550@0] vout_notify: vout_register_server [ 0.462093@0] tv_vout: register tv module server ok [ 0.467064@0] codec_mm:codec_mm_module_init [ 0.471357@0] gxbb clk HIU base is 0xffffff800002a000 [ 0.476274@0] gxbb clk ao base is 0xffffff800002c000 [ 0.481286@0] register mpll_clk_out0 success done [ 0.485989@0] register mpll_clk_out1 success done [ 0.490707@0] register mpll_clk_out2 success done [ 0.495594@0] register sys pll success done [ 0.499665@0] clkrate [ xtal ] : 24000000Hz [ 0.503918@0] clkrate [ 32Khz ] : 32000Hz [ 0.508037@0] clkrate [ clk81 ] : 166666666Hz [ 0.512492@0] clkrate [ fixed_pll ] : 2000000000Hz [ 0.517399@0] clkrate [ fclk_div2 ] : 1000000000Hz [ 0.522292@0] clkrate [ fclk_div3 ] : 666666666Hz [ 0.527110@0] clkrate [ fclk_div4 ] : 500000000Hz [ 0.531917@0] clkrate [ fclk_div5 ] : 400000000Hz [ 0.536735@0] clkrate [ fclk_div7 ] : 285714285Hz [ 0.541561@0] gxbb clock initialization complete [ 0.546286@0] msr_clk_reg0=ffffff800002e75c,msr_clk_reg2=ffffff8 00003a764 [ 0.554389@0] amlogic iomap probe done [ 0.557046@0] Init pinux probe! [ 0.560611@0] pinmux-gxbb c1109880.pinmux: Probed amlogic pinctrl driver [ 0.566955@0] genirq: Setting trigger mode 8 for irq 241 failed (gic_set_type+0x0/0xbc) [ 0.574721@0] genirq: Setting trigger mode 8 for irq 242 failed (gic_set_type+0x0/0xbc) [ 0.582861@0] genirq: Setting trigger mode 8 for irq 241 failed (gic_set_type+0x0/0xbc) [ 0.590819@0] genirq: Setting trigger mode 8 for irq 242 failed (gic_set_type+0x0/0xbc) [ 0.599913@0] codec:codec map io source 0x00000000c1100000,size=1048576 to 0xffffff8000800000 [ 0.607449@0] codec:codec map io source 0x00000000c8820000,size=65536 to 0xffffff80003a0000 [ 0.615842@0] codec:codec map io source 0x00000000c883c000,size=8192 to 0xffffff800007c000 [ 0.624160@0] codec:codec map io source 0x00000000c8100000,size=1048576 to 0xffffff8000980000 [ 0.632732@0] codec:codec map io source 0x00000000d0100000,size=262144 to 0xffffff8000b00000 [ 0.641216@0] codec:codec map io source 0x00000000c8838000,size=1024 to 0xffffff800006e000 [ 0.649623@0] codec_mm has 2 memory regions [ 0.653730@0] codec_mm codec_mm.15: assigned reserved memory node linux,codec_mm_cma ok [ 0.661780@0] codec_mm:codec_mm_reserved_init 0000000023700000->0000000027800000 [ 0.669213@0] codec_mm codec_mm.15: assigned reserved memory node linux,codec_mm_reserved ok [ 0.677697@0] codec_mm:codec_mm_probe mem init done [ 0.682595@0] codec_mm:add reserve memory 0000000023700000(aligned 0000000023700000) size=4100000(aligned 4100000) [ 0.693073@0] codec_mm has 2 memory regions [ 0.697215@0] codec_mm codec_mm.15: assigned reserved memory node linux,codec_mm_cma ok [ 0.705262@0] codec_mm:codec_mm_reserved_init 0000000023700000->0000000027800000 [ 0.712694@0] codec_mm codec_mm.15: assigned reserved memory node linux,codec_mm_reserved ok [ 0.721185@0] codec_mm:codec_mm reserved memory probed done [ 0.726784@0] codec_mm:codec_mm_probe ok [ 0.731840@0] VPU driver version: v01 [ 0.734404@0] vpu driver detect cpu type: gxbaby [ 0.739040@0] load vpu_clk in dts: 666667000Hz(7) [ 0.743816@0] vpu_probe OK [ 0.747370@0] hdmitx: system: amhdmitx_probe [ 0.750979@0] ------------[ cut here ]------------ [ 0.755590@0] WARNING: CPU: 0 PID: 1 at drivers/base/core.c:552 device_create_file+0x84/0xbc() [ 0.764236@0] Attribute phy: read permission without 'show' [ 0.769830@0] Modules linked in: [ 0.773071@0] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.14.29 #1 [ 0.779286@0] Call trace: [ 0.781910@0] [<ffffffc001088e74>] dump_backtrace+0x0/0x144 [ 0.787512@0] [<ffffffc001088fd4>] show_stack+0x1c/0x28 [ 0.792758@0] [<ffffffc0019b3044>] dump_stack+0x74/0xb8 [ 0.798013@0] [<ffffffc00109996c>] warn_slowpath_common+0x98/0xc0 [ 0.804131@0] [<ffffffc001099a08>] warn_slowpath_fmt+0x74/0x88 [ 0.810000@0] [<ffffffc001452974>] device_create_file+0x80/0xbc [ 0.815951@0] [<ffffffc0015ff51c>] amhdmitx_probe+0x1b4/0x938 [ 0.821720@0] [<ffffffc001459958>] platform_drv_probe+0x28/0x60 [ 0.827675@0] [<ffffffc0014578c4>] really_probe+0xd4/0x244 [ 0.833181@0] [<ffffffc001457a98>] __device_attach+0x64/0x74 [ 0.838874@0] [<ffffffc001455a10>] bus_for_each_drv+0x64/0xa8 [ 0.844648@0] [<ffffffc0014577d0>] device_attach+0x98/0xb8 [ 0.850156@0] [<ffffffc001456ce0>] bus_probe_device+0x98/0xc0 [ 0.855937@0] [<ffffffc001454960>] device_add+0x434/0x514 [ 0.861358@0] [<ffffffc0015d5638>] of_device_add+0x58/0x94 [ 0.866874@0] [<ffffffc0015d5e54>] of_platform_device_create_pdata+0x70/0xb0 [ 0.873957@0] [<ffffffc0015d5fa4>] of_platform_bus_create+0xcc/0x2a4 [ 0.880350@0] [<ffffffc0015d62a0>] of_platform_populate+0x4c/0xb8 [ 0.886477@0] [<ffffffc001cf8290>] arm64_device_init+0x24/0x34 [ 0.892331@0] [<ffffffc0010816a4>] do_one_initcall+0xd4/0x138 [ 0.898112@0] [<ffffffc001cf6914>] kernel_init_freeable+0x13c/0x1dc [ 0.904414@0] [<ffffffc0019acd2c>] kernel_init+0x1c/0xdc [ 0.909755@0] ---[ end trace 88dd2edeb32340e3 ]--- [ 0.914574@0] ------------[ cut here ]------------ [ 0.919370@0] WARNING: CPU: 0 PID: 1 at drivers/base/core.c:552 device_create_file+0x84/0xbc() [ 0.928035@0] Attribute hdcp_ctrl: read permission without 'show' [ 0.934154@0] Modules linked in: [ 0.937394@0] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 3.14.29 #1 [ 0.944571@0] Call trace: [ 0.947195@0] [<ffffffc001088e74>] dump_backtrace+0x0/0x144 [ 0.952794@0] [<ffffffc001088fd4>] show_stack+0x1c/0x28 [ 0.958048@0] [<ffffffc0019b3044>] dump_stack+0x74/0xb8 [ 0.963293@0] [<ffffffc00109996c>] warn_slowpath_common+0x98/0xc0 [ 0.969423@0] [<ffffffc001099a08>] warn_slowpath_fmt+0x74/0x88 [ 0.975286@0] [<ffffffc001452974>] device_create_file+0x80/0xbc [ 0.981231@0] [<ffffffc0015ff564>] amhdmitx_probe+0x1fc/0x938 [ 0.987011@0] [<ffffffc001459958>] platform_drv_probe+0x28/0x60 [ 0.992956@0] [<ffffffc0014578c4>] really_probe+0xd4/0x244 [ 0.998473@0] [<ffffffc001457a98>] __device_attach+0x64/0x74 [ 1.004155@0] [<ffffffc001455a10>] bus_for_each_drv+0x64/0xa8 [ 1.009936@0] [<ffffffc0014577d0>] device_attach+0x98/0xb8 [ 1.015448@0] [<ffffffc001456ce0>] bus_probe_device+0x98/0xc0 [ 1.021219@0] [<ffffffc001454960>] device_add+0x434/0x514 [ 1.026649@0] [<ffffffc0015d5638>] of_device_add+0x58/0x94 [ 1.032157@0] [<ffffffc0015d5e54>] of_platform_device_create_pdata+0x70/0xb0 [ 1.039250@0] [<ffffffc0015d5fa4>] of_platform_bus_create+0xcc/0x2a4 [ 1.045636@0] [<ffffffc0015d62a0>] of_platform_populate+0x4c/0xb8 [ 1.051756@0] [<ffffffc001cf8290>] arm64_device_init+0x24/0x34 [ 1.057623@0] [<ffffffc0010816a4>] do_one_initcall+0xd4/0x138 [ 1.063394@0] [<ffffffc001cf6914>] kernel_init_freeable+0x13c/0x1dc [ 1.069699@0] [<ffffffc0019acd2c>] kernel_init+0x1c/0xdc [ 1.075034@0] ---[ end trace 88dd2edeb32340e4 ]--- [ 1.080024@0] hdmitx: system: not find match pwr-ctl [ 1.084838@0] hdmitx hpd irq = 89 [ 1.088509@0] hdmitx20: Mapped PHY: 0xc0800000 [ 1.092621@0] hdmitx20: Mapped PHY: 0xc1104400 [ 1.097101@0] hdmitx20: Mapped PHY: 0xc8100000 [ 1.101544@0] hdmitx20: Mapped PHY: 0xc8834000 [ 1.106012@0] hdmitx20: Mapped PHY: 0xc883a000 [ 1.110468@0] hdmitx20: Mapped PHY: 0xc883c000 [ 1.114939@0] hdmitx20: Mapped PHY: 0xd0100000 [ 1.119393@0] hdmitx20: Mapped PHY: 0xda83a000 [ 1.123862@0] hdmitx: alread display in uboot 0x10 [ 1.128689@0] avmute set to 1 [ 1.132210@0] canvas_probe reg=00000000c8838000,size=400 [ 1.137003@0] canvas maped reg_base =ffffff800008e000 [ 1.142057@0] hdmitx: system: irq 2 [ 1.148764@0] rdma_probe [ 1.202155@0] bio: create slab <bio-0> at 0 [ 1.202879@0] SCSI subsystem initialized [ 1.205173@0] usbcore: registered new interface driver usbfs [ 1.210525@0] usbcore: registered new interface driver hub [ 1.216029@0] usbcore: registered new device driver usb [ 1.221852@0] i2c-gpio i2c_gpio.30: using pins 153 (SDA) and 154 (SCL) [ 1.227819@0] Linux video capture interface: v2.00 [ 1.232693@0] pps_core: LinuxPPS API ver. 1 registered [ 1.237707@0] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]> [ 1.247149@0] PTP clock support registered [ 1.251583@0] logo: logo_init [ 1.254148@0] tv_vout: tv_set_current_vmode[672]fps_target_mode=12 [ 1.260369@0] tv_vout: mode is 12,sync_duration_den=1,sync_duration_num=60 [ 1.267277@0] switch_vpu_mem_pd: vencp ON [ 1.271295@0] tv_vout: TV mode 1080p60hz selected. [ 1.276110@0] tv_vout: already display in uboot [ 1.280655@0] tv_vout: new mode =1080p60hz set ok [ 1.285387@0] vout_serve: vinfo mode is: 1080p60hz [ 1.290193@0] logo: set vmode: 1080p60hz [ 1.294131@0] switch_vpu_mem_pd: viu_osd1 ON [ 1.298423@0] switch_vpu_mem_pd: viu_osd2 ON [ 1.302705@0] switch_vpu_mem_pd: viu_osd_scale ON [ 1.307635@0] osd_rdma: osd_rdma_init: rmda_table p=0x36841000,op=0x36841000 , v=0xffffff8000099000 [ 1.316677@0] Advanced Linux Sound Architecture Driver Initialized. [ 1.323320@0] Bluetooth: Core ver 2.18 [ 1.326670@0] NET: Registered protocol family 31 [ 1.331239@0] Bluetooth: HCI device and connection manager initialized [ 1.337803@0] Bluetooth: HCI socket layer initialized [ 1.342870@0] Bluetooth: L2CAP socket layer initialized [ 1.348143@0] Bluetooth: SCO socket layer initialized [ 1.353492@0] cfg80211: Calling CRDA to update world regulatory domain ----- continued in next post ......
..... continued from previous post - post 2 of 3. -------
Code:1.359854@0] NetLabel: Initializing [ 1.363342@0] NetLabel: domain hash size = 128 [ 1.367903@0] NetLabel: protocols = UNLABELED CIPSOv4 [ 1.373086@0] NetLabel: unlabeled traffic allowed by default [ 1.379471@1] Switched to clocksource Timer-E [ 1.422803@1] NET: Registered protocol family 2 [ 1.423215@1] TCP established hash table entries: 8192 (order: 4, 65536 bytes) [ 1.429085@1] TCP bind hash table entries: 8192 (order: 5, 131072 bytes) [ 1.435944@1] TCP: Hash tables configured (established 8192 bind 8192) [ 1.442400@1] TCP: reno registered [ 1.445744@1] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 1.451903@3] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 1.458602@3] NET: Registered protocol family 1 [ 1.463192@3] RPC: Registered named UNIX socket transport module. [ 1.469103@3] RPC: Registered udp transport module. [ 1.469532@0] hdmitx: plugin [ 1.470172@0] hdmitx: system: [edid_tx_segaddr] err = -6 [ 1.470174@0] hdmitx: system: [gpio_read_edid] setptr = 0 [ 1.487666@3] RPC: Registered tcp transport module. [ 1.492560@3] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 1.499356@3] [wifi_dev_probe] wifi_dev_probe [ 1.503589@3] [wifi_dev_probe] wifi_dt : interrupt_pin= [ 1.508860@3] [wifi_dev_probe] wifi_dt : irq_num=null [ 1.513922@3] [wifi_dev_probe] wifi_dt : irq_trigger_type=GPIO_IRQ_HIGH [ 1.520562@3] [wifi_dev_probe] wifi_dt : power_on_pin= [ 1.525719@3] [wifi_dev_probe] set pwm as 32k output [ 1.530568@3] [wifi_dev_probe] interrupt_pin=235 [ 1.535341@3] [wifi_dev_probe] irq_num=100, irq_trigger_type=0 [ 1.540075@0] hdmitx: system: [edid_tx_segaddr] err = -6 [ 1.540076@0] hdmitx: system: [gpio_read_edid] setptr = 0 [ 1.551974@3] [wifi_dev_probe] power_on_pin=248 [ 1.556516@3] [wifi_dev_probe] clock_32k_pin=0 [ 1.561402@3] Unpacking initramfs... [ 1.582666@0] hdmitx: edid: check sum valid [ 1.582704@0] hdmitx: edid: check sum valid [ 1.585488@0] hdmitx: edid: blk0 raw data [ 1.589559@0] 00ffffffffffff0026cde446502d31011e11010381211b78ea aea5a6544c9926 [ 1.589559@0] 145054bfef00818001010101010101010101010101019e2000 9051201f304880 [ 1.589559@0] 3600510e1100001c000000fc0048444d490a0a0a0a0a0a0a0a 0a000000fd0037 [ 1.589559@0] 4c1d520e000a202020202020000000ff003538363637333030 303030310a01d6 [ 1.589559@0] [ 1.589559@0] [ 1.621916@0] hdmitx: edid: blk1 raw data [ 1.625944@0] 020321714e0607020315961112130414051f90230907078301 000065030c0010 [ 1.625944@0] 008c0ad090204031200c405500b98821000018011d8018711c 1620582c2500b9 [ 1.625944@0] 882100009e011d80d0721c1620102c2580b9882100009e011d 00bc52d01e20b8 [ 1.625944@0] 285540b9882100001e023a80d072382d40102c4580b9882100 001e00000000d0 [ 1.625944@0] [ 1.625944@0] [ 1.658329@0] EDID Parser: [ 1.661330@0] hdmitx: edid: find IEEEOUT [ 1.664999@0] [ 1.665358@3] Freeing initrd memory: 3148K (ffffffc033baf000 - ffffffc033ec2000) [ 1.667356@3] futex hash table entries: 1024 (order: 4, 65536 bytes) [ 1.667438@3] audit: initializing netlink subsys (disabled) [ 1.667487@3] audit: type=2000 audit(1.620:1): initialized [ 1.668253@3] HugeTLB registered 2 MB page size, pre-allocated 0 pages [ 1.674666@3] VFS: Disk quotas dquot_6.5.2 [ 1.674865@3] Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 1.678825@3] NFS: Registering the id_resolver key type [ 1.678863@3] Key type id_resolver registered [ 1.678864@3] Key type id_legacy registered [ 1.678886@3] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc. [ 1.679660@1] fuse init (API version 7.22) [ 1.680207@1] msgmni has been set to 1613 [ 1.738141@0] hdmitx: video: get current mode: 1080p60hz [ 1.739349@1] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248) [ 1.739356@1] io scheduler noop registered [ 1.739358@1] io scheduler deadline registered [ 1.739541@1] io scheduler cfq registered (default) [ 1.764552@0] hdmitx: system: [set_disp_mode_auto] ALREADY init VIC = 16 [ 1.771267@0] hdmtix: set audio [ 1.774410@0] hdmitx tx_aud_src = 0 [ 1.777908@0] hdmitx: system: irq 80000001 [ 1.782098@0] hdmitx aud_n_para = 24576 [ 1.785889@0] Start = 0x10000100 End = 0x100001ff [ 1.788483@1] meson-rng c8834000.rng: hwrng registered [ 1.792559@1] loop: module loaded [ 1.793030@1] zram: Created 1 device(s) ... [ 1.793714@1] mtdoops: mtd device (mtddev=name/number) must be supplied [ 1.794185@1] tun: Universal TUN/TAP device driver, 1.6 [ 1.794187@1] tun: (C) 1999-2004 Max Krasnyansky <[email protected]> [ 1.802641@1] libphy: stmmac: probed [ 1.802649@1] eth0: PHY ID 001cc916 at 0 IRQ POLL (stmmac-0:00) active [ 1.802652@1] eth0: PHY ID 001cc916 at 7 IRQ POLL (stmmac-0:07) [ 1.803050@1] PPP generic driver version 2.4.2 [ 1.803302@1] PPP BSD Compression module registered [ 1.803304@1] PPP Deflate Compression module registered [ 1.803321@1] PPP MPPE Compression module registered [ 1.803325@1] NET: Registered protocol family 24 [ 1.803465@1] usbcore: registered new interface driver asix [ 1.803603@1] usbcore: registered new interface driver ax88179_178a [ 1.803678@1] usbcore: registered new interface driver cdc_ether [ 1.803753@1] usbcore: registered new interface driver net1080 [ 1.803830@1] usbcore: registered new interface driver cdc_subset [ 1.803903@1] usbcore: registered new interface driver zaurus [ 1.804008@1] usbcore: registered new interface driver cdc_ncm [ 1.804259@1] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.804262@1] ehci-h20ahb: H20AHB-EHCI Host Controller driver [ 1.804423@1] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 1.804528@1] usbcore: registered new interface driver cdc_acm [ 1.804530@1] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 1.804618@1] usbcore: registered new interface driver usb-storage [ 1.804801@1] usbcore: registered new interface driver usbserial [ 1.805430@1] mousedev: PS/2 mouse device common for all mice [ 1.805855@1] i2c /dev entries driver [ 1.806142@1] usbcore: registered new interface driver uvcvideo [ 1.806143@1] USB Video Class driver (1.1.1) [ 1.806888@1] device-mapper: ioctl: 4.27.0-ioctl (2013-10-30) initialised: [EMAIL="[email protected]"][email protected][/EMAIL] [ 1.806959@1] Bluetooth: HCI UART driver ver 2.2 [ 1.806962@1] Bluetooth: HCI H4 protocol initialized [ 1.807713@1] usbcore: registered new interface driver usbhid [ 1.807715@1] usbhid: USB HID core driver [ 1.808028@1] ashmem: initialized [ 1.808191@1] logger: created 256K log 'log_main' [ 1.808331@1] logger: created 256K log 'log_events' [ 1.808461@1] logger: created 256K log 'log_radio' [ 1.808593@1] logger: created 256K log 'log_system' [ 1.809007@1] ==uart0 reg addr = ffffff80000ca4c0 [ 1.809032@1] c81004c0.serial: ttyS0 at MMIO 0xc81004c0 (irq = 225, base_baud = 1500000) is a meson_uart [ 2.033654@0] hdmitx set channel status [ 2.037502@0] [0x10000103]: 0x00000008 [ 2.041196@0] [0x10000104]: 0x00000001 [ 2.045048@0] [0x10000170]: 0x00000010 [ 2.048731@0] [0x10000180]: 0x000000ff [ 2.052482@0] [0x10000181]: 0x000000ff [ 2.056238@0] [0x10000182]: 0x00000003 [ 2.060008@0] [0x10000183]: 0x00000007 [ 2.063766@0] [0x10000184]: 0x0000003f [ 2.067533@0] [0x10000185]: 0x00000002 [ 2.071298@0] [0x10000187]: 0x000000ff [ 2.075051@0] [0x10000188]: 0x00000003 [ 2.084326@1] ttyS0 use xtal 24000000 change 0 to 115200 [ 2.084366@1] console [ttyS0] enabled [ 2.084366@1] console [ttyS0] enabled [ 2.091446@1] bootconsole [earlycon0] disabled [ 2.091446@1] bootconsole [earlycon0] disabled [ 2.100633@1] ==uart1 reg addr = ffffff80000de4c0 [ 2.104784@1] c11084c0.serial: ttyS1 at MMIO 0xc11084c0 (irq = 58, base_baud = 1500000) is a meson_uart [ 2.114507@1] ESM HLD: Initializing... [ 2.117791@1] ESM HLD: Registering device range 'esm'... [ 2.123064@1] ESM HLD: Device range 'esm' has been registered. [ 2.128831@1] ESM HLD: Creating class /sys/class/elliptic... [ 2.134512@1] ESM HLD: The class /sys/class/elliptic has been created. [ 2.140917@1] ESM HLD: Creating device 'esm'... [ 2.145508@1] ESM HLD: Device 'esm' has been created. [ 2.150400@1] ESM HLD: Done initializing the HLD driver. INFO: HDCP22 key read fail! INFO: p1d 0 INFO: pd1 0 [ 2.175994@1] aml_vrtc rtc.25: rtc core: registered aml_vrtc as rtc0 [ 2.176870@1] secmon has 1 memory regions [ 2.180697@1] secmon: share in base: 0xffffff80000fc000, share out base: 0xffffff80000fe000 [ 2.188949@1] secmon secmon.3: assigned reserved memory node linux,secmon ok [ 2.195939@1] secmon: probe done [ 2.199297@1] storage: storage in base: 0xffffff8001800000 [ 2.204565@1] storage: storage out base: 0xffffff8001880000 [ 2.210084@1] storage: storage block base: 0xffffff8001900000 [ 2.215769@1] storage: probe done! [ 2.219504@1] aml_sd_emmc_probe: line 3202 [ 2.223190@1] mmc driver version: 1.07, 2015-01-21: fix a bug in tuning which caused eMMC data CRC error [ 2.232939@3] aml_sd_emmc_reg_init 796 [ 2.236382@3] pdata->caps 7 [ 2.239058@3] pdata->caps2 0 [ 2.241914@3] get property: port, value:0x00000001 [ 2.248373@3] get property: ocr_avail, value:0x00200080 [ 2.254848@3] get property: f_min, value:0x00061a80 [ 2.261317@3] get property: f_max, value:0x05f5e100 [ 2.267780@3] get property: max_req_size, value:0x00020000 [ 2.274255@3] get property: irq_in, value:0x00000003 [ 2.280723@3] get property: irq_out, value:0x00000005 [ 2.287194@3] get property: gpio_cd, str: [ 2.292626@3] get property: pinname, str:sd [ 2.298227@3] get property: jtag_pin, str: [ 2.303666@3] get property: card_type, value:0x00000005 [ 2.310136@3] get property: gpio_dat3, str: [ 2.315583@3] [aml_is_card_insert] card OUT [ 2.360644@1] [aml_sd_emmc_probe] aml_sd_emmc_probe() success! [ 2.361019@1] aml_sd_emmc_probe: line 3202 [ 2.380584@1] [aml_is_card_insert] card OUT [ 2.380634@3] [aml_is_card_insert] card OUT [ 2.380634@3] [ 2.387508@1] aml_sd_emmc_reg_init 796 [ 2.391132@1] pdata->caps 80000d47 [ 2.394396@1] pdata->caps2 60 [ 2.397327@1] get property: ocr_avail, value:0x00200080 [ 2.403804@1] get property: f_min, value:0x000493e0 [ 2.410271@1] get property: f_max, value:0x0bebc200 [ 2.416734@1] get property: max_req_size, value:0x00020000 [ 2.423211@1] get property: pinname, str:emmc [ 2.428981@1] get property: card_type, value:0x00000001 [ 2.435457@1] get property: gpio_dat3, str: [ 2.440891@1] get property: hw_reset, str: [ 2.446322@1] storage 1, boot 1 [ 2.449421@1] get_storage_dev return 1 [ 2.489489@0] [aml_sd_emmc_probe] aml_sd_emmc_probe() success! [ 2.489688@0] aml_sd_emmc_probe: line 3202 [ 2.493750@0] aml_emmc_hw_reset 1311 [ 2.499669@1] aml_sd_emmc_reg_init 796 [ 2.501050@1] pdata->caps 7810f [ 2.504078@1] pdata->caps2 0 [ 2.506925@1] get property: ocr_avail, value:0x00200080 [ 2.513414@1] get property: f_min, value:0x00061a80 [ 2.519949@1] get property: f_max, value:0x0bebc200 [ 2.526332@1] get property: max_req_size, value:0x00020000 [ 2.532808@1] get property: pinname, str:sdio [ 2.538578@1] get property: card_type, value:0x00000003 [ 2.579489@0] [aml_sd_emmc_probe] aml_sd_emmc_probe() success! [ 2.579885@0] ion_dev has 1 memory regions [ 2.583874@0] emmc: BKOPS_EN bit is not set [ 2.594980@1] ============================================ [ 2.595037@1] trying cali emmc 0-th time(s) [ 2.601452@0] fb: osd_init_module [ 2.602330@0] fb: viu vsync irq: 35 [ 2.605713@0] meson-fb has 1 memory regions [ 2.610208@0] meson-fb meson-fb.12: assigned reserved memory node linux,meson-fb ok [ 2.617448@0] fb: osd_probe vinfo:ffffffc001e89700 [ 2.622191@0] fb: Frame buffer memory assigned at [ 2.626668@0] fb: phy: 0x3e000000, vir:0xffffff8003c00000, size=24576K [ 2.633677@0] fb: init fbdev bpp is:32 [ 2.637362@0] fb: ---------------clear fb0 memory [ 2.649733@0] fb: osd[0] canvas.idx =0x40 [ 2.649752@0] fb: osd[0] canvas.addr=0x3e000000 [ 2.652613@0] fb: osd[0] canvas.width=7680 [ 2.656665@0] fb: osd[0] canvas.height=3240 [ 2.664370@0] fb: Frame buffer memory assigned at [ 2.665292@0] fb: phy: 0x3f800000, vir:0xffffff8005480000, size=1024K [ 2.680954@0] fb: osd probe OK [ 2.681132@0] vout_serve: vout_init_module [ 2.682518@0] vout_serve: meson_vout_probe [ 2.686577@0] vout_serve: create vout attribute OK [ 2.691377@0] ge2d: ge2d_init_module [ 2.694794@0] ge2d: ge2d_dev major:244 [ 2.698787@0] ge2d: ge2d clock is 400 MHZ [ 2.702476@0] ge2d: ge2d: pdev=ffffffc034e56600, irq=182, rstc=0xffffffc03428a8c0, clk=ffffffc034da5b00 [ 2.711828@0] ge2d: mapped phy: 0xd0160000 [ 2.715841@0] ge2d: ge2d start monitor [ 2.719595@1] ge2d: ge2d workqueue monitor start [ 2.719735@0] aml_sysled_init: module init [ 2.719881@0] aml_sysled_dt_parse: active_low = 1 [ 2.720017@0] aml_sysled_probe: module probed ok [ 2.720130@0] codec:Amlogic A/V streaming port init [ 2.743603@0] codec:get gate demux control ok ffffffc02293cd00 [ 2.747997@0] codec:get gate parser_top control ok ffffffc02293c900 [ 2.754225@0] codec:get gate vpu_intr control ok ffffffc02293c500 [ 2.760269@0] codec:get gate vdec control ok ffffffc02293c100 [ 2.766481@0] codec:[tsync_pcr_init]init success. [ 2.770711@0] codec:regist mpeg12 codec profile [ 2.775173@0] codec:regist mpeg4 codec profile [ 2.779496@0] codec:amvdec_vc1 module init [ 2.783630@0] codec:regist vc1 codec profile [ 2.787765@0] codec:amvdec_h264 module init [ 2.792015@0] codec:regist h264 codec profile [ 2.796219@0] codec:amvdec_h264mvc module init [ 2.800714@0] codec:regist hmvc codec profile [ 2.804929@0] codec:amvdec_h264_4k2k module init [ 2.809596@0] codec:regist h264_4k2k codec profile [ 2.814245@0] codec:amvdec_h265 module init [ 2.818471@0] codec:regist hevc codec profile [ 2.822789@0] codec:regist mjpeg codec profile [ 2.827097@0] codec:amvdec_real module init [ 2.831332@0] codec:regist real codec profile [ 2.835548@0] codec:amvdec_avs module init [ 2.839691@0] codec:regist avs codec profile [ 2.843887@0] amvenc_avc_probe -- reserved memory config fail. [ 2.849620@0] amvenc_avc - cma memory pool size: 32 MB [ 2.854709@0] encode_wq_init. [ 2.857629@0] encode start monitor. [ 2.861134@1] encode workqueue monitor start. ------- continued in next post ....... next (3/3)
----------- continuation of previous post - (post 3/3)
Code:[ 2.865639@0] jpegenc module init [ 2.868870@0] codecicdec_driver_probe called. [ 2.873171@0] picdec has 1 memory regions [ 2.877150@0] picdec picdec.20: assigned reserved memory node linux,picdec ok [ 2.884214@0] codecicdec_driver_probe done. [ 2.888512@0] codec:reserved memory config fail , use CMA . [ 2.896422@0] codec:cma memory is 37000000 , size is 3000000 [ 2.900149@0] codec:0 addr is 37000000################ [ 2.904821@0] codec:1 addr is 372fd000################ [ 2.910071@0] switch_vpu_mem_pd: vpu_arb ON [ 2.914501@0] codec:create_ge2d_work_queue video task ok [ 2.919747@0] codec:register clk_set_setting cpu[31] [ 2.924470@0] di_module_init ok. [ 2.927422@0] di_module_init: major 240 [ 2.931517@0] di_probe [ 2.933727@0] deinterlace has 1 memory regions [ 2.937956@0] di reveser memory 0x3c200000, size 30MB. [ 2.943040@0] deinterlace deinterlace.22: assigned reserved memory node linux,di ok [ 2.950788@0] rdma_register, rdma_table_addr ffffff8000159000 rdma_table_addr_phy 36848000 reg_buf ffffffc0342d4000 [ 2.960971@0] rdma_register success, handle 1 table_size 8192 [ 2.966668@0] di_probe allocate rdma channel 1. [ 2.971148@0] DI hw version 2. [ 2.974164@0] 0x000000c3:Y=c3,U=0,V=0 [ 2.977782@0] 0x000000c4:Y=c4,U=0,V=0 [ 2.981414@3] 0x000000c5:Y=c5,U=0,V=0 [ 2.985000@3] 0x000000c6:Y=c6,U=0,V=0 [ 2.988622@3] 0x000000c7:Y=c7,U=0,V=0 [ 2.992273@3] 0x000000c8:Y=c8,U=0,V=0 [ 2.993273@0] delay[0]= 3125 padding= 7, bidx=3 [ 2.993276@0] delay[1]= 3250 padding= 6, bidx=3 [ 2.993278@0] delay[2]= 4000 padding= 8, bidx=4 [ 2.993280@0] delay[3]= 3250 padding= 6, bidx=3 [ 2.993281@0] delay[4]= 3250 padding= 6, bidx=3 [ 2.993283@0] delay[5]= 3000 padding= 8, bidx=3 [ 2.993284@0] delay[6]= 3375 padding= 5, bidx=3 [ 2.993286@0] delay[7]= 2875 padding= 1, bidx=2 [ 2.993288@0] calibration result @ 0: max(4000), min(2875) [ 2.993290@0] line_delay =0x95866067 [ 2.993291@0] max_cal_result =4000 [ 2.993293@0] base_index_max 4, base_index_min 2 [ 2.993301@0] emmc: clk 200000000 SDR mode tuning start [ 2.993582@0] rx_tuning_result[0][0] = 10 [ 2.993853@0] rx_tuning_result[0][1] = 10 [ 2.994123@0] rx_tuning_result[0][2] = 10 [ 2.994417@0] rx_tuning_result[0][4] = 10 [ 2.994419@0] best_win_start =4, best_win_size =4 [ 2.994421@0] emmc: adj_win_start 6 [ 2.994423@0] emmc:sd_emmc_regs->gclock=0x1000245,sd_emmc_regs->gadjust=0x12007 [ 2.994426@0] emmc: gclock =0x1000245, gdelay=0x95866067, gadjust=0x12007 [ 2.994522@0] emmc: new HS200 MMC card at address 0001 [ 2.994925@0] emmc: clock 200000000, 8-bit-bus-width [ 2.994925@0] [ 2.994926@0] mmcblk0: emmc:0001 8WPD3R 7.28 GiB [ 2.995045@0] mmcblk0boot0: emmc:0001 8WPD3R partition 1 4.00 MiB [ 2.995153@0] mmcblk0boot1: emmc:0001 8WPD3R partition 2 4.00 MiB [ 2.995959@1] mmcblk0: unknown partition table [ 2.996547@0] [mmc_read_partition_tbl] mmc read partition OK! [ 2.996548@0] add_emmc_partition [ 2.996738@0] [mmcblk0p01] bootloader offset 0x000000000000, size 0x000000400000 [ 2.996874@0] [mmcblk0p02] reserved offset 0x000002400000, size 0x000004000000 [ 2.997020@0] [mmcblk0p03] cache offset 0x000006c00000, size 0x000020000000 [ 2.997159@0] [mmcblk0p04] env offset 0x000027400000, size 0x000000800000 [ 2.997290@0] [mmcblk0p05] logo offset 0x000028400000, size 0x000002000000 [ 2.997421@0] [mmcblk0p06] recovery offset 0x00002ac00000, size 0x000002000000 [ 2.997553@0] [mmcblk0p07] rsv offset 0x00002d400000, size 0x000000800000 [ 2.997728@0] [mmcblk0p08] tee offset 0x00002e400000, size 0x000000800000 [ 2.997860@0] [mmcblk0p09] crypt offset 0x00002f400000, size 0x000002000000 [ 2.997993@0] [mmcblk0p10] misc offset 0x000031c00000, size 0x000002000000 [ 2.998129@0] [mmcblk0p11] instaboot offset 0x000034400000, size 0x000020000000 [ 2.998259@0] [mmcblk0p12] boot offset 0x000054c00000, size 0x000002000000 [ 2.998411@0] [mmcblk0p13] system offset 0x000057400000, size 0x000040000000 [ 2.998543@0] [mmcblk0p14] data offset 0x000097c00000, size 0x00013a400000 [ 2.998583@0] card key: card_blk_probe. [ 2.998587@0] emmc_key_init:524 emmc key lba_start:0x12020,lba_end:0x12220 [ 2.998590@0] emmc key: emmc_key_init:549 ok. [ 2.998791@0] amlmmc_dtb_init: register dtb chardev [ 2.998864@0] amlmmc_dtb_init: register dtb chardev OK [ 2.998865@0] Exit aml_emmc_partition_ops OK. [ 3.000641@0] mmcblk0boot1: unknown partition table [ 3.001415@0] mmcblk0boot0: unknown partition table [ 3.289738@3] 0x000000c9:Y=c9,U=0,V=0 [ 3.293348@3] 0x000000ca:Y=ca,U=0,V=0 [ 3.296966@3] 0x000000cb:Y=cb,U=0,V=0 [ 3.300595@3] 0x000000cc:Y=cc,U=0,V=0 [ 3.304212@3] 0x000000cd:Y=cd,U=0,V=0 [ 3.307833@3] 0x000000ce:Y=ce,U=0,V=0 [ 3.311462@3] 0x000000cf:Y=cf,U=0,V=0 [ 3.315158@3] di_probe here. [ 3.317936@3] switch_vpu_mem_pd: di_pre OFF [ 3.322343@3] efusekeynum: 4 [ 3.324916@3] efusekeyname: mac offset: 0 size: 6 [ 3.331322@3] efusekeyname: mac_bt offset: 6 size: 6 [ 3.337679@3] efusekeyname: mac_wifi offset: 12 size: 6 [ 3.344080@3] efusekeyname: usid offset: 18 size: 16 [ 3.350688@0] efuse efuse.7: probe OK! [ 3.354372@0] key unify config unifykey-num is 11 [ 3.358835@0] key unify fact unifykey-num is 11 [ 3.363312@0] aml_unifykeys_probe:1087=============unifykey_devn o:ed00000 [ 3.370252@0] 6unifykey: device unifykeys created ok [ 3.375114@0] 6aml_unifykeys_init done! [ 3.378903@0] ppmgr module init func called [ 3.383118@0] ppmgr_driver_probe called [ 3.386840@0] ppmgr has 1 memory regions [ 3.390741@0] init ppmgr memsource 3a200000->3c1fffff [ 3.395958@0] ppmgr_probe done [ 3.399109@0] amlogic rfkill init [ 3.402350@0] ionvideo-000: V4L2 device registered as video13 [ 3.407716@0] [dsp]register dsp to char divece(257) [ 3.413213@0] amaudio: driver amaudio succuess! [ 3.417052@0] amlvideo_init called [ 3.420226@0] amlvideo_create_instance called [ 3.424703@0] v4l2_dev.name=:amlvideo-000 [ 3.428793@0] amlvideo-000: V4L2 device registered as video10 [ 3.434389@0] [ 3.434389@0] [ 3.434389@0] VECM init [ 3.434389@0] [ 3.442128@0] nandphy: storage 1, boot 1 [ 3.442128@0] [ 3.447300@0] nandphy: get_storage_dev return 1 [ 3.447300@0] [ 3.453453@0] aml_nand d0074800.nand: do not init nand [ 3.458771@0] saradc c1108680.saradc: initialized by BL30 [ 3.463872@0] saradc c1108680.saradc: calibration start: [ 3.469180@0] saradc c1108680.saradc: nominal=0, value=2 [ 3.474434@0] saradc c1108680.saradc: nominal=256, value=252 [ 3.480038@0] saradc c1108680.saradc: nominal=512, value=507 [ 3.485649@0] saradc c1108680.saradc: nominal=768, value=764 [ 3.491252@0] saradc c1108680.saradc: nominal=1023, value=1019 [ 3.496981@0] saradc c1108680.saradc: calibration end: coef=4096 [ 3.503071@0] remote: Driver init [ 3.506246@0] remote: platform_data g_remote_ao_offset=580 [ 3.511651@0] remote: platform_data irq =228 [ 3.515904@0] remote: set drvdata completed [ 3.520112@0] remote: device_create_file completed [ 3.525276@0] input: aml_keypad as /devices/meson-remote.9/input/input0 [ 3.531886@0] remote: input_register_device completed [ 3.536778@0] remote: [0x480] = 0x1dd0190 [ 3.540717@0] remote: [0x484] = 0xf800ca [ 3.544588@0] remote: [0x488] = 0x82006e [ 3.548486@0] remote: [0x48c] = 0x3c0030 [ 3.552351@0] remote: [0x490] = 0x30fa0013 [ 3.556405@0] remote: [0x498] = 0x6f19000 [ 3.560380@0] remote: [0x49c] = 0xbe40 [ 3.564081@0] remote: [0x580] = 0xfa00a0 [ 3.567962@0] remote: [0x584] = 0xfa00a0 [ 3.571843@0] remote: [0x588] = 0xfa00a0 [ 3.575725@0] remote: [0x58c] = 0x640030 [ 3.579613@0] remote: [0x590] = 0x30fa0013 [ 3.583660@0] remote: [0x598] = 0x961b800 [ 3.587627@0] remote: [0x59c] = 0x9740 [ 3.591336@0] remote: [0x5a0] = 0x104 [ 3.594959@0] remote: [0x5a4] = 0x0 [ 3.598420@0] remote: [0x5a8] = 0x0 [ 3.601859@0] remote: set_remote_mode[72] [ 3.605846@0] remote: remote config major:234 [ 3.610417@0] remote: physical address:0x224be000 [ 3.615245@0] gpio-key gpio_keypad.42: gpio_key: 0 name(power) pin() [ 3.621193@0] gpio-key gpio_keypad.42: amlogic_gpio_name_map_num pin 0!:: [ 3.627916@0] gpio-key gpio_keypad.42: gpio_key: 0 power(125) [ 3.633647@0] gpio-key gpio_keypad.42: start setup_timer [ 3.638864@0] gpio-key gpio_keypad.42: power key(116) registed. [ 3.644886@0] input: gpio_keypad as /devices/gpio_keypad.42/input/input1 [ 3.651528@0] gpio-key gpio_keypad.42: gpio keypad register input device completed. [ 3.658963@0] input input1: gpio keypad major:233 [ 3.664224@0] i2c-core: driver [mir3da] using legacy suspend method [ 3.669858@0] i2c-core: driver [mir3da] using legacy resume method [ 3.676017@0] i2c-core: driver [lis3dh_acc] using legacy suspend method [ 3.682537@2] i2c-core: driver [lis3dh_acc] using legacy resume method [ 3.689122@2] i2c-core: driver [bma222] using legacy suspend method [ 3.695190@2] i2c-core: driver [bma222] using legacy resume method [ 3.701456@2] i2c-core: driver [dmard06] using legacy suspend method [ 3.707602@2] i2c-core: driver [dmard06] using legacy resume method [ 3.713891@2] lsm303d driver: init [ 3.717304@2] i2c-core: driver [dmard10] using legacy suspend method [ 3.723480@2] i2c-core: driver [dmard10] using legacy resume method [ 3.729497@0] input input1: key 116 up [ 3.733475@2] stk8313_init [ 3.736134@2] ======stk831x init ok====== [ 3.740040@2] stk831x_init [ 3.742778@2] mxc622x accelerometer driver: init [ 3.747347@2] i2c-core: driver [mxc622x] using legacy suspend method [ 3.753580@2] i2c-core: driver [mxc622x] using legacy resume method [ 3.759790@2] mxc6255xc accelerometer driver: init [ 3.764599@2] i2c-core: driver [mxc6255xc] using legacy suspend method [ 3.771003@2] i2c-core: driver [mxc6255xc] using legacy resume method [ 3.777450@2] l3gd20_gyr: gyroscope sysfs driver init [ 3.782646@2] cm3217 v.1.0.0.1 [ 3.785462@2] i2c-core: driver [elan_epl6814] using legacy suspend method [ 3.792134@2] i2c-core: driver [elan_epl6814] using legacy resume method [ 3.798839@2] i2c-core: driver [LTR501] using legacy suspend method [ 3.804995@2] i2c-core: driver [LTR501] using legacy resume method [ 3.811309@2] aml dvb init [ 3.814844@0] usbcore: registered new interface driver snd-usb-audio [ 3.820562@0] dummy_codec_platform_probe [ 3.824085@0] *****enter pcm2bt_codec_probe [ 3.828220@0] enter aml_soc_platform_pcm2bt_probe [ 3.833126@0] divider=16,frac=33920000,SDMval=4523 [ 3.837648@0] enter aml_pcm_dai_probe [ 3.841247@0] [aml-spdif-dai]enter aml_dai_spdif_init [ 3.846175@0] aml_spdif_probe [ 3.849225@0] enter spdif_dit_probe [ 3.852922@0] enter aml_asoc_init [ 3.855790@0] p_aml_audio->hp_disable=1 [ 3.859587@0] falied to get spk event delay time [ 3.864145@0] spk_event delay_time = 0 [ 3.868501@0] aml_snd_card aml_m8_snd.40: dummy <-> I2S.32 mapping ok [ 3.874611@0] aml_snd_card aml_m8_snd.40: dit-hifi <-> SPDIF.33 mapping ok [ 3.881146@0] enter aml_pcm2bt_preallocate_dma_buffer stream: 0 [ 3.886957@0] enter aml_pcm2bt_preallocate_dma_buffer stream: 1 [ 3.892822@0] aml_snd_card aml_m8_snd.40: pcm2bt-pcm <-> PCM.34 mapping ok WARNING: Unimplemented Sip Call: 0x82000035 WARNING: Unimplemented Sip Call: 0x82000035 [ 3.907357@0] audio use jtag pinmux as i2s output, read val =ffffffff WARNING: Unimplemented Sip Call: 0x82000036 [ 3.917874@0] GACT probability NOT on [ 3.921262@0] Mirror/redirect action on [ 3.925040@0] u32 classifier [ 3.927883@0] Actions configured [ 3.931452@0] Netfilter messages via NETLINK v0.30. [ 3.936289@0] nf_conntrack version 0.5.0 (6452 buckets, 25808 max) [ 3.942725@0] ctnetlink v0.93: registering with nfnetlink. [ 3.948220@0] xt_time: kernel timezone is -0000 [ 3.952374@0] ipip: IPv4 over IPv4 tunneling driver [ 3.957673@0] ip_tables: (C) 2000-2006 Netfilter Core Team [ 3.962658@0] arp_tables: (C) 2002 David S. Miller [ 3.967364@0] TCP: cubic registered [ 3.970775@0] Initializing XFRM netlink socket [ 3.975822@0] NET: Registered protocol family 10 [ 3.980493@0] mip6: Mobile IPv6 [ 3.982870@0] ip6_tables: (C) 2000-2006 Netfilter Core Team [ 3.988514@0] sit: IPv6 over IPv4 tunneling driver [ 3.994092@0] NET: Registered protocol family 17 [ 3.997714@0] NET: Registered protocol family 15 [ 4.002341@0] Bridge firewalling registered [ 4.006445@0] Bluetooth: RFCOMM TTY layer initialized [ 4.011396@0] Bluetooth: RFCOMM socket layer initialized [ 4.016670@0] Bluetooth: RFCOMM ver 1.11 [ 4.020532@0] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 4.025951@0] Bluetooth: BNEP filters: protocol multicast [ 4.031336@0] Bluetooth: BNEP socket layer initialized [ 4.036388@0] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 4.042437@0] Bluetooth: HIDP socket layer initialized [ 4.047559@0] l2tp_core: L2TP core driver, V2.0 [ 4.052031@0] l2tp_ppp: PPPoL2TP kernel driver, V2.0 [ 4.056915@0] l2tp_ip: L2TP IP encapsulation support (L2TPv3) [ 4.062640@0] l2tp_netlink: L2TP netlink interface [ 4.067387@0] l2tp_eth: L2TP ethernet pseudowire support (L2TPv3) [ 4.073409@0] l2tp_debugfs: L2TP debugfs support [ 4.077959@0] l2tp_ip6: L2TP IP encapsulation support for IPv6 (L2TPv3) [ 4.084570@0] NET: Registered protocol family 35 [ 4.089131@0] Key type dns_resolver registered [ 4.093902@0] Registering SWP/SWPB emulation handler [ 4.098932@0] regulator-dummy: disabling [ 4.102564@0] aml_vrtc rtc.25: setting system clock to 2015-01-01 00:00:16 UTC (1420070416) [ 4.111576@0] enter cpufreq [ 4.113430@0] probe cpufreq okay [ 4.119320@0] hdmitx: cec: CEC probe, fun_config:0 [ 4.121706@0] input: cec_input as /devices/virtual/input/input2 [ 4.127508@0] hdmitx: cec: pinmux:ffffffc034473780, name:hdmitx_aocec [ 4.133713@0] hdmitx: cec: value:78009801 [ 4.137645@0] hdmitx: cec: value2:0 [ 4.141129@0] hdmitx: cec: irq:231, name:hdmitx_cec, ret:0 [ 4.146556@0] hdmitx: system: not find cec config [ 4.151213@0] hdmitx: system: not find ao cec [ 4.155514@0] hdmitx: cec: hdmitx_device->cec_init_ready:0x1 [ 4.164391@0] 6enter meson_pm_probe! [ 4.164820@0] meson_pm_probe done [ 4.168209@0] aml_istbt_dev_ready NULL [ 4.1717[ 4.178269@0] ttyS0 use xtal 24000000 change 115200 to 115200 [ 4.178787@0] Freeing unused kernel memory: 1028K (ffffffc001cf6000 - ffffffc001df7000) [ 4.377418@1] aml_nftl_dev: module license 'Proprietary' taints kernel. [ 4.378389@1] Disabling lock debugging due to kernel taint [ 4.384808@0] sync 1 [ 4.386119@0] init_aml_nftl end return 0 [ 4.390028@0] 6init_aml_nftl done! [ 4.507240@0] EXT4-fs (mmcblk0p13): recovery complete [ 4.507796@0] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: (null) [ 4.580973@0] switch_vpu_mem_pd: viu_vd1 OFF [ 4.581013@0] switch_vpu_mem_pd: afbc_dec OFF [ 4.583929@0] switch_vpu_mem_pd: di_post OFF [ 4.588156@0] switch_vpu_mem_pd: viu_vd2 OFF [ 4.725607@3] ttyS0 use xtal 24000000 change 115200 to 115200 [ 4.745091@0] EXT4-fs (mmcblk0p13): re-mounted. Opts: data=ordered /etc/init.d/rc.modules: line 10: depmod: not found [ 4.784918@0] mali-utgard d00c0000.mali: max pp is 3 [ 4.784958@0] mali-utgard d00c0000.mali: set min pp to default 1 [ 4.790243@0] mali-utgard d00c0000.mali: min pp is 1 [ 4.795115@0] mali-utgard d00c0000.mali: set min clk default to 0 [ 4.801186@0] mali-utgard d00c0000.mali: min clk is 0 [ 4.806273@0] mali-utgard d00c0000.mali: hiu io source 0xffffff800019e000 [ 4.813103@0] mali-utgard d00c0000.mali: hiu io source 0xffffff80001ae000 [ 4.819891@0] mali-utgard d00c0000.mali: num of pp used most of time 3 [ 4.826337@0] mali-utgard d00c0000.mali: clock dvfs cfg table size is 6 [ 4.832995@0] mali-utgard d00c0000.mali: max clk set 4 [ 4.837980@0] mali-utgard d00c0000.mali: max clk is 4 [ 4.843097@0] mali-utgard d00c0000.mali: turbo clk set to 5 [ 4.848598@0] mali-utgard d00c0000.mali: turbo clk is 5 [ 4.853864@0] mali-utgard d00c0000.mali: default clk set to 2 [ 4.859555@0] mali-utgard d00c0000.mali: default clk is 2 [ 4.864988@0] mali-utgard d00c0000.mali: ====================0==================== [ 4.864988@0] clk_freq= 125000000, clk_parent=fclk_div4, voltage=1150, keep_count=5, threshod=<30 120>, clk_sample=125 [ 4.883134@0] mali-utgard d00c0000.mali: ====================1==================== [ 4.883134@0] clk_freq= 285000000, clk_parent=fclk_div7, voltage=1150, keep_count=5, threshod=<100 190>, clk_sample=285 [ 4.901306@0] mali-utgard d00c0000.mali: ====================2==================== [ 4.901306@0] clk_freq= 400000000, clk_parent=fclk_div5, voltage=1150, keep_count=5, threshod=<152 207>, clk_sample=400 [ 4.919513@0] mali-utgard d00c0000.mali: ====================3==================== [ 4.919513@0] clk_freq= 500000000, clk_parent=fclk_div4, voltage=1150, keep_count=5, threshod=<180 220>, clk_sample=500 [ 4.937700@0] mali-utgard d00c0000.mali: ====================4==================== [ 4.937700@0] clk_freq= 666000000, clk_parent=fclk_div3, voltage=1150, keep_count=5, threshod=<210 236>, clk_sample=666 [ 4.955905@0] mali-utgard d00c0000.mali: ====================5==================== [ 4.955905@0] clk_freq= 792000000, clk_parent= gp0_pll, voltage=1150, keep_count=5, threshod=<230 255>, clk_sample=792 [ 4.974094@0] mali-utgard d00c0000.mali: clock dvfs table size is 6 [ 4.982210@0] gpu cooling register okay with err=0 [ 4.985115@0] gpu core cooling register okay with err=0 [ 4.990481@0] Mali: Mali device driver loaded [ 5.023878@2] RTL871X: module init start [ 5.023906@2] RTL871X: rtl8189es v4.3.10.1_13373.20150129 [ 5.027521@2] [wifi_setup_dt] wifi_setup_dt [ 5.031715@2] [wifi_setup_dt] interrupt_pin(235) [ 5.036240@2] [wifi_setup_dt] power_on_pin(248) [ 5.040725@2] ######platform_wifi_power_on: [ 5.044945@2] [extern_wifi_set_enable] WIFI Disable! 248 [ 5.402503@1] CPU2: shutdown [ 5.559834@0] [extern_wifi_set_enable] WIFI Enable! 248 [ 6.071434@0] [aml_sd_emmc_irq] sdio: resp_timeout,vstat:0x2800,virqc:3fff [ 6.074087@1] aml_sd_emmc_data_thread 2337 sdio: cmd:52 [ 6.080397@1] [aml_sd_emmc_irq] sdio: resp_timeout,vstat:0x2800,virqc:3fff [ 6.087409@1] aml_sd_emmc_data_thread 2337 sdio: cmd:52 [ 6.097809@1] [aml_sd_emmc_irq] sdio: resp_timeout,vstat:0x2800,virqc:3fff [ 6.100777@1] aml_sd_emmc_data_thread 2337 sdio: cmd:8 [ 6.107014@1] [aml_sd_emmc_irq] sdio: resp_timeout,vstat:0x2800,virqc:3fff [ 6.114054@1] aml_sd_emmc_data_thread 2337 sdio: cmd:5 [ 6.120291@1] [aml_sd_emmc_irq] sdio: resp_timeout,vstat:0x2800,virqc:3fff [ 6.127338@1] aml_sd_emmc_data_thread 2337 sdio: cmd:5 [ 6.133658@1] [aml_sd_emmc_irq] sdio: resp_timeout,vstat:0x2800,virqc:3fff [ 6.140618@1] aml_sd_emmc_data_thread 2337 sdio: cmd:5 [ 6.146846@1] [aml_sd_emmc_irq] sdio: resp_timeout,vstat:0x2800,virqc:3fff [ 6.153895@1] aml_sd_emmc_data_thread 2337 sdio: cmd:5 [ 6.160150@1] [aml_sd_emmc_irq] sdio: resp_timeout,vstat:0x2800,virqc:3fff [ 6.167187@1] aml_sd_emmc_data_thread 2337 sdio: cmd:55 [ 6.173594@1] [aml_sd_emmc_irq] sdio: resp_timeout,vstat:0x2800,virqc:3fff [ 6.180545@1] aml_sd_emmc_data_thread 2337 sdio: cmd:55 [ 6.186879@1] [aml_sd_emmc_irq] sdio: resp_timeout,vstat:0x2800,virqc:3fff [ 6.193923@1] aml_sd_emmc_data_thread 2337 sdio: cmd:55 [ 6.200242@1] [aml_sd_emmc_irq] sdio: resp_timeout,vstat:0x2800,virqc:3fff [ 6.207289@1] aml_sd_emmc_data_thread 2337 sdio: cmd:55 [ 6.217720@1] [aml_sd_emmc_irq] sdio: resp_timeout,vstat:0x2800,virqc:3fff [ 6.220663@1] aml_sd_emmc_data_thread 2337 sdio: cmd:1 [ 6.225913@1] sdio: error -110 whilst initialising MMC card [ 6.232662@0] [sdio_reinit] finish [ 6.236337@0] RTL871X: module init ret=0 [ 6.337582@0] dwc_otg: usb1: type: 1 speed: 0, config: 0, dma: 0, id: 1, phy: c0000020, ctrl: 0 [ 6.899772@1] CPU3: shutdown [ 6.900429@0] dwc_otg: Core Release: 3.10a [ 6.901083@0] dwc_otg: Setting default values for core params [ 6.906780@0] dwc_otg: curmode: 1, host_only: 1 [ 6.923597@0] dwc_otg: Using Buffer DMA mode [ 6.923617@0] dwc_otg: OTG VER PARAM: 1, OTG VER FLAG: 1 [ 6.927488@0] dwc_otg: Working on port type = HOST [ 6.932565@0] dwc_otg dwc2_b: DWC OTG Controller [ 6.936817@0] dwc_otg dwc2_b: new USB bus registered, assigned bus number 1 [ 6.943731@0] dwc_otg dwc2_b: irq 63, io mem 0x00000000 [ 6.948886@0] dwc_otg: -------hcd->flags.d32 = 0 [ 6.953488@0] dwc_otg: Init: Port Power? op_state=1 [ 6.958278@0] dwc_otg: Init1: Power Port (0) [ 6.963140@0] hub 1-0:1.0: USB hub found [ 6.966411@0] hub 1-0:1.0: 1 port detected [ 6.970675@0] dwc_otg: usb0: type: 1 speed: 0, config: 0, dma: 0, id: 1, phy: c0000000, ctrl: 0 [ 6.990671@0] dwc_otg: Core Release: 3.10a [ 6.990691@0] dwc_otg: Setting default values for core params [ 6.994830@0] dwc_otg: curmode: 1, host_only: 1 [ 7.011590@0] dwc_otg: Using Buffer DMA mode [ 7.011611@0] dwc_otg: OTG VER PARAM: 1, OTG VER FLAG: 1 [ 7.015485@0] dwc_otg: Working on port type = HOST [ 7.020405@0] dwc_otg dwc2_a: DWC OTG Controller [ 7.024807@0] dwc_otg dwc2_a: new USB bus registered, assigned bus number 2 [ 7.031737@0] dwc_otg dwc2_a: irq 62, io mem 0x00000000 [ 7.036870@0] dwc_otg: -------hcd->flags.d32 = 0 [ 7.041466@0] dwc_otg: Init: Port Power? op_state=1 [ 7.046270@0] dwc_otg: Init1: Power Port (0) [ 7.050522@0] DEBUG:set_usb_vbus_power:: set usb port power on (board gpio 1)! [ 7.050522@0] [ 7.059875@0] hub 2-0:1.0: USB hub found [ 7.063192@0] hub 2-0:1.0: 1 port detected [ 7.068107@0] random: nonblocking pool is initialized [ 7.077024@0] amlogic-thermal thermal: this chip is trimmed, use thermal [ 7.078884@0] amlogic-thermal thermal: keep_mode_max_range: [2016000, 666, 4, 3] [ 7.086446@0] amlogic-thermal thermal: keep_mode_min_range: [ 500, 400, 1, 2] Starting logging: OK Starting mdev... [ 7.169603@0] dwc_otg: Indeed it is in host mode hprt0 = 00021501 Initializing random number generator... done. Starting system message bus: [ 7.349569@1] usb 1-1: new high-speed USB device number 2 using dwc_otg [ 7.350795@1] dwc_otg: Indeed it is in host mode hprt0 = 00001101 done Starting network... ip: RTNETLINK answers: File exists Starting inetd: OK Starting supplicant... Device open failed !!! [ 7.620793@1] hub 1-1:1.0: USB hub found [ 7.621749@1] hub 1-1:1.0: 4 ports detected [ 7.900501@0] usb 1-1.2: new low-speed USB device number 3 using dwc_otg [ 8.084250@1] input: Microsoft Microsoft® Digital Media Keyboard as /devices/dwc2_b/usb1/1-1/1-1.2/1-1.2:1.0/0003:045E:00B4.0001/input/input3 [ 8.096261@1] hid-generic 0003:045E:00B4.0001: input: USB HID v1.11 Keyboard [Microsoft Microsoft® Digital Media Keyboard] on usb-dwc2_b-1.2/input0 [ 8.124384@0] input: Microsoft Microsoft® Digital Media Keyboard as /devices/dwc2_b/usb1/1-1/1-1.2/1-1.2:1.1/0003:045E:00B4.0002/input/input4 [ 8.136418@0] hid-generic 0003:045E:00B4.0002: input: USB HID v1.11 Device [Microsoft Microsoft® Digital Media Keyboard] on usb-dwc2_b-1.2/input1 [ 8.883126@0] CPU1: shutdown [ 11.698694@0] vout_serve: vmode set to 1080p60hz [ 11.698694@0] [ 11.699348@0] vout_serve: don't set the same mode as current. [ 11.707714@0] fb: osd[0] canvas.idx =0x40 [ 11.707716@0] fb: osd[0] canvas.addr=0x3e000000 [ 11.707718@0] fb: osd[0] canvas.width=7680 [ 11.707720@0] fb: osd[0] canvas.height=2160 Starting dnsmasq: OK [ 11.750013@0] fb: osd[0] enable: 1 (echo) [ 11.817222@0] vout_serve: vmode set to 1080p60hz [ 11.817222@0] [ 11.817860@0] vout_serve: don't set the same mode as current. # #
Here is what the partitions look like. I do not have an SD card inserted in the system.
# fdisk -l
Code:Disk /dev/mmcblk0: 7818 MB, 7818182656 bytes 4 heads, 16 sectors/track, 238592 cylinders Units = cylinders of 64 * 512 = 32768 bytes Disk /dev/mmcblk0 doesn't contain a valid partition table Disk /dev/mmcblk0boot1: 4 MB, 4194304 bytes 4 heads, 16 sectors/track, 128 cylinders Units = cylinders of 64 * 512 = 32768 bytes Disk /dev/mmcblk0boot1 doesn't contain a valid partition table Disk /dev/mmcblk0boot0: 4 MB, 4194304 bytes 4 heads, 16 sectors/track, 128 cylinders Units = cylinders of 64 * 512 = 32768 bytes Disk /dev/mmcblk0boot0 doesn't contain a valid partition table #
PankajLast edited by ajiratech; 20 August 2017, 05:37.
To support display need to have several elements. 1. Support in the kernel (in source code and configuration). 2. If the kernel not does a direct activation function of the monitor will need more utility "fbset". Which is commonly used in the activation script with the correct set of parameters, which activates the output on the monitor. As an example of such a script can be viewed here.
Partitions on the internal media, you will not see. There is no partition table (in its place be code the u-boot bootloader). To internal memory contents can be accessed via the mounting block devices (/devsystem /dev/data, etc.). For this you need the appropriate driver in the kernel (aml_nftl_new).
There are currently 1755 users online. 1 members and 1754 guests.
