Thanks for your help.
How to remove lock screen on Finless rom 1.7c
I bought the MK808 from geekbuying last 2 weeks, and it came with the latest SW 4.2. I ran into the wifi and freezing issue as other people mention. After that, I load the Finless rom 1.7c and everything went smoothly. I could watch the whole movies from you-tube without any hiccup. There was only app to slow when open is XBMC, then I decided to try new Finless 2.1 ( 4.2.2). The rom version 2.1 load successful and the MK808 came up without any problem. I tried XBMC and it loaded and working faster, however, you-tube did not work at all. When clicking the movie the circle on you-tube app just spinning crazy and nonstop. I reloaded the rom 2.1 again, and I am still not able to watch you-tube movies. Finally I decided to come back rom version 1.7c, the installed went smoothly. However, when booting up the MK808 went straight to lock screen which displayed the clock on the left hand side show 12:00, the icon lock on the right side inside the flashing circle !!! Thus, if anyone had the same problem please shares the solution to remove the lock screen. I saw on the geek site there is a version 4.2 available for download, should I try that one out?
Thanks for your help.Tags: None
Settings -> Security -> Screen lock
Originally posted by daochoi View PostI bought the MK808 from geekbuying last 2 weeks, and it came with the latest SW 4.2. I ran into the wifi and freezing issue as other people mention. After that, I load the Finless rom 1.7c and everything went smoothly. I could watch the whole movies from you-tube without any hiccup. There was only app to slow when open is XBMC, then I decided to try new Finless 2.1 ( 4.2.2). The rom version 2.1 load successful and the MK808 came up without any problem. I tried XBMC and it loaded and working faster, however, you-tube did not work at all. When clicking the movie the circle on you-tube app just spinning crazy and nonstop. I reloaded the rom 2.1 again, and I am still not able to watch you-tube movies. Finally I decided to come back rom version 1.7c, the installed went smoothly. However, when booting up the MK808 went straight to lock screen which displayed the clock on the left hand side show 12:00, the icon lock on the right side inside the flashing circle !!! Thus, if anyone had the same problem please shares the solution to remove the lock screen. I saw on the geek site there is a version 4.2 available for download, should I try that one out?
Please try these:
1. Go to Settings -> Security -> Screen lock
2. Select None
(The next time you power up or boot your device, there will be no lockscreen anymore.)
Goodluck!
Originally posted by g.b.a. View PostHi,
Please try these:
2. Select None
Goodluck!
but, can you unlock the screen so you can go to settings and turn it off?
Use your mouse to move the lock to the right to unlock it. (Put mouse on lock, hold left button and slide right to unlock). Then go to testing as suggested above to turn it off.
hope it works.
hope it works.
There are currently 791 users online. 1 members and 790 guests.
