Should I return this to the vendor? My Rikomagic MK802iv had no problems running this benchmark on the stock 4.2.2 rom.
MK908 reboots when attempting AnTuTu Benchmark CPU/Memory Test
I have tried both the stock firmware (4.2.2 May 28) and Finnless 1.5 with the supplied 2A power adapter as well as a 4A and everytime I begin the CPU/Memory Test, instant re-boot. I have a usb power meter and can see that the max current draw does not actually accede 1.6A.
Should I return this to the vendor? My Rikomagic MK802iv had no problems running this benchmark on the stock 4.2.2 rom.Tags: None
Try another USB cable from the PSU. Some can have a really lousy connection. Bottom line almost always when Antutu reboots like that, it's not getting solid power. If your sure all that is in order, maybe then consider you got a bad unit.
Originally posted by Finless View PostTry another USB cable from the PSU. Some can have a really lousy connection. Bottom line almost always when Antutu reboots like that, it's not getting solid power. If your sure all that is in order, maybe then consider you got a bad unit.
I've tried a couple different power supplies always with my usb power meter in-line, guess I'll try removing that meter from the equation and re-run.
I also noticed that in both CoolTool and AnTuTu the CPU frequency shows as 1008MHz and never seems to scale up or down. Contrast to my MK802iv which I can see will throtle up from 600MHz to 1.6 GHz. I saw this "locked: CPU clock with both the stock firmware and your 1.5 Finless ROM.
Originally posted by sausage View PostI have tried both the stock firmware (4.2.2 May 28) and Finnless 1.5 with the supplied 2A power adapter as well as a 4A and everytime I begin the CPU/Memory Test, instant re-boot.
However, after reading Bob' tip I will also try a different cable as the power supply should have enough power to handle it.
There are currently 3406 users online. 3 members and 3403 guests.
