S400 quad core minipc with RK3188-from cozyswan
Originally posted by darekmarta1975 View Postare you sure the chip is OK
Edit: Jus installed NOWA WIFI you gave me and still the same( WIFI not working
I have the same board you have and I use this rom right now: http://www.freaktab.com/showthread.p...-dan-Vsync-Fix But the wifi still works pretty badly. 5mbps mostly.
Originally posted by arsuna View PostI have the same board you have and I use this rom right now: http://www.freaktab.com/showthread.p...-dan-Vsync-Fix But the wifi still works pretty badly. 5mbps mostly.
EDIT: WORKINGGGGGGG with stock from from your post, im so happy , thank you, thank you
what is so special at this rom who other roms don't have ? wifi drivers ? or what ? kernel ? ?Last edited by criszz; 17 January 2014, 19:48.
Originally posted by arsuna View PostIts the only kernel that seems to work. I have no real clue why.
Im still testing around but I havent found any other combination that works. And the wifi is still really shitty with that rom.)
without wi-fi my device was nothing
bluetooth working well also
thank you
Originally posted by veatla View Post
I bought this Cozyswam S400 last week running 4.2.2. but I am upset wtih the Colour Depth. I think it is running @16-bit depth. instead of 32-bit atlest I am expecting 24-bit. Do you suggest any fix..
Were you able to find a solution to the problem. Were you able to get 24bit or 32bit color depth. If yes, could you plz share the solution with me.
Really help me out.
dk
There are currently 1610 users online. 1 members and 1609 guests.
