AMLOGIC S905X - Inphic SPOT i7 PRO - A product development story...
Originally posted by prahjister View PostAndroid TV Box direct from China. English & EspaƱol
Originally posted by prahjister View PostWhat about a non soldered antenna? Easier to change later if wifi is weak..
Does/Will the 905x support both 2.4 and 5g
Maybe a software option when it senses the TV is off only push audio to 3.5mm or with hardware to internal speaker when TV is off. That should be relatively easy. I am playing with a box now that sends a toast message everytime I turn TV on that HDMI is connectedPrahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
After some testing on a s905. I believe the fan is a really good idea. I am testing the s905 stick and with just a small heat sink it reaches 75 deg Celsius very easily. After turning on fan temp drops really fast and runs about 35-40 always on.
Also I am starting to think 2gb mem is a must. If too many apps r running it gets slugish. Have to manually kill them.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
There are currently 3857 users online. 2 members and 3855 guests.
