Android Marshmallow on RK3368 -> BOX64_v170117
Originally posted by mackjlm65 View PostThis is what I see. Shouldn't I see 16gb as the total drive size?
EDIT:
Pls make
Code:adb shell cat /proc/partitions
Originally posted by scooter2014 View Post
Missed this post 64 @@@@@ I'll try tonight wowhoooooo.
It took some time for the BOX Version..but I wanted to do as Arm64 right from the begining.
Reboot Menu is working via remote control.. keep power button pressed.
Reboot to linux too, if required.
Hopefully also for the other devices too
Or just via TWRP app .. like before.
Cheers
Originally posted by followmsi View Post
Made a kernel for you ... You confirmed WiFi is working !
Originally posted by DNIZoid View Post
Updated to box version since then,kernel don't work because wifi can't be turned on in setting, flashed the ap6330 again still no luck. Tablet version was good but box so much smoother only downside is mentioned above and sd card not showing. Tryed stickmound no luck. Appreciate your response and your hard work.👏
This is a strange one ..
pls make full wipe .. Factoryreset via TWRP and test WiFi again.
If WiFi works in Tablet version .. it should work in BOX version too.
Normally
I have taken the ap6330 into "my" standard kernel .. but the resource.img is still pointing to ap6354.
You have always to install "your" kernel after you did an update .. to get back the ap6330 settings !
Or at least the resource.img.
Pls test WiFi again !
Normally
Normally
When I did factory reset it said unable to find partion size for /ramfs
Due to some HDMI-cec issues there will come a new box64 version soon .. as update.img too.
Then you just need to install the kernel for ap6330 afterwards.
Let's test this version .. release later today.
[QUOTE=followmsi;n578287]
This is not relevant for Android factory reset, pls ignore.
Great look forward to the new update. Thanks
[QUOTE=DNIZoid;n578296]Originally posted by followmsi View Post
Here you are ... more infos on first page.
Update.IMG_Marshmallow_BOX64_v160611.7z
Please use this kernel now .. for AP6330 .. Update.ZIP_Marshmallow_Kernel_AP6330_v160611.zip
To be installed via TWRP.
Confirmed working on mk68 without kernel change. You tube hd videos play great..... No task bar so no photos. Wifi stable build 27000 antutu. Running cool seems faster then other builds. Ui very smooth. Ill test kodi and sd cards ect usb works even ota port working on this one.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by scooter2014 View PostConfirmed working on mk68 without kernel change. You tube hd videos play great..... No task bar so no photos. Wifi stable build 27000 antutu. Running cool seems faster then other builds. Ui very smooth. Ill test kodi and sd cards ect usb works even ota port working on this one.
Sounds good ... See of beelink wifi works too .. But thanks for the report !
Need to check the task bar .. Maybe it's a quicky
There are currently 4388 users online. 1 members and 4387 guests.
