AMLOGIC S905X - Inphic SPOT i7 PRO - A product development story...
Finally I got the new version of i7 pro. First thing, I opened the case and inspected inside the device.
First impressions are very positive. A good radiator. Not some flat piece of iron, as many manufacturers and high quality radiator. Connector for fan connection (which is easy to add). Connector to connect the UART console (very useful thing).
add foto
Hello balbes150, Thanks for the photos. Looks like Inphic listened to your suggestions. Should be Inphic's best effort yet.
Any idea what the maximum load is on the fan header?
Is the fan header controlled by firmware?
Looking forward to your developing impressions of the i7 Pro.
Regards.
Hi RISCy Dude
I have not yet checked the connector for the fan, no proper fan. A connector for UART already use, a very convenient option. I would define a new i7Pro - as a multifunctional device that can replace the outdated home PC for General tasks and at the same time as a device for multimedia playback. It is convenient to use two separate systems (multi system) - Linux as a desktop and Lebreelec as a powerful and lightweight multimedia system. I'm working on debugging a desktop version of Linux with the possibility of installing to the internal memory.
Originally posted by balbes150If you give links and write what you want to check, I can try to check. But just so you know, I'm not an expert on tests. I consider these devices in the first place, how universal miniPC.
Sent from my GT-I9190 using Tapatalk
There are currently 1769 users online. 1 members and 1768 guests.
