Android Marshmallow on RK3368 -> BOX64_v170117
Originally posted by mackjlm65 View PostHow do I swap them out? Sorry a newby and editing roms. Is there a tool I need to use?
Originally posted by scooter2014 View PostFiles names same as last time i downloaded did you change file names for the new builds? Ok 160604 is new which one is duel boot?
System.img was too small .. now it's up to 1.5 gb !
The mmallow only release :
Update.IMG_Marshmallow-NEW-SOURCES_v160604.7z
The new dualOS release:
Update.IMG_dualOS_Marshmallow_Lubuntu_v160604.7z
Installed via rockchip tools .. afterwards you can flash your own resource.img.
Still black screen no wake up from sleep. No keyboard for set up. Play store errors (package file stopped) wait or close on ugoos kodi.. Sd as stated above. Alot of different file managers maybe pick one only. Terminal not needed mm build. Slow ui. As followmsi said lot of issues with this one.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by scooter2014 View PostStill black screen no wake up from sleep. No keyboard for set up. Play store errors (package file stopped) wait or close on ugoos kodi.. Sd as stated above. Alot of different file managers maybe pick one only. Terminal not needed mm build. Slow ui. As followmsi said lot of issues with this one.
Thanks for testing .. will see what we can fix next
Originally posted by clarkss12 View PostI installed it yesterday (after several tries), WiFi and stock remote worked, but not Ethernet. I installed it on my Tronsmart R68 non-gigabit Ethernet version. Looking very good.
Do you know the excact Hardware of your Chip ?
Originally posted by followmsi View PostEthernet is different hardware .. different kernel .. etc.
Do you know the excact Hardware of your Chip ?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12 View PostNo, I don't. I tried to use the kernel and resource img files from the stock ROM for my box, but it would not boot. I use those img files when I use firmware from other devices. Right now I am running the current Zidoo ROM.
Next time when you try to change kernel and resource img.. try to change trust and uboot as well .
It may boot.
It may boot.
Thanks, I will give that a try.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
There are currently 4073 users online. 2 members and 4071 guests.
