thanks for the reply
Customization Tool 2.0.7
I'm just wondering if there’s any way to make an image files smaller.
I’m currently using the MXQ pro s905x .img file
I have the image but when I add my apks and my Kodi build it exceeds 1.1G
I tied to delete most things from the build back up but I’m not sure what I can remove from the img file.
Does anyone have any ideas what I can remove without effecting the operating system?
Other then that, there isn't a lot that will make a great deal of difference, so you may want to look at the number of APK's you are installing and whether it will be easier to install them later from the Play Store.
Some firmwares come with a Kodi zip file full of addons, so worth looking for that to remove as it can be quite large.
I just have another weird issue, there's 3 apps (emulators) that won't install during firmware flash but other app install fine
I’ve tried the following
*place the apks in system/preinstall folder with all the other apps, all apps installed fine except these 3 apps
*I put unsigned version of these apps in system/app folder ,they still no luck
* I put signed version in system/app folder and also didn't install
any ideas
I’ve also tried getting the 3 apps from other sources and still no luck
Originally posted by bluesmanuk View PostDo any of the apk's have spaces in their file names?
Doing the 3rd option (put signed apk in system/app folder), it installed the apks but for some reason they give me black screen then go back to app page when I try open them
I have come across some APK's that do not install too.
Often paid ones.
I've never found a specific reason why but it has been intimated that the way that the apps are designed to install may have something to do with it.
If you create the firmware with only these apps and remove the others that you have added, do they install then?
What are the names of these apps?
Originally posted by bluesmanuk View PostI have come across some APK's that do not install too.
Often paid ones.
I worked it out
the play store will install different version on my tablet as opposed to box. I was trying to install the tablet version on the box. Once I noticed difference apk version.
Issue resolved
Thanks for your time in trying to help resolve the issue
Originally posted by comhen View PostDo you know which apk I can remove that won't affect the firmware.
all I’m really using the box for is Kodi some other apps
i've attached i screen shot
i always debloat my Roms after installing and delete about 20 Apps that i do not use like :
All Apps
APKInstaller
Browser ( only if u install another one )
Basic Dreams ( Wallpaper )
Camera2 ( only if you dont have a Web Cam )
Quicksearchbox
DeskClock
Exchange2 ( only if u use your own Email.apk )
FactoryTest
Filebrowser ( if u not need him or choose one of your one from PS )
HoloSpiralWallpaper ( Wallpaper )
LiveWallpapers ( Wallpaper )
LiveWallpapersPickers( Wallpaper )
Music ( u want to use Kodi / delete )
NoiseField ( Wallpaper )
NativeImagePlayer ( if it is another Videoplayer too )
OpenWnn ( chinese Keyboard or something like that )
PhaseBeam ( Wallpaper )
Soundrecorder
VideoPlayer ( u want to use Kodi / delete )
VisualationsWallpapers ( Wallpaper )
LatinIME (only if u want to use your own Keyboard )
MBoxLauncher ( only if u already installed another one there , same with Keyboard , after that they can deleted )
CalenderSync & Calender too if not needed .
and 3-4 Apps from the "priv-app" Folder , but this is not listed here .
After that i always wipe Cache & DalvikCache and Reboot , hope it helps you .
good luck
gefattern
Hi comhen ,
All Apps
APKInstaller
Quicksearchbox
DeskClock
FactoryTest
Soundrecorder
good luck
gefattern
There are currently 1909 users online. 0 members and 1909 guests.
