Time for a quick release ..
Due to the new Loader v2.54 we have an initial Update.IMG release - to be installed via rockchip tools.
The Update.zip will come later .. if required at all.
Update.IMG_Marshmallow_BOX64_v170117.7z
- Pre-Rooted (SuperSU-v2.76)
- Google Play Services pre-installed (open_gapps-arm64-6.0-pico-20161118.zip)
- Xposed Framework pre-installed (xposed-v86-sdk23-arm64.zip)
- Added XposedInstaller_3.0_alpha4.apk (as preinstalled user application)
- Automatic TWRP custom recovery installation on first boot !
- TWRP_3.0.2-1_RK3368_V160622.zip
- Added TWRP Manager (as preinstalled user application) - can be used for rebooting to recovery / loader / system.
- Added 3C Toolbox (as preinstalled user application)
- Added DRM Info (as preinstalled user application)
- Added TerminalEmulator (as preinstalled user application)
- Added TotalCommander (as preinstalled user application)
- Added MiXplorer (as preinstalled user application)
- Added Chrome (as preinstalled user application)
- Added Paragon (as preinstalled user application)
- Added Kodi 17 RC3 (ARM64)
- Changed bootanimation (default mmallow)
- Removed RKUpdateService
- Added Status bar to BOX64 version
- Added Navigation bar to BOX64 version
And here is the new dualOS version for Android M ...
This Update.IMG firmware release is using Rockchip Loader Version 2.54 !
Only as Update.IMG available.
Update.IMG_dualOS_Marshmallow-BOX64_Lubuntu_v170117.7z
The Linux part is the latest Geekbox Lubuntu rootfs.img. (V160309)
Pls look here: viewtopic.php?f=12&t=3276
Fixed the dual boot issue, as it´s not a dualOS release.
If you want different Linux versions .. Pls have a look here ..
https://onedrive.live.com/?authkey=%...42EE9E65C3FAF6
The Update.zip are supposed for TWRP installation.
The other zips are for rockchip flash tools .. just reflash the "linuxroot" partition.
NEW downloads:
https://drive.google.com/drive/folde...1cyWW9yRy1QMGc
OLD downloads:
Have fun !
