MX III s812 amlogic 2g ram/8g ROM, not boot, only red light
I Upload the photo. the nand; There is no inlet on the chip, wait
only one white cue ball, which should indicate the number 1 of the chip.
Just see the CHIP AP 6330
Confirm that the Chip FORESEE NCEFES78-g is the nand flash?
Because the pins marked USB burning tool I put them together, but it didn't work.
Then AP 6330 is the wifi chip?
Thank you
hostare immagini
We have the same PCB, just mine writes m82g v2.1, is suppose since it is a 2/16gb
I trid with a cable like this one you sent in the link,and Putty, but has a lot of "noise" in the data received. There are no pins in the PCB for Tx/Rx/Gnd so had to put some hand made cables, didn't want to solder them.
I suppose i am going to send the box back to supplier cause I am not even sure we have a working firmware for the box.
There are currently 2307 users online. 1 members and 2306 guests.
