MXQ Pro (an maybe other boxes too) Request!
Originally posted by witokondoria View PostAndroid TV Box direct from China. English & Español
Just as a second-same-response, my box doesn't have this /sys/devices/virtual/amhdmitx/amhdmitx0/rgb_mode file (nor I could touch it). My disp_mode is also VIC:4 (1280 x 720 p 59.94/60Hz 16:9), where my edid outputs this:
Code:Rx Brand Name: PHL Rx Product Name: Philips EDID block number: 0x1 blk0 chksum: 0xc7 Source Physical Address[a.b.c.d]: 1.0.0.0 native Mode f1, VIC (native 255): ColorDeepSupport 38, MaxTMDSClock 45 31 16 32 33 34 20 5 19 4 18 3 17 2 22 7 21 6 1 Audio {format, channel, freq, cce} {1, 1, 1f, 7} {2, 5, 7, 0} Speaker Allocation: 1 Vendor: 0xc03 Vendor2: 0x0 SCDC: 0 RR_Cap: 0 LTE_340M_Scramble: 0 Rx 3D Format Support List: {VIC FramePacking TopBottom SidebySide} { 31 0 0 0 } { 16 0 0 0 } { 32 0 0 0 } { 33 0 0 0 } { 34 0 0 0 } { 20 0 0 0 } { 5 0 0 0 } { 19 0 0 0 } { 4 0 0 0 } { 18 0 0 0 } { 3 0 0 0 } { 17 0 0 0 } { 2 0 0 0 } { 22 0 0 0 } { 7 0 0 0 } { 21 0 0 0 } { 6 0 0 0 } { 1 0 0 0 } checkvalue: 0xc7b40000
Hello everyone. I used be around here under another user name (I don't remember it now). I just bought a couple of Qac Qoc AmLogic S905 MXQ boxes. This is the link from Amazon https://www.amazon.ca/gp/product/B01...?ie=UTF8&psc=1.
I'm hoping that someone can answer a few questions for me. I'm getting frustrated. In the past, I've rooted, modded and hacked the older Samsung devices and I have a collection of weird off-brand Chinese tablets. I had no problem with them. Until I bought the Android boxes, I was running Kodi on Raspberry Pi's. Again, no problem with anything.
These things...ughh. So, today I tried to upload a custom .ini into FTV Guide. I know that I don't need root because I have installed it in my Galaxy Note II. Even though I have hidden files enabled in System, I couldn't drop the file in through the file manager. I tried to go in through WinSCP. It's asking for a username/password. I don't have a clue what those would be. I haven't even added a GMail account to the device yet. I downloaded any apps that I needed with Raccoon. There is no username or password whatsoever associated with this device. Does anyone have any idea of what these would be? Blank doesn't work. And, yes, I did install the SSH software.
And, what's up with the Backup? I always used the Backup from the Kodi repository to backup the Pi's. I can't do that with the MXQ's. I have an SD card and a flash drive with plenty of storage available. Every time that I try to backup I get an error. Backup thinks that both storage locations aren't writeable and they should be.
At this point, I decided to just root the thing and get it over with. I don't really trust all of that Chinese software. I deleted as much of it as I could. Now I see that there are two models of that MXQ Pro. How do I know which one that I have?
And finally, could someone please point me towards the correct root software and possibly suggest a ROM? I'm just so confused at this point I really don't know what I should be using.
I'm just having a really hard time finding any information. There really seems to be more information out there for the Pi's and they aren't nearly as popular. Usually I am stubborn as a mule and struggle through because I won't ask for help. I have learned most of what I know this way. But, this time I really do need a hand.
Thanks!
I think MXQ has alredy released a new firmware to their vendors fixing pink-screen problem. Did not get it yet?Android TV Box direct from China. English & Español
Hi, just talked to MXQ engineer and told me that there are several versions and firmwares are different, so it could be a problem if you flash the wrong one.
I think he is going to send me something later... then I will back.Android TV Box direct from China. English & Español
Hi dude,
Same issue from my MXQ Pro + and PHILLIPS TV.
Current compilation: p201-userdebug 5.1.1 LMY47V 20160511
NO "Force RGB" option in more settings ...
Any new regarding this issue?, any file depot to download and upgrade?
I just have a no OTA service availabe message too when I try to update.
Regards from Málaga/SpainLast edited by asmartin; 06-01-2016, 06:24.
New upgrade for MXQ+ Pro stock firmware [ aml_upgrade_package0429.img ] :Good luck!!!Last edited by asmartin; 06-03-2016, 10:40.
There are currently 2389 users online. 4 members and 2385 guests.
