S400 quad core minipc with RK3188-from cozyswan
    I was problems with wifi and blutouth after one firmware for mi mini pc., but i rezolved.
    I have s400 quad core with external antena wifi,from cozyswan.For mi this mini pc work with alotof firmware from ather tools with rk3188 ,but no wifi and blutouth.Now all it is ok, work wifi. with firmware from hier: http://pan.baidu.com/share/link?shar...&uk=3509931586
    If help....
    If help....
    Surely given the firmware to S400 (MK809 IV). Here's a post where I gave. 10 post
    MY MINI PC: C4,CS918,M8,M8C
      http://www.freaktab.com/showthread.p...809IV-Quadcore
      I tried your firmware with mi s400, and no hawe wifi and blutouth,\. In your version apear ddr 1gh,and i have 2 gh ddr.So, i think is not same version.You kan try your version with mi firmware, but i think is not exactly same.
        This is wrong I will sell these devices and know what suits you. Why do not you upload and write with does not fit. I have the firmware directly from manufacturers.
        I am working with this company for over a year
          I bought this Cozyswam S400 last week running 4.2.2. but I am upset wtih the Colour Depth. I think it is running @16-bit depth. instead of 32-bit atlest I am expecting 24-bit. Do you suggest any fix..
            upload it yourself http://www.freak-tab.de/neomode/MK80...1_20130620.zip
              I have updated, working better than previous one. But still 16-bit colours only. Installed MX player & xmbc.
                not working wifi & bl
                hey all, i have s400 usb sting and after first flash of custom rom i don't have wifi anymore no matter what rom i put, including stock. can you help me?Click image for larger version
ID:	431833Click image for larger version
ID:	431834 << this is my device
                  Originally posted by criszz View Post
                  hey all, i have s400 usb sting and after first flash of custom rom i don't have wifi anymore no matter what rom i put, including stock. can you help me?[ATTACH=CONFIG]4783[/ATTACH][ATTACH=CONFIG]4784[/ATTACH] << this is my device
                  email me at PM will send you a firmware
                    thank you, pm sent
                      I have same components (main board and wifi) but my stick is marked MK809III.
                      Can I use your firmware?
                        Received and installed. thx
                        i format nand with fash tool 137 , and install rom with rkbatch tool 1.7 without errors. Rom is working well but still no wi-fi or bl . What im doing wrong ?
                          so my board is not S400 is Mk809III ?
                            it is not important how you use bad upload the two programs
                            You use only RKBatch TOOL.
                            You hit restore and wait
                            you understood ?
                              you understood ?
                              till now i always used UPGRADE , now i used restore and waitting ....
                              EDIT:
                              BOOTED FINE
                              (( wifi & bl still NOT work
                              reboted
                              STILL NOT WORK
                              is anything else to do ? thx
