Android Marshmallow on RK3368 -> BOX64_v170117
The BOX64 version ..
Update.ZIP_Marshmallow_BOX-ARM64_v160609.zip
- Same content as TABLET64 version (it may run on old 1GB system partition as well)
- open_gapps-arm64-6.0-pico-20160608.zip
- Update.ZIP_TWRP_3.0.2-0_RK3368_V160607.zip -> fresh compiled 64Bit version with new blue theme
- New kernel from today with some minor fixes.
- Pls use your remote control to enter "reboot menu" .. or via TWRP app.
- Pre-rooted ARM64 boot.img for system-less SuperSU installations.
This release is still rooted the "old" way .. system-install mode !
I know, it´s a little bit early for the system-less stuff in Rockchip world - but we are prepared now
The new BOX64 release is only available as Update.ZIP release - to be installed via TWRP.
Enjoy !
When I install your newest firmware zip via TWRP, everything installs fine. After the Android screen comes up, it configures the 14 apps then reboots. After the reboot, it stays at the boot screen with the 4 colored dot animation forever. I can remove the power, plug it back in and it does the same thing, goes to the Android screen updates the apps then reboots.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12 View PostWhen I install your newest firmware zip via TWRP, everything installs fine. After the Android screen comes up, it configures the 14 apps then reboots. After the reboot, it stays at the boot screen with the 4 colored dot animation forever. I can remove the power, plug it back in and it does the same thing, goes to the Android screen updates the apps then reboots.
When you see the bootanimation .. pls do it like this.
Code:adb reboot recovery adb shell twrp wipe factoryreset adb reboot
If it´s not working fine .. we need the logs .. to be able to reproduce ..
Code:adb shell logcat
As you know .. the initial first boot will take approx. 5 -8 minutes .. maybe a few seconds longer .. but noch much !
Originally posted by mackjlm65 View PostOk so what updates am I supposed to flash? I am running a Zidoo X6 rk3368 2x16 gb
Do you want Linux and Android ? Take Update.IMG_dualOS_Marshmallow_Lubuntu_v160604.7z
or just Android only ? take this ... Update.IMG_Marshmallow-NEW-SOURCES_v160604.7z
Update.img .. Install like you did before.
update.zip later on .. via TWRP
Cheers
Originally posted by followmsi View Post
pls try a factory wipe first ..
There are currently 4361 users online. 1 members and 4360 guests.
