MX III s812 amlogic 2g ram/8g ROM, not boot, only red light
    Hi guys. I have just joined this forum nice,
    I hope you solve my problem.
    I have a TV Box android MX iii with amlogic s812,
    This BOX, remains with the red light.
    I downloaded the new firmware, and used usb burning tool, but arrived at 2%
    fails and exits written Romcode/Initialize initialize USB DDR/Read status/Control setup error.
    I tried with boot card maker, formatted the SD CARD, put the files in the stock firmware,
    reset using the toothpick and switched power, but remains steady red.
    what to do?
    Thank you
      Thanks, but I have to watch the page 1?
      As I understand it, to use usb buring tool be welded the two pins of the nand flash?
        First go here i not see that device before. Alot of unknown things. Do you have right firmware is driver installed. Check here if dont see same device post photo of pcb (main board so chipsets can be seen) once we know what it is someone better able to help you.
        http://freaktab.com/forum/tv-player-...=1460141677416
          Ok! Upload photos, okay?
          Thank you
            😖 post the photos in the thread i posted for you
              friend, the images are large, so I put the thumbnails that are always visible with a click.
              upload immagini
              free image hosting
                You have 6330 chipset so go to post and use firmware posted by jd in 812 section Knowledge .
                  Hi scooter2014:-)
                  Be patient, but I can't find the post by JD, where to find it?
                  Thank you
                    Scooter2014, breaking News??
                      Sorry moving friends today /yesterday.
                        I tried boot card maker, but the box stays with the led solid red, zero
                        results. Now I want to try with USB burning tool, but I don't know if I should
                        use a USB cable male to male, or if I can use
                        USB OTG connection BOX.
                        I don't even know which pins of the nand flash solder to get the result.
                        If you can help all right, otherwise this box I throw it in the trash.
                        I am tired.
                        Thanks always.
                          Yes that was the post pins to short (not soder) are listed in post 13 shows you what pins. If you check near chip it will have a dot at first or star of nand. One is beside the dot.
                            Hello. My Nand flash is FORESEE NCEFES78-g.
                            You can look at the picture above and tell where should start counting the PIN? From left or right?
                            Thank you
