I will definitely try this out. Will get back with the results. Awesome tool btw! Good job!
Customization Tool 2.0.7
natinusala I get errors when I use the build script, am I doing something wrong?
output_file.c:30:18: fatal error: zlib.h: the file or catalog doesn't exist.
abootimg.c:51:25: fatal error: blkid//blkid.h: the file or catalog doesn't exist.
Do I have to install some missing repository?
I'm still pretty new to Linux, so excuse my newb.
Originally posted by Jinxy View Postnatinusala I get errors when I use the build script, am I doing something wrong?
Missed that you wrote it on your github already.
I still receive an error when using the build-script though.
"output_file.c:30:18: fatal error: zlib.h: No such file or directory"
I've installed zlibc, but I still receive the above error. Any ideas?
Was a bit too fast there.
However, now it doesn't find my input-file. Just states 'file not found: xx.img"
Edit: natinusala Saw your message after my post, yeah, that solved the issue, thanks!
However, it won't find my input file, just states that it can't find it.
Edit 2: Nevermind, it worked as intended now. Seems like I had fat fingers. Thanks!
Originally posted by natinusala View PostYou will have to copy the input file in the directory where you cloned the repository and run ./bin/unpack xxx.img.
Got another question which might be the wrong forum for it, but do you know any place where I can find information regarding opening and editing partitions? I've tried googling but haven't found anythinf decent. Would love to learn it.
However, thanks a lot for your awesome tool, it works perfectly!
Seems like your tool doesn't like modifications made to 'bootvideo' in /system/etc/.
When I replaced this file, it didn't manage to compile 'system' at all.
It compiles the .img just fine, however, when unpacked, system is empty.
Any ideas? natinusala
I suggest we move to the dedicated topic I made for this tool instead of polluting this one : http://freaktab.com/forum/tv-player-...with-android-7
The only amlogic tools you will need are right here, minus usb burn tool, ricky divjakovski has revamped them to work with new android versions.
just do a search for ricky divjakovski, revamped analogic tools.
Make sure to thank him, he also won't mind if you buy him a beer..You the man Ricky!!!!
There are currently 1848 users online. 0 members and 1848 guests.
